East/West and North/South loading.
Discussion in 'Modern EPA Stoves and Fireplaces' started by Perry long jr, Dec 18, 2022.
  1. Nitrodave
    Nitrodave
    Grayling Mi.
    My father in law used to have a small pot bellied type stove… remove small lid on top and drop on the wood… burned just fine .
    Rich L likes this.
  2. Gark
    Gark
    SW Michigan
    Our Ideal Steel starts quick but burns long with a hybrid of N/S and E/W. The bottom layer is 6” NS (max 17” long) then on top is E.W. layer up to 20” long, thinner to the rear growing fatter toward the front. “Works fine, lasts a long time”.
    brenndatomu, Rich L, oldspark and 3 others like this.
  3. oldspark
    oldspark
    NW Iowa
    How many pieces of wood do you put in?
    The Wood Wolverine, Eckie and Gark like this.
  4. Gark
    Gark
    SW Michigan
    Four n/s on bottom, three e/w on top.
  5. oldspark
    oldspark
    NW Iowa
    Gonna have to try that in my IS.
    The Wood Wolverine, Gark and Eckie like this.
  6. blacktail
    blacktail
    PNW
    My insert is small so there are times I want to get as much fuel in as possible. Wood cut shorter will dry faster and split easier too.
    You could just cut a portion of your supply at 13" and use it when you need the stove at its fullest. NS under a row of EW would stretch that supply even further.
  7. Raiderfan
    Raiderfan
    MA
    True. I never loaded my stove (any of them) N/S and E/W at the same time (except at start up)... I was always under the thinking that it would allow for too much air flow during a regular burn
    NewYorkNewJack and blacktail like this.
  8. The Wood Wolverine
  9. billb3
    Both of my stoves are N/S designed stoves.
    I have an old one in the garage that is coal/wood vertical/top load. Similar to a Warm Morning but made by/for (I think) Sears.
    NewYorkNewJack and KSPlainsman like this.
  10. Todd
    Todd
    NW WIS
    I’ve tried both ways many times in my F45 and N/S works best for me.
    NewYorkNewJack likes this.
  11. thescratchylens
    thescratchylens
    Rock County, Wisconsin
    Very thoughtful.
  12. ginger1313
    ginger1313
    I just started loading e/w this winter after only loading n/s.
    For whatever reason, my burns times have increased and no more back puffs when I close the air too much.
    I'm guessing because the burn is slower and less smoke is being produced so the stove doesn't fill with smoke and ignite causing a back puff.
    It is always amazing what little adjust do. Part of the fun I suppose.
  13. The Wood Wolverine
    This season so far, I’ve loaded the back of my 25” (n/s) firebox with splits oriented N/S, then put 2 splits E/W in front. This seems to block incoming air until those 2 fronts are burned, then allows it to flow to the rear most splits and acts similar to opening the vent a bit later in the night. I’ve only been able to do this since I have 18” splits. Next year I’ll get into the wood cut 24” specifically for this stove.
