Dump trailer! need advise
Discussion in 'Chainsaws and Power Equipment' started by swags, May 2, 2015.
  1. haveissues
    haveissues
    Hudson Valley
    I'm sure that trailer would be great. I used a trailer for a while with a telescopic cylinder and it would often times be unable to start lifting the load. Luckily it always happened when my tractor was near so I used that to help start the lift. Once going it was fine. The trailer I just ordered has a scissor lift.
  2. Oliver1655
    Oliver1655
    Central Missouri
    Thomas,
    - I would encourage you to see how much more it would be to upgrade the axles to 10,000 (10K) axles.
    - D-rings welded in the bed. While handy for tying down equipment, can inhibit dumping by giving the material to being dumped something to hang on to.
    - Does it have a solar panel battery charger? Is it an option? Sam-tip has one on his dump trailer.
    Hinerman likes this.
  3. Hinerman
    Hinerman
    NE Oklahoma
    I cannot imagine needing 10K axles; I don't have any heavy equipment; just hauling wood. D-rings on walls does make more sense. Solar charger is an option.
    http://bigtextrailers.com/options/dump-options/
    But doesn't the battery charge off the truck; and won't the dump operate off the truck power if it is hooked up?
    EDIT: I called Bigtex. 10K axles is not an option; they do have a model with 3-7K axles. Also, the D-rings are in the corners, not on walls. It appears you cannot custom order a trailer from Bigtex. And, the trailers are not designed to run off truck battery; the truck will "trickle charge" the trailer battery, as does the solar panel. For every day use, the trailer battery needs to be recharged from a 110 outlet.
  4. concretegrazer
    concretegrazer
    Southwest MO
    As long as it's sized and placed properly your fine. The truck I use for filling silo has an undersized scissor. So they placed it further back to provide adequate lift height which makes it useless for hauling dirt or gravel.
  5. Hinerman
    Hinerman
    NE Oklahoma
    Wow, just called the Bigtex dealer in Tulsa. $7495 for 14' dump trailer with 7K axles, ramp, and tarp. $220 extra for spare and $300 more for solar charger. Seems high to me, but I don't know for sure.
  6. eatonpcat
  7. haveissues
    haveissues
    Hudson Valley
    Take a look at load trail. After extensive looking around they are some of the nicest IMHO and should be a bit cheaper than that.
  8. Hinerman
    Hinerman
    NE Oklahoma
    Just looked. There is a dealer about 10-12 miles from my house. I bought a trailer from them 7-8 yrs ago, different brand, non dump, utility trailer.
  9. Stihl Livin
    Stihl Livin
    Minnesota
    Swags did you buy a dump trailer yet. I have been looking at one of the 10' long load trails since I found your thread.
  10. My IS heats my home
    My IS heats my home
    Albany, NH
    I'm just cruising through the dump trailer threads and came across your pics with a full loaded 16' trailer with he gooseneck. What do you guess your carrying for weight with that green load of tree length?
  11. My IS heats my home
    My IS heats my home
    Albany, NH
    Can you tell me which model of load trail you got and the weight capacities. I just wrote them an e-mail and asked to spec out a certain model for me. I'm not even sure there are any dealers in my area, worst case I may have to travel if the price is right. Can you tell me what you paid for yours??? Thanks
  12. Scotty Overkill
    My cousin has an old blue Bri-Mar trailer with the twin two-stage cylinders, talk about a heavy duty trailer. I've used it many times.....
    TurboDiesel and clemsonfor like this.
  13. Scotty Overkill
    Sure Trac makes some decent trailers for the money, blacksmith 's cousin has a 5th wheel dumper and it's a dang nice trailer...I think it's rated for 12k ....
  14. My IS heats my home
    My IS heats my home
    Albany, NH
    It's funny how select trailer companies retail in certain parts of the country. Like someone who posted earlier said, in Texas they have trailers at every other intersection...In Mass we might have 6-8 companies total meanwhile there are 15+ manufacturers that make decent trailers for what we are looking for. This site is great when we do research for things like this because it lets us know what else is out there, it's definitely worth doing the research.
    i've seen a handful of sure-trac in CL pics but I have yet to see them come up on google searches around here. Thanks for the heads up Scotty
    Scotty Overkill likes this.
  15. MasterMech
    +1 on Sure-Trac being a top-notch trailer. I have a local dealer here and have looked several times.
    Be wary about cheap trailers manufactured out-of-state. Not all states have the same standards for required equipment on trailers. Especially in the south, the requirements are relatively lax compared to NY. I wouldn't expect Mass to be much different than NY. Tires, axles, brakes, couplers and lighting are all areas manufacturers cut corners to keep the price low. Not at all uncommon to find brand new trailers built with minimal structure, used tires, brakes on one axle (or worse, none) and non-DOT compliant lighting with sub-standard wiring. I've seen couplers welded on that were rated under the GVWR of the trailer. Also, some states do not require titles on trailers of any size so make sure you know what your regs are. You do not want to buy a trailer out-of-state and get it home and find out you need to install $$$$-worth of equipment and go through DMV purgatory to get it legal. Ask me how I know. :doh:
  16. savemoney
    I like the idea of the trailer vs a truck. You can go through a lot of trucks for one reason or another, but the trailer is usually in good condition and available.
    swags and My IS heats my home like this.
  17. 94BULLITT
    94BULLITT
    Frederick County, VA
    Bri mars are not a bad trailer but they are over rated and over priced.
    The two best made dumps I have seen are sure trac and load trail.
    Sent from my SPH-L710 using Tapatalk
  18. clemsonfor
    Heard bad things about BigTex Fit and finish, I think the actual structure is fine though.
  19. clemsonfor
    Swags what did you do before the full time flipping? I thought you always did this or was it just a part time thing before? We're you a contractor before and did pay jobs in between flipping?
  20. My IS heats my home
    My IS heats my home
    Albany, NH
    I'm looking at the sure-tram and load trails right now, emailed both companies over the weekend.
    As far as the Bri-mar are concerned, I have to give them kudos on pricing around my way. I'm looking at 7x12, 12,000 gvw units
    and they are under $6500. The CAM Superline is the overpriced dump trailer around here, nearly $1400 more than Bri-Mar.
    I'm waiting to see what sure-trac and load trail come in with numbers
