Door Gasket Needs Relacement
Discussion in 'Modern EPA Stoves and Fireplaces' started by trooper, May 13, 2017.
  1. lukem
    You could try either....flip the gasket or scrunch up the 3/4 gasket. Just make sure you to a dollar bill test when you're done.
    Old stoves used to use furnace cement to hold the gasket on instead of silicone. Doesn't take much.
    Well Seasoned and Marvin like this.
  2. HDRock
    Scrunch that 3/4" gasket up real tight And measure it To see how close you get to 7/8
  3. Marvin
    Marvin
    Huntingdon, Pa
    I got it in. The door seemed a lot tighter. I guess I will find out once it cures. One problem I ran in to....the glass gasket kit did not cover all 3 pieces of glass :hair: I guess I'll order another kit. Also one of the screws that holds the glass tight snapped off. I hope it doesnt leak there. I'll have to drill a new hole sometime and put one in. I guess Murphy showed up to help me out.
    Well Seasoned and HDRock like this.
  4. HDRock
    So do you have a gap there were there is no glass gasket present ?
    One thing after another I hope you get it fixed up Where it works right .
    Do You have a backup heat source ?
  5. Marvin
    Marvin
    Huntingdon, Pa
    I just kept the old gasket on it for now. Hopefully it will be okay until I can get another one.
  6. Horkn
    So i got a new gasket for my quadrafire 4100i. All of the online research says it uses 3/4" rope gasket, so I bought a kit from a Wisconsin eBay seller. The gasket cement is from Gaskets Inc, whom I used to buy from when I worked for a place that made Regenerative Thermal Oxidizers, essentially giant blast furnaces that burn off VOC's. Those RTO's always needed gaskets. I'm certain the materials I bought are good quality.
    My only issue is that the existing gasket on the door looks way smaller than the 3/4" gasket I bought.
    Is it just that the old gasket is smooshed down making it look smaller?
    I don't want to pull the old gasket out and then realize that I need a different gasket size. I've never changed the gasket yet, but it's starting to leak on the hinge side.
    So I'm looking to see if anyone that owns this stove can let me know if I have the right gasket or not. Paul bunion ?
  7. lukem
    New gaskets usually look big. Not sure what your stove calls for, but I can understand the "there's no way this is the right size for my stove" feeling.
  8. HDRock
    My gasket is 7/8 Looks really fat And The old one definitely looks smaller On the door .
    Seems to me I remember someone with the stove like yours did post About replacing the gasket Could have been Paul bunion
    brenndatomu and Well Seasoned like this.
  9. Horkn
    Ok, I didn't do enough homework. From the manual....
    This says it takes .625" rope gasket. That would be 5/8". I'll mention it to the eBay retailer after I measure the channel on the stove as extra reassurance. I'm assuming I'll just need to buy the correct gasket. I'll still wait to see what Mr Bunion says though.
    brenndatomu, Well Seasoned and Marvin like this.
  10. Paul bunion
    Paul bunion
    Sounds kind of like me. My memory is poor on this one but I think I bought a chunk of rope from a local stove shop and cemented it in. And since I never throw anything away I think this scrap is what was left over.
  11. Paul bunion
    Paul bunion
    Don't confuse the door glass gasket with the window gasket. They are definitely different sizes.
  12. Horkn
    Yeah, I'm talking the door gasket. Afaik, the glass gaskets are good.
    What size diameter is the stuff you have?
  13. Locust Post
    Good luck Horkn I will say I used gasket cement on my old stove and never liked the way it worked because if you get too much soak through it can make the gasket a bit brittle. When I changed this time Buck recommended and uses high temp silicone on their gaskets.
    brenndatomu, HDRock and Well Seasoned like this.
  14. yooperdave
    As I remember, there are two ways to measure the gaskets.
    You probably need the high density stuff. Noticeable difference between 5/8 gasket and 5/8 high density stuff.
  15. Horkn
    The screenshot II hav from the quadrafire manual says it needs low density rope gasket.
    I found a place that sells the right gasket.
  16. Paul bunion
    Paul bunion
    The piece I have seems to be 3/4. I don’t know the difference between low and high density. I’m guessing that it’s low as it is rather hollow.
    brenndatomu, HDRock, LongShot and 3 others like this.
  17. Horkn
    Thanks! Maybe it will work? Now I'm hesitant to do anything unless I know for certain that a local store has it in the shelf.
    Also there's apparently two different latches for 4100i models. Mines different than the one in the manual I posted above. So I wonder if there's 2 gasket thicknesses? I'll dig up my manual, not the one I found on the internet.
    brenndatomu and HDRock like this.
  18. Paul bunion
    Paul bunion
    My stove is an early model. From when the fan did not have a bypass switch to turn it on.
    As I recall I bought the gasket locally. But I don’t remember exactly how I figured out what I needed. Other than I did spend a lot of time looking at schematics to find the right parts.
    Are you replacing the latch? I did that too. The roller catch wore down to nothing. Bought that from Black Swam Stoves.
  19. HDRock
    I agree And I found in my manual for my lopi , That is Says to use high temp silicone ,so, That's what I'm going to use next time
  20. HDRock
    I had so much trouble with the different brands of gasket cement That is another good reason not to use it
