Echo 490
Discussion in 'Chainsaws and Power Equipment' started by Barcroftb, Mar 8, 2016.
  1. HDRock
  2. CoreyB
    CoreyB
    South east iowa
    Ok how are the photos and videos of the 490 coming?
    Maina, HoneyFuzz and Barcroftb like this.
  3. Barcroftb
    Barcroftb
    The Mitten
    Haha yeah we got a little side tracked with the fans didn't we? No video yet. The saw videos are on hold until I finish boiling maple sap into syrup. At 80 bucks a gallon I'd say it's worth my time.:smoke:
    I did fire it up today. Poured a lil fuel in the carb and a couple pulls and it fired right up. On a side note: I got a no spill Jill gas can recently, and will never go back! 11800 on the dti 20k tac says this saws actually tuned pretty well from the factory.
    Put it in some 16" hickory and shoot I had forgotten what a slug my old cs 500 was befor I modded the muffler.
    It actually has me contemplating these this evening:
    Dirt Bike Motion Pro Timing Degree Wheel | MotoSport
    Maina, HoneyFuzz and HDRock like this.
  4. LongShot
    LongShot
    New Mexico -Jemez Mountains
    well, I didn't pay quite that much. ;)
  5. clemsonfor
    Even the small Vornado is like $50 but it moves air of like a normal fan 4x it's size
    Stephiedoll, HDRock and LongShot like this.
  6. Kyle Mulligan
    Kyle Mulligan
    North Greenbush, NY
    You won't buy that wheel! You won't open up that cylinder! You won't advance that timing! You won't mod that muffler! You won't do it!:p
    clemsonfor and Barcroftb like this.
  7. millermodsaws
    millermodsaws
    I wouldn't advance the timing! :)
    I think you'll find it dosnt like it!
    Barcroftb likes this.
  8. Kyle Mulligan
    Kyle Mulligan
    North Greenbush, NY
    Why do you say that?
  9. millermodsaws
    millermodsaws
    I advanced the ported saw I did the build thread on 8° and the saw went backwards!
    Maina and Barcroftb like this.
  10. Barcroftb
    Barcroftb
    The Mitten
    I think Mwebba said the same thing about this saw not liking the timing advanced. Guess you confirmed it.
    Maina likes this.
  11. millermodsaws
    millermodsaws
    6100 dosnt like it either. In fact on the ported ones I mat try retarding it.
  12. Barcroftb
    Barcroftb
    The Mitten
    Well I got a chance to drop a 14" wild cherry. Thought it would be an appropriate test for the 490. So here it is in all its stock glory!
    Maina, HoneyFuzz, HDRock and 3 others like this.
  13. Barcroftb
    Barcroftb
    The Mitten
    So now that we know this is a well built but slow machine it's time to see if that can be improved. I'm going to take this in stages and post up a video of the gains on the same 14" green wild cherry log. First up the simple muffler mod:
    At least it should have been simple. The screws on the deflector were torqued right down and the head on this one stripped pretty easy. So I had to drill this one out and used some self tapping screws to reattach the deflector. Underneath the deflector is this little tube which restricts the exhaust quite a bit.
    Its only held by the deflector screws and will easily pull out of the muffler.
    20160312_182321.jpg once the tube is removed I modify the deflector by grinding the little tab off the front of it. From this: 20160312_190442.jpg
    To this: 20160312_215612.jpg
    Next I gave it some gills on the other side of the muffler to help it breath a little better.
    Stephiedoll, Maina, fox9988 and 4 others like this.
  14. CoreyB
    CoreyB
    South east iowa
    I gave Ya a big old thumbs up and a comment. I also subscribed to your channel.
    Maina, clemsonfor and Barcroftb like this.
  15. CoreyB
    CoreyB
    South east iowa
    AWESOME work. Looking great can't wait to see how she wakes up and sounds.
  16. Barcroftb
    Barcroftb
    The Mitten
    I use a small flat head screwdriver and a pair of needlenose pliers to shape the gills of the second muffler exhaust port.
    Notice I made sure to locate the second port so it wouldn't be blowing directly on the plastic or the side of the saw case. Plenty of clearance.
    After reinstalling the modified muffler the next thing to do is pull the limit caps off the carb and retune it. 20160312_193935.jpg
    The limit caps are red and are located over the low and high needles on the carb. They can be reached easily with a drywall screw through the adjustment holes in the plastic cover. I screwed the drywall screw in and pulled them out. Incidentally they seemed to be held in by a small metal shield which came off too. You can see it laying to the left of the red caps in the picture. This had the side effect of making the high and low screws easier to get at with a splined adjuster. The needles can also both be adjusted with a little flat head screwdriver too.
    So there you have it. Pretty basic muffler mod. The saw is tuned and hopefully I can get a quick video in the morning if it isn't raining too hard.
    Deererainman, Maina, fox9988 and 6 others like this.
  17. Barcroftb
    Barcroftb
    The Mitten
    Thanks I appreciate that. Let me tell ya uploading videos without high speed Internet sucks!
    clemsonfor and CoreyB like this.
  18. CoreyB
    CoreyB
    South east iowa
    Tell me about it. We have a satellite Internet service and it sucks. Sometimes a 2 min video takes 2-3 hours
  19. Barcroftb
    Barcroftb
    The Mitten
    About an hour for that short video. Let's just say there won't be any 5 minute pizz reving videos anytime soon.
    Maina, clemsonfor and CoreyB like this.
  20. CoreyB
    CoreyB
    South east iowa
    But I really like sharing them and seeing others videos. I would rather watch chainsaws on you tube than TV.
    YES I KNOW I HAVE A PROBLEM!
