Draft questions?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Keweenaw, Feb 19, 2016.
  1. Keweenaw
    Keweenaw
    tapiola mi
    Yeah, I've been really happy with how it has helped :D
    After I try the key damper tomorrow, I will hopefully have learned how to regulate the temp in my stove.
    HDRock and Eric VW like this.
  2. HDRock
    That's a heck of a note, you've gone from not enough heat to too much heat :D
    Eric VW, bobdog2o02 and Keweenaw like this.
  3. Keweenaw
    Keweenaw
    tapiola mi
    Ok, so I installed the key damper this morning and loaded the stove up with spruce, let it come up to 500 degrees and shut the main air down and turned the key damper just 1/4 turn.
    The STT dropped to about 450 and has been cruising there for going on 4 hours now, and I bet I have an hour to go, which is the longest a load of spruce has burned for me :)
    I will really get a better idea tonight when I load up with hard wood, those are the loads that seem to go nuclear. Hopefully not anymore :yes:
  4. saskwoodburner
    saskwoodburner
    Glad that it was such an easy fix for you. I had made a post on my stove where I tinkered with the air lever, and it didn't take much cutting the air on the top end, to simmer down a fire and increase burn time.
    I would say in my situation, I could go too far and hinder the fire and it would start dropping temp on the flue probe. My fine line seems to be keeping most flame under the baffle, with a few licks running between the baffles now and then. More than that, and the stove would go up 75 degrees, but the flue probe possibly 200 or more, so it's the point of diminishing returns.
    I'm sure you'll find the right balance with your stove. Good job for going against conventional wisdom, and trying it for yourself.
    basod, HDRock, Eric VW and 3 others like this.
  5. Eric VW
    Sounds like promising conditions are afoot, Keweenaw :thumbs:
    Anxious to hear of the results on a full load of the hard stuff:yes:
    basod, Keweenaw and bobdog2o02 like this.
  6. Keweenaw
    Keweenaw
    tapiola mi
    So warm out today that we decided to let the fire go out before bed :loco: :crazy:
    But I'm sure tomorrow night I will get a proper read on it
    basod and Eric VW like this.
  7. Keweenaw
    Keweenaw
    tapiola mi
    Ok, 75% full load of hardwood went in an hour ago. STT climed to about 600 with key damper closed as well as damper on the front of the stove. That is way better than before, 700 degrees and above doesn't make me very comfortable, not to mention my house gets way hot! Now I'm cruising at 450 and I'm looking to see good coals and a warm stove in 6 hours, might update when I reload at 4, depends on how groggy I am. Otherwise I will report once I'm up for the day:)
    milleo, HDRock, fox9988 and 4 others like this.
  8. Eric VW
    Nice!
  9. wildwest
    I have been following this thread. Congrats Keweenaw !
  10. Keweenaw
    Keweenaw
    tapiola mi
    Not quite 4 yet but the coyotes woke me up they were being so loud, it's been a solid 6 hours and I've still got a full bed of coals and the house is still warm :D
    Before the key damper at the 6 hour mark I would have seen maybe just barely enough coals for a reload and the house would be 10 degrees cooler than when I went to sleep. Right now the living room is 75 and the far bedroom is 65, both 5 degrees warmer than normal right before a reload :yes:
    milleo, Eric VW, HDRock and 5 others like this.
  11. crzybowhntr
    crzybowhntr
    WV
    Great to hear that you're getting along better with it now.
  12. ironpony
    ironpony
    Mid Ohio
    I registered 36 years ago, no call yet.
  13. papadave
    Took me a second.............:rofl: :lol::picard:
    Eric VW, wildwest and bobdog2o02 like this.
  14. Keweenaw
    Keweenaw
    tapiola mi
    It's not connecting upstairs for me???
    I don't get it...
  15. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I'm glad I'm not alone.
    Eric VW, wildwest and Keweenaw like this.
  16. ironpony
    ironpony
    Mid Ohio
    registered for the military draft.......you must be youngins
    bobdog2o02, Eric VW, HDRock and 4 others like this.
  17. yooperdave
    Yeah, youngins for sure!
    Over 4 decades ago for me. I still have it also. Looked at it a couple years ago and couldn't believe the weight that was on there!!!
    Eric VW, Keweenaw and wildwest like this.
  18. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Ahhh, the selective service. Yea, did that too.
    Eric VW likes this.
  19. Eric VW
    Now there's debate about women registering......
    But that's another topic altogether :whistle:
  20. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    They should. Equal and all....
    wildwest and Eric VW like this.
