Draft Question
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Kevin1024, Jan 1, 2017.
Tags:
  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Now a fire device should never be vented into the prevailing wind direction. Causes, yup bad burns and/or vacuum (wind related) shut downs.
    IHATEPROPANE and ivanhoe like this.
  2. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    As a test disconnect the OAK.
    IHATEPROPANE, ivanhoe and slvrblkk like this.
  3. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Kevin are you learning any thing?
  4. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Setup is the very first thing that must be correct or everything else will be for naught. Luckily he has what is normally a solid unit.
  5. imacman
    imacman
    Denver, NC
    Yes, just disconnect from the stove for the time being. The guys here are trying to help you determine where the problem might lie. If flame shortens and gets bright & lively after removal, you've found your problem.
    If not, there may be a blockage or air leak in the stove. How many bags through the stove before the problem started, or problem started right from the beginning? (don't remember from the other thread)
    Have you removed the liner from the rear of the stove and seen how much ash has built up and/or cleaned the entire liner?
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Shortly I'll have to go down for short nap, didn't get one yesterday and was draggin' hind end early.
  7. imacman
    imacman
    Denver, NC
    :Yar:
  8. imacman
    imacman
    Denver, NC
    Kevin, try to keep all the posts about your stove in the same thread. Multiple threads about the same thing gets confusing. Maybe mods can put them all together? jtakeman
    IHATEPROPANE, ttdberg and ivanhoe like this.
  9. Kevin1024
    Kevin1024
    Nj
    Ok. I just disconnected about 15 minutes ago. I'm feeling air still through the OAK pipe. Is that the stove trying to still get outside air even though I disconnected it? Should I plug the end of the oak pipe even though it's still disconnected? It's still sitting real close to the stove. Sorry if I don't know what I'm talking about.
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Pete, I loose steam fast these days, no stamina for the most part.
  11. Kevin1024
    Kevin1024
    Nj
    Sorry Smoky. I'm learning a lot.
    ivanhoe likes this.
  12. slvrblkk
    slvrblkk
    Northampton, PA
    Nap or hibernation? :D
  13. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Just let us know what the flame did it should be drawing more from the room.
    IHATEPROPANE, ivanhoe and imacman like this.
  14. imacman
    imacman
    Denver, NC
    The only reason to plug the OAK pipe up the chimney would just to keep the cold air from coming back in the house. The stove is ALWAYS trying to get air.
    So, since disconnecting, any change?
  15. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Nap not allowed to 'nate. Meds.
  16. imacman
    imacman
    Denver, NC
    That's the purpose of being on this forum. Lots of friendly and very knowledgeable pellet burners here.
  17. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    There is a backdraft valve on the air intake that valve must be free to open, they have been known to stick somewhat closed which leads to yup, bad burn. Nap time for bear.
  18. Kevin1024
    Kevin1024
    Nj
    The flame looks livelier. Now I'm seeing sparks flying like my p43. I'm liking it.
  19. imacman
    imacman
    Denver, NC
    I'm guessing like on an oil burner.......flapper opens & closes as needed?
  20. imacman
    imacman
    Denver, NC
    Has the flame gotten a lot shorter?
