Earth Stove
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by StihlHead, Oct 4, 2013.
  1. Erik B
    Erik B
    Western Wisconsin
    I do put about 4-5 cords thru it every year. I own my own woods so I burn whatever Mother Nature gives me. I find I have to cut rather short pieces, about 12 inches or so but that makes it easier to load.
    papadave and fox9988 like this.
  2. Bowtie
    Bowtie
    Kansas
    Here is my Earth Stove 100. I just installed it after building the hearth and protected wall behind it.
    HDRock, NortheastAl, fox9988 and 2 others like this.
  3. papadave
    Hey Bowtie, welcome aboard. Nice first post, too.
    That's a real clean Earth Stove. Am I looking at window panes in the door? Never seen one like that.
    Also, do I see an air gap around that wall?
    SisIL had one of those, but a 1000 series. Hers was a rustbucket, unlike yours.
    NortheastAl, Brad38 and Bowtie like this.
  4. Bowtie
    Bowtie
    Kansas
    This stove was in my sisters house that caught fire due to electrical fault Last feb. I had to restore the finish but the stove itself is very sound. Had not had much use. I used steel wool to remove rust, wiped it down with lacquer thinner, allowed it to dry, then painted it with 3 coats of 1200 degree stove paint.
    Fired it up to burn off the stinkies the other night. I can understand the overfiring deal. This thing burns hot!
    HDRock, Chvymn99, NortheastAl and 3 others like this.
  5. Bowtie
    Bowtie
    Kansas
    Yes it has the metal door, windowed door, and a metal screen. The wall has a 1" air gap behind the tile, then stove installed at minimum protected wall clearances listed on back of stove.
    bushpilot, HDRock, Chvymn99 and 4 others like this.
  6. papadave
    I love it when someone does things the right way.
    Kudos.
  7. Bowtie
    Bowtie
    Kansas
    I used 1 1/4" steel wall studs turned on side covered in 1/2" durock and natural slate tile.
  8. Bowtie
    Bowtie
    Kansas
    Thanks papadave, I don't want to burn my house down, I spent a while planning and buying the necessary chimney shields and pipe to do it right.
    HDRock, Chvymn99, NortheastAl and 2 others like this.
  9. Brad38
    Brad38
    S. Indiana
    Great looking setup!
    Bowtie likes this.
  10. Bowtie
    Bowtie
    Kansas
    Thanks Brad. Our last house had a small El Fuego insert fireplace. I burned that thing like it was going out of style trying to heat the 1700 sq. ft. house we had. Im quickly learning that this Earth Stove is a whole different animal. Without even trying it produces 3 times or better the heat the insert did.
    Im a newbie here but I recognize a few names from another forum I frequented for a long time.
    Chvymn99 and papadave like this.
  11. HDRock
    Real nice setup there Bowtie :thumbs::fire:
    Bowtie likes this.
  12. Eric VW
    Looking gooder, Bowtie. How well does that window seal? Brand new like?
    Bowtie likes this.
  13. Bowtie
    Bowtie
    Kansas
    It seals good enough that it kills the fire if I shut off the air intake.
    HDRock, Eric VW and papadave like this.
  14. Eric VW
    I shoulda said the window next to the hearth..
    Unless that's what you meant.
  15. OnceUponaTimer
    OnceUponaTimer
    Northern ny
    Mine is a series 1000.I have never seen 1 with the hardware that keeps the door snug on the inside like mine.Thru the back it has the 1inch iron pipe N 2 half inch copper pipes I thought may have been for a coil to heat water. Would love any N all info I can get.There is a round meatal disk that I don't believe is original that attaches to the top edge.Great for heating things N keeping coffee warm as it raises N lowers or pivots off to the side to adjust heat.
    I call her by her Indian name KEEPSMEWARM.
    fox9988 and HDRock like this.
  16. OnceUponaTimer
    OnceUponaTimer
    Northern ny
    I posted a pic in "everything else" of a homemade woodstove my pal has at deer camp, my earth stove in its entirety fits in
  17. Unicorn1
    Unicorn1
    Amarillo, TX
    I like the Earth Stove, and I remember going to the October Fest in Mt. Angel, OR.
  18. Big Dragon
    Big Dragon
    Nebraska
    Hi everyone, I just joined the page after reading all the post. I have a Earth Stove 100 and was trying to get info on putting a baffle plate and air tubes in it for secondary burn? Any tips or reasons that this wouldn't work in this stove? I'm looking to make it more efficient and "LONGER" burn times as well as cut the ease of over firing. The spring dampener in back does function correctly, the door seals tight and I added a dampener to the chimney but can only 3-4 peace of wood without the chimney temp going every which way. As a result only getting about 4 hour burn time, and that is not cutting it. This is the second Earth Stove that I've had and this one doesn't perform at all like my other one did. Thanks for the help and thanks for letting me join the group.
    fox9988, HDRock and Eric VW like this.
  19. Eric VW
    Happy join up day, yesterday and welcome Big Dragon :thumbs:
    Share what ya know and post up a pic when you can....:)
    I'm anxious to see what will come of your question.:yes:
    HDRock likes this.
  20. Big Dragon
    Big Dragon
    Nebraska
    image.jpeg This is my Earth Stove set up.
    milleo, fox9988, HDRock and 1 other person like this.
