Eager Beaver oiler?
Discussion in 'Chainsaws and Power Equipment' started by HDRock, Mar 31, 2014.
  1. HDRock
    Eager Beaver, 2.1
    Oiler worked off an on, now its not working at all, has auto and manual.
    Is there a good Way to flush the system out, with Kerosene or something?
  2. MasterMech
    Does either oiler work? Dual systems like that often had tiny check valves in them that get sticky. If one gets stuck open, no oil. I would flush it out with Kero or similar.
    HoneyFuzz likes this.
  3. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Not super sure...but I would definetly start with a Kero-Clean ! Good luck :)
  4. HDRock
    Neither one works now, at first the auto quit, pump worked, then it quit working also
    I cleaned up the bar and around the port, poked a small wire in port ,auto worked for a couple of tanks , and quit
    I don't use it that much but want to get it working proper, first saw I ever owned, and a new chain was on the way when oiler quit
  5. HDRock
    Is Kero the best thing to use ,cuz IDK , I was just guessing
    I should run the saw with Karo in it , bar n chain attached ???????
  6. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    At 36.00 a gallon I am not sure I would! Things might get a little sticky!:rofl: :lol:
    Gary
    HDRock likes this.
  7. HDRock
    I haven't tried it in any saws yet but I picked up some of this
  8. HDRock
    Well ??? :whistle::smoke:
  9. MasterMech
    You're just trying to work some Kerosene through the system so running it without the B&c or with won't matter, just don't do any wood cutting.
    HDRock likes this.
  10. HDRock
