Dolmar ps 6100 info and videos
Discussion in 'Chainsaws and Power Equipment' started by CoreyB, Nov 4, 2015.
  1. Barcroftb
    Barcroftb
    The Mitten
    Cabin fever much?
    CoreyB, Shawn Curry and Eric VW like this.
  2. Eric VW
    Yes, thank you very little. :rofl: :lol:
    Don't fall on yer face and lose yer phone Fri or Sat nite, pal!:whistle:
    :wacky:
    HDRock, Shawn Curry and Barcroftb like this.
  3. Barcroftb
    Barcroftb
    The Mitten
    I am growing my beard out for such a contingency! :dex:
    Shawn Curry, HDRock, CoreyB and 3 others like this.
  4. CoreyB
    CoreyB
    South east iowa
    I hope to get some more videos up in the near future. The 6100 is really screaming these days.
    Andyshine77, mdavlee, HDRock and 2 others like this.
  5. CoreyB
    CoreyB
    South east iowa
    Hey thought I would share this here as well.
    The 6100 continues to put a smile on my face and starts so easy.
    This is in some green white oak about 18" across.
    Andyshine77, DexterDay and Barcroftb like this.
  6. CoreyB
    CoreyB
    South east iowa
    Making more firewood. This time with a dead white oak that is a bit harder then the green one. Lol
    Mandy the 6100 makes short work of a tree.
    DexterDay, HDRock, Ronaldo and 2 others like this.
  7. Andyshine77
    Andyshine77
    Cincinnati, OH
    You have to love the sound Dolmar's make!!
    Sent from my HTC One_M8 using Tapatalk
    Barcroftb and CoreyB like this.
  8. MasterMech
    My 6100 is downright ferocious sounding compared to most new saws.
  9. CoreyB
    CoreyB
    South east iowa
    I love the sound when idling sounds like it is just dieing to unleash it's wrath. Lol
    Barcroftb, Andyshine77 and Eric VW like this.
  10. Andyshine77
    Andyshine77
    Cincinnati, OH
    The Dolmar's run high compression, that's what makes them sound so good.
    Ronaldo, MasterMech and Barcroftb like this.
  11. CTYank
    CTYank
    CT Panhandle
    Need confirmation of that? My 6100, after 4-5 tankfuls- 210 psi. Two years and many more tankfuls later- 210 psi. Right up around what I used to see on a 12.5/1 CR production-racer. Consistency & durability a BIG PLUS. Still a badazz spitting chips.
    CoreyB likes this.
  12. Andyshine77
    Andyshine77
    Cincinnati, OH
    210PS is awesome!!
    However CR in piston ported 2 cycles is a lot harder to determine do to scavenge loss and because the cylinder is feed fuel from the crank case. If the saw really had 12:5/1 CR pump fuel wouldn't work, let alone 89 octane. The trapped or Corrected method, is most commonly used to determine CR in these engines, and even then the numbers aren't perfect. 210PS in a piston ported saw is still well under 10:1 as most stock saws with 150/160 PS of compression are around 6:8:1
  13. CoreyB
    CoreyB
    South east iowa
    I would like to get the compression of mine since it has broken in. I can even tell a difference in the pull of the rope even with the easy start. But don't worry my 7 year old can still start it for me. Lol
    Andyshine77 likes this.
  14. CoreyB
    CoreyB
    South east iowa
    I tried to cause a vapor lock to day. Why?
    One I was curious.
    Two an excuse to run my saws.
    Three to make a video. Lol
    It was 91 degrees out I was running91 octane e-free fuel dolmar synthetic oil
    I noodled oak and removed the stump .
    I ran the saw hard and as lean as I am willing to go for 30 min. Killed the saw directly out of the cut and let it sit in the sun for 15 min.
    I understand that this situation can cause vapor lock and serious starting problems.
    As you can see it started right up though it did have a slight lean sounding hesitation for the first couple blips of the throttle.
    Great news I sweated off 10 pounds in 2 hours!
    Anyways enjoy
    DexterDay, Barcroftb, jerhurt and 4 others like this.
  15. MasterMech
    Now leave it in the black lined bed of a black pickup. I was boiling fuel in the tank when I popped the cap to check on mine! Once things calmed down, it ran fine.
    Barcroftb, CoreyB and Andyshine77 like this.
  16. CoreyB
    CoreyB
    South east iowa
    LOL that whooped me yesterday I am satisfied that my saws will probably never have a vapor lock. Working that much in that heat just zapped me. Lol
    Andyshine77, MasterMech and Barcroftb like this.
  17. Ronaldo
    Ronaldo
    Yea, the saws usually hold up their end better than I do in heat like that. I don't like runnin em when it's hot!!!
    Andyshine77, Barcroftb and CoreyB like this.
  18. CoreyB
    CoreyB
    South east iowa
    The wild and elusive 6100 in it's natural habitat. Lol making firewood out of stubborn oak trees.
    HDRock, Barcroftb, Ronaldo and 2 others like this.
  19. CoreyB
    CoreyB
    South east iowa
    Cutting some cookies.
    If it was a blue version you could name it cookie monster. Lol
  20. CoreyB
    CoreyB
    South east iowa
    Anybody want to watch the 6100 pull a 24" junk safety chain through a 20" + Hickory?
