Drolet 1800i Install (Long & Pic Heavy)
Discussion in 'Modern EPA Stoves and Fireplaces' started by ReelFaster, Sep 2, 2018.
  1. ReelFaster
    ReelFaster
    S.Jersey
    Hey FB, thanks so much, I am pretty happy with it. Can't wait to burn (Mid 90s all week here, ugh)
    The liner is a bit awkward. I first laid it out on the lawn and straightened it best I could as it was all coiled up in a box. It kinda has a mind of its own but you can work it pretty straight. I did this alone! Goal was for my wife to pass it to me up on the roof, however she was out food shopping and being the impatient person I am I decided to give it a go alone as I had it already rigged to pull down the chimney. I threw the rope on the roof and got up there heave hoed it up to the first roof just pulling the rope. It was a bit heavy, long and awkward and I was giving it my all but I got it up. Once my wife got home we began pulling it down. Dropped the rope down and when I started pulling up to 2nd roof I just started feeding it down chimney while my wife pulled. Went pretty easy except for throat part. But a couple times pulling liner back up and her pulling down we got past fairly quick. At min I'd recommend a light helper to just help pull it down and do small things to assist. If you can get another guy, it def will make it easier. This was my 1st go at anything like this and its far from perfect but am here to help in anyway and share my experience. I planned this out for weeks and went over it in my head a bunch times. Originally was gonna ovalize part of the liner but decided to cut out part of the damper as recommended by many.
    milleo, Maina, bear 1998 and 4 others like this.
  2. brenndatomu
    Great advice!
    Maina, bear 1998, Horkn and 1 other person like this.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    great writeup, thanks !!!
  4. Locust Post
    Looking real good, and good call on the crown coat. Just redid mine but I used the same brand but went with the trowelable crown coat. Worked so well I did my boiler chimney crown next and gave the rest to the neighbor to do his.
    Maina, bear 1998, BCB and 4 others like this.
  5. Horkn
    Nice work!
    They really are not that difficult to install.
    Thanks for the crown coat idea BCB, I need to do mine as I have a few cracks on mine as well.
    Maina, bear 1998, BCB and 2 others like this.
  6. BCB
    BCB
    USA
    Here's my post (with pic) from 2016. The chimney top in the pic is from my old house. I had enough product left over to do the crown at my current house also.
    Crown repair
    Maina, bear 1998, Horkn and 3 others like this.
  7. ReelFaster
    ReelFaster
    S.Jersey
    I just got of the phone with the stove shop I purchased it from and yes the adapter is stainless steel....
    I just looked that stuff up BCB and that stuff looks great and easy to apply. Good tip, thank you!! I want to replace the other top cap since one is nice and shiny and other is black and rusty so when I do I'll hit it with that stuff.
  8. ReelFaster
    ReelFaster
    S.Jersey
    Does anyone recommend or think it's worth it to put some furnace cement around the stove collar where it connects to the appliance connector? Or really not necessarily?
    Maina, bear 1998, Horkn and 2 others like this.
  9. Eric VW
    I could agree with that.
    Also, even tho it’s not much of a distance, I would think wrapping some ceramic fiber blanket around the appliance adapter would be a gooder idea.... the more insulated the better!
  10. ReelFaster
    ReelFaster
    S.Jersey
    Thanks Eric, I think I'll do that!!!
  11. lukem
    I would definitely use some stove cement in your adapter. If it isn't air-tight it will either leak smoke into your house (not as likely) or the draft from the chimney will pull in cold air and maybe cause some creosote build-up (more likely, but not a given).
  12. ReelFaster
    ReelFaster
    S.Jersey
    Thanks lukem definitely going to pick some up for sure before I start burning. Amazon has it for under 13$ bucks!!
  13. BCB
    BCB
    USA
    It is. It brushes on nicely. IDK why the link to the product didn't come up in my response. It's called ChimneyRX
  14. Locust Post
    The ceramic blanket around the adapter with 1 or 2 hose clamps would be ok but as far as I am concerned you're wasting your time with stove cement down that close to the stove as it will just get brittle and crack and/or fall off.
  15. ReelFaster
    ReelFaster
    S.Jersey
    After reading the reviews on some of the cement products that seems to be the case about drying out and cracking. But for 12$ bucks, I picked up anyways, I guess it gives me a mental peace of mind.
    Maina, bear 1998 and Firefighter like this.
  16. lukem
    It will crack, but it won't fall apart unless you pull the insert out and/or move the chimney around a lot. Just flake the loose stuff off and dope it up again before putting the insert back in.
  17. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Welcome to the Drolet owners club. We meet each Tuesday at the pub. We can actually afford the drinks because it's an affordable stove and u put it in your self
  18. ReelFaster
    ReelFaster
    S.Jersey
    bear 1998 and brenndatomu like this.
