'Easy start' chainsaws from various mfg's
Discussion in 'Chainsaws and Power Equipment' started by BDF, Nov 23, 2015.
  1. MasterMech
    There are 2 versions of Easy2Start. (In addition to the elastic start handles) The wind up type you would typically find on a MS250, or a spring assist type, similar to what Husky, J-red, and Dolmar and others all offer on their saws.
    Anybody notice that Husky has an elastostart type handle on some of their saws now too? :) Noticed it the last time I was pawing a T540XP.
    Horkn and Eric VW like this.
  2. Eric VW
    Are Huskies like the 440E and 445E, etc these types of start assist saws? Or does the "E" mean something different?
  3. MasterMech
    I can't say for certain as I haven't been paying attention to their homeowner line for a while now. :emb: but I'm fairly sure that you're correct.
    Eric VW likes this.
  4. BDF
    BDF
    With all due respect, I do not think that is correct- I went all through this when I bought my saw this last spring. Again, it is all in the part numbers. And of course, I am talking about current manufactured saws only as I have no idea of whatever may have been offered in the past. But to the best of my knowledge, Easy 2 Start is a very specific system that uses two springs and two sprags and basically disconnects the recoil start mechanism from the engine itself. Put another way, when pulling the recoil rope, it does NOT actually cause the engine to turn, it winds up a spring to store energy until there is enough tension in the spring to actually turn the engine; at that point the second sprag locks and the turning of the engine is totally isolated from the recoil starter (and the user).
    This chart explains it all: http://www.stihlusa.com/WebContent/CMSFileLibrary/downloads/Chain-Saw-Comparison-Chart.pdf
    The saw you used, and MS 250, does not have Easy 2 Start. Neither does an MS 251. But an MS 251 C-BE absolutely does have Easy 2 Start. All of them do have Elastostart though, at least the currently made models.
    Brian
    Edited to add: With all due respect. Not trying to start a pi$$ing contest here nor am I going to argue with anyone about this. I am merely seeking the facts, and also trying to present them as well as I can do so.
    Eric VW likes this.
  5. Eric VW
    It's all good in my book, BDF!
    I like a thorough read-up! :yes:
  6. pantelis
    pantelis
    Europe
    I dont like all theese bull........... like easy starts , heated handles , trio brakes , quick brakes and what a f........ call them .
  7. Eric VW
    pantelis likes this.
  8. pantelis
    pantelis
    Europe
    I like good saws like pro series from husqvarna , stihl , dolmar
    Eric VW likes this.
  9. Eric VW
    I can appreciate that:yes:
  10. MasterMech
    Little background on me: I sold and serviced Stihl (among other brands of OPE) for several years while employed by a dealer. I'm quite familiar with the in's and out's of these little machines. :dremel: :Thumbs:
    When I refer to an MS250 (or any other model) with Easy2Start, I am indeed referring to the C-BE version of that saw. As someone who types out thousands of these posts annually, often from my phone, it's common for me to drop the alphabet soup suffixes when referring to model specific features. ;) The MS250 and MS250C-BE are the same saw in my eyes with a few added bells and whistles. Using Stihl's alphabet soup nomenclature constantly will drive you batty. :wacky:
    The "E" (Easy2Start) suffix can actually refer to two mechanically different but functionally related systems as I was trying to clarify before. While the term Easy2Start is used on multiple models, the system is mechanically different on saws like the MS181C-BE, MS192C-E vs. saws like the MS250C-BE and larger. On the new smaller saws, blowers and newer trimmers, the system doesn't have that unique "wind-up" functionality the OP was looking for in competitive units. The wind-up version used to be the only version Stihl offered, I remember it quite well on units like the FS45/55 trimmers, MM55 Tiller, and the MS180, MS210, MS230, and MS250 chainsaws.
    Cut4fun, Horkn and Eric VW like this.
  11. BDF
    BDF
    Probably true enough- real men use misery whips, dull hatchets and fingernail clippers to lay in a 1,000 year wood supply with a broken left arm on a Sunday afternoon.....
    At any rate, it looks like only Stihl makes this specific version of a starting assist (Easy 2 Start). They do not offer it in any saw version above 55 cc in displacement (model MS 291 C-BEQ, which has virtually all of the newest, baddest features / detriments available). If / when they do offer a 60 / 70 cc saw with this feature, I would be sorely tempted to try one on although the value (read: what you get for the cost) is not great.
    All of that said, I do like my Echo 590 but find it a bit clunky to start. Hey Echo- copy Stihl's Easy 2 Start function (with a new, catchy name of course, maybe 'happy pulling' or some such similar), offer it up for $500 or less and I promise to buy one.
    Brian
  12. BDF
    BDF
    All I can do is go by Stihl's own nomenclature; if they are altering what a very specific phrase means, then certainly, all bets are off. If by 'electronic ignition' one means that it is done with electricity, then certainly Model T's with their wooden box 'exciters' were most certainly 'electronic ignition' but that is not how I would state it.
    Of course you are free to post / type whatever you want but when you refer to an MS 250 C-BE as an MS 250, it will always generate confusion because an MS 250 does NOT come with Easy 2 Start but a 251 C-BE does, while Stihl also makes a MS 251 without an Easy 2 Start feature, which is called.... an MS 251 with no following letters.
    In any event, I am the OP, and I was looking for a comparison of the Stihl 'wind-up' system as it compared to other manufactures. This year, I broke away from buying the big box store special of the day and actually bought a name- brand, gas fueled OPE: specifically and Echo trimmer, as opposed to what I would usually buy, which would be something like a Homelite Featherlight. I actually found the Featherlight to be a fine trimmer but is too short and does not have enough angle to suit me (I am 6'2") and was sick of bending over to trim. I was very happy with the Echo and while it did not represent the best value IMO, it is a nice, rugged trimmer that I can use while standing up on my hind legs. The next breakout was buying a Stihl chainsaw: a 211 C-BE that I really, really like a lot. But having five fairly large maples cut down this year (more to follow), it was a bit of a strain on the saw and me to whittle through these trunks and I could really use a bigger saw. Ended up with an Echo 590 simply because I believe it was the best value saw, by far, available in that size class, and I was not willing to spend $1,000 or so for an equivalent Stihl. Now the Echo is a fine tool IMO, and will serve me just great for the foreseeable future and I am happy with it but it can be a bit.... cranky to start. Not miserable or horrible, just far more demanding than, say ,the Stihl. And I firmly believe that machinery should serve man, not the other way around..... ever. So I was considering a different saw, possibly something in-between the Echo and an equivalent Stihl in price / performance (again, read: value). Jonsered came to mind and I was wondering about that company's version of "Easy Start".
    So back to the Echo and possibly re- fitting it with a decompression valve that works a bit better.
    I still would not pay, say, $1,000 for any Stihl (or any other brand) saw as I do not believe I can ever get the value from the tool cutting firewood for myself. Then again, as I am big on 'nice' machinery that functions well, I would absolutely consider a 60 / 70 cc Echo with a Stihl- type, spring and sprag type starter for, say, $550 or so.
    Brian
  13. Horkn
    While it is hard to tell where the piston is on the stroke, its far from a gimmick.
    My parents bought a new stihl ms211cbe last fall. Without the easy start, she might not be able to pull it over. With the easy 2start it's scary how easy it is to get running.
    I used it last winter, and again this past weekend. Slick little saw, and it cuts very well even through decent sized oak.
    An acquaintance has an easy start stihl. He had to lock it up as his very small kids are starting it and they thought it was funny. That's scary....
  14. Oldman47
    Oldman47
    Illinois
    I have no idea where to find it today but I recently saw a video of a little girl, perhaps 7 years old, starting a Dolmar with one of their easy start systems. Don't recall what Dolmar calls theirs. It was all that kid could do to wind it up but when she got to the end of the pull stroke the darned thing started every time.
    Horkn and CoreyB like this.
  15. pantelis
    pantelis
    Europe
    I can not understand why is so important if the saw have easy start
  16. dougand3
    dougand3
    North Alabama
    I looked up decomp for Cs-590 - they want $40-$50 for it. YAWZER! Echo A014000040
    I buy Husky valves in lots of 5 for $2 each. The ads read Husky, Stihl, Dolmar, Makita, Partner....not Echo
    Pull your valve and get mm and pitch...maybe ads forget Echo and Husky might fit. 1omm x 1.0 pitch
    Horkn likes this.
  17. pantelis
    pantelis
    Europe
    99% fit 1.o pitch is a common for the most saws , but i not put my hand to fire
  18. MasterMech
    With the Easy2Start? While I agree $800 is way too steep for an MS291C-BEQ, the base MS291 would have been nearly a pound lighter than the 590 and cost you $510 at MSRP. And I agree that the Echo 590 is the best bang for the buck in the Farm Boss/Rancher/Timberwolf category.
    Did you consider the Dolmar 6100? A fantastic professional quality saw from a reputable manufacturer. Has a spring assist starter, weighs the same as that 590 (on paper at least) but has a helluva lot more power.:saw: I thought the spring assist on the 6100 was quite nice, not a wind-up type starter but certainly a smooth, easy pull. If I needed a 60cc saw tomorrow, that's most likely what I'd be buying. Pricing can vary from about $580 or less depending on your source.
    DOLMAR - PS-6100
    That's from our own CoreyB . Here's his vid.
    concretegrazer, Eric VW and Horkn like this.
  19. Horkn
    My 73 yr old wood burning mom that cares for my 73 yr old dad with ALS could explain it for you.:yes:
  20. Machria
    Machria
    Long Island, NY
    Thanks for the vid, that is pretty cool. Seems like a great idea to me. hmmmmmmmm
    MasterMech likes this.
