Dry Wood. Still a Little Sizzle
Discussion in 'The Wood Pile' started by Babaganoosh, Dec 11, 2016.
  1. Babaganoosh
    Babaganoosh
    Jersey Shore
    I've never run an epa tube stove. Just an old cast iron Russo and then my Ideal Steel. Maybe the difference is that you run mostly full tilt with the tube stoves while the cat stoves can be run lower and slower. That small amount of moisture probably won't affect a tube stove because of how hot you run it but it may affect the cat stove because you aren't trying to run the firebox as hot. Just a theory anyway.
    Backwoods Savage and Woodsnwoods like this.
  2. oldspark
    oldspark
    NW Iowa
    LOL, thank you for pointing out I had that worded stupid, I try not to do that but missed that one.:D
  3. oldspark
    oldspark
    NW Iowa
    Yep no problem at all, seems like some are concerned about nothing but a little moisture under the bark.
    Woodsnwoods and Eric VW like this.
  4. Canadian border VT
    Woodsnwoods the Ideal Steel is a catalytic wood stove with a bypass.. the higher moisture does something not good to the cats... I got same stove as Babaganoosh because my wood this year is marginal 18 to 22 Mc on center fresh split. .. I am compensating by leaving the bypass open a few minutes longer ... probably got a face cord of really dry ash I will use when the cold hits this week.. may have to turn on furnace at 12 below we will see my flue Temps are a little low 350.. i like them low.. as long as still heating house
  5. Babaganoosh
    Babaganoosh
    Jersey Shore
    Yup. My wood is a few percent less moisture wise over last year and the difference is very noticeable.
  6. Canadian border VT
    Babaganoosh So is this what you did? the good news is i still got 3 years left stacked and covered outback:)
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Ahhhh, makes more sense now. I am not familiar with the EPA level stoves. I certainly can understand the impact moisture would have on them though. Good bit of knowledge to know prior to getting a new stove.....
  8. Backwoods Savage
    You don't have to have a sunny spot necessarily. We have stacked wood in the shade many times. Get on the 3 year plan and all will be well.
  9. oldspark
    oldspark
    NW Iowa
    Burning dry wood in a pre-EPA stove is important also, just that people refused to believe it.
    One of my favorite posts was "I wonder how my old non EPA stove would have worked with dry wood.":hair:
  10. oldspark
    oldspark
    NW Iowa
    Some of my wood is in a shaded spot (gonna change that) and it took about 10 days to dry out under the bark after a rain this past fall, much better when the sun can hit it.
    Woodsnwoods likes this.
  11. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Top cover and wind.....firewoods two best friends.
  12. oldspark
    oldspark
    NW Iowa
    That's what I was waiting for ( to cover it) , I dont cover during the seasoning of the wood just the wood to get used the winter coming up.
    Sun and heat are more important then some give it credit for, the heat drives the moisture to the surface and the wind takes it away.
    nobody, Babaganoosh and Woodsnwoods like this.
  13. Backwoods Savage
    Right...
  14. Canadian border VT
    I am really thinking I need to go do some more :saw::axe::stacke:.. I think this year we had 5 days above 90 .... 11 days above 80 ..... don't know where to look but I would guess year average is 55... I have had snow on and off since 10/22 Dennis will vouch for it:)
    I am 3 years ahead now... maybe us northerners need a 5 year plan!
  15. ansehnlich1
    ansehnlich1
    I top cover my wood with rubber roofing as soon as I stack it. The stuff I'm burning has been split/cut and under cover for 4 to 5 years. I have absolutely no moisture problem, however, if I bring some stuff in that's been sitting for 4 years, but rained on recently, then right there is when I get the ends sizzling and bubbling til she drys out.
    Fanatical1 and Woodsnwoods like this.
  16. yooperdave
    Once again, there ain't no cheating the three year plan.
    The wood won't dry no matter how much you want it to....it needs time to dry on its own.
    Lets see now...wood cut in summer of 2016....add three years...I've got it! It'll be ready to burn in the fall of 2019! Right? Eureka!
    There will be no turning back once you hit that stage of firewood processing. People have to break out of the mold of cutting wood and burning it the same or second season........Please!
  17. bushpilot
    bushpilot
    Eastern Washington
    With the softwood trees I have and the climate I live in, 2nd year (two summers) is quite workable. More is better.
    Sean and papadave like this.
  18. Kevin in Ohio
    Kevin in Ohio
    All my wood is stored under roof. I've burnt wood that has been stored for over 10 years on a dry concrete floor that still sizzles. You can take Kiln dried lumber and store it in the atmosphere and it will GAIN moisture content once out of the kiln. Just like a slow fire in my stove(OWB) will start running some moisture when the snow starts melting hard. There is so much moisture in the air it collects and runs as that moisture has to be dried out if you will. Not much you can do about it.
    rdust and Babaganoosh like this.
  19. Kimberly
    Kimberly
    The Kangaroo State
    When I get a decent video camera; might have to borrow my sister's camera, I should do a walk around and see what the advice is for my wood storage. Current stacks are at the end of the drive. I want to build some storage bins and not have to do this cross stacking; it takes more time and the wood has to be drawn off equally over the stack or you risk collapsing the stack.
  20. Kimberly
    Kimberly
    The Kangaroo State
    Yes, different regions, different curing times. Here the summers can be quite humid, with humidity constantly at the high end. That humidity has to affect my drying time in the summer months.
