Downdraft problem, looking for suggestions
Discussion in 'The Wood Pile' started by JDU, Jan 21, 2025.
  1. Krackle_959
    Krackle_959
    Coastal Maine
    We have a similar situation in our basement with a wood stove. The down draft would blow out lit newspaper before I could put it into the stove pipe. Smoked out the basement twice before calling it quits for a bit. Doesn’t help that the stovepipe goes out to the chimney below grade, and an exterior chimney at the North end of the house. Talking to my fil he mentioned the fact that we rebuild our bulkhead door and added an insulated door at the bottom of the stairs. Mentioned opening it to see if that helped. Before it was just a wooden bulkhead that was 40 yrs old and needed work.
    I tried it again with the bulkhead door open, and the newspaper stayed lit, and burned quickly when I put it into the stovepipe. Made all the difference having the bulkhead door open. Our house has a fieldstone foundation and is 207 yrs old, so nowhere near air tight. My wife has been happy with the whole house being 70 degrees now instead of the far end being 60 degrees.
    Chaz, wildwest, Chud and 6 others like this.
  2. Eckie
    Eckie
    So I get the concept of the hair dryer, but does that blow ashes or dust everywhere? I would think even pointing it up would stir things quite a bit. Would a heat gun be better since it puts out more heat faster? Or is the fan speed of the hair dryer more beneficial?
    I typically use my little green bottle Propane torch to get the warmth started, but am not fighting the basement issue, so I don't need to overcome as much.
    Chaz, wildwest, John D and 4 others like this.
  3. brenndatomu
    It can, so gotta be careful where you point that thang! :rofl: :lol:
    I'm sure a heat gun would work well too...but a lot more people own hair dryers.
    Chaz, wildwest, RGrant and 6 others like this.
  4. Eckie
    Eckie
    I bought a heat fun from Harbor Freight for like 15-20 bucks or something...I figured wth not. Had some use for it at the time, can't remember what. It's proven useful several times. And probably much better for me grab than the hair dryer for domestic reasons.....
    Chaz, sms4life, wildwest and 5 others like this.
  5. brenndatomu
    If you haven't been given permission to use the hair dryer, its just not cold enough in the house yet...;)
    Chaz, JD Guy, jtstromsburg and 11 others like this.
  6. Eckie
    Eckie
    Bahahaha...touche!
    Chaz, JD Guy, wildwest and 6 others like this.
  7. JDU
    JDU
    Perry County, PA
    Thanks to everyone for comments and suggestions. I never considered the air flow situation as part of the problem, but obviously to me now, it is. Unfortunately my basement is not conducive to just opening a door or window, but I will come up with something. Preheating flue ideas/tools where also great and I did that to start a fire yesterday in 16 F temps outside.
    JDU:salute:
    Chaz, MikeInMa, Chud and 8 others like this.
  8. wildwest
    eatonpcat, MikeInMa, Chud and 3 others like this.
  9. wildwest
    The stove with the cold plug chimney here is a big old Pre-Epa with large firebox, (= holds a ton of ashes), we just prop it upwards towards the fire box and let it go a few minutes. If we had tried it on the NC13 (small firebox, secondary tubes and baffle I could see that blowing ashes around.
    Chaz, eatonpcat, Chud and 4 others like this.
  10. BC Doug Fir
    BC Doug Fir
    Cariboo BC
    Your smoke pipe looks outrageously big for the size of the stove. Maybe neck it down to 5””. Somebody on here would know more.
    eatonpcat, Chud, JDU and 1 other person like this.
  11. JDU
    JDU
    Perry County, PA
    I agree, but a 6" pipe fit on the oval opening on stove top, so I just continued rest with the 6". 5" pipe would seem more appropriate and might try necking it down.
    5" flue was on several wood cook stoves I used.
    Chaz, eatonpcat, Chud and 1 other person like this.
  12. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Should holler when you know you’ll be coming through and stop for a cup o’ coffee.
    Yea swede capital is correct. To be clear, you’re talking with a bonafide Swedish festival King. ‍♂️
    Chaz, eatonpcat, John D and 3 others like this.
  13. wildwest
    We had a pot belly stove in the garage when we moved in here. Both the stove opening and the pipe installed were 6". A previous owner ran auto repairs out of the garage.
    Chaz, eatonpcat, JDU and 3 others like this.
