Dolmar 6400
Discussion in 'Chainsaws and Power Equipment' started by J. Dirt, Oct 20, 2017.
  1. J. Dirt
    J. Dirt
    Didn’t time it but as far as the tach goes it seems to hold a bit better rpm under load and has a touch more trigger snap. I didn’t go nuts with the muffler so it’s not much louder than stock either just different tone. Watch the video of it back a few posts to compare. Same log same chain.
    Horkn, HDRock and Barcroftb like this.
  2. Barcroftb
    Barcroftb
    The Mitten
    Looks and sounds stronger. Bet the 4 stroke is easier to hear too!
    Horkn, J. Dirt and CoreyB like this.
  3. Jutt
    Jutt
    Bailey, CO
    Great saws. Check to see if you have green or black oil lines. The green is the old style that shrinks and then leaks and puts less oil on the bar. Nate can hook you up with the updated lines.
    OEM 7900 top end with HD filter are good additions as already mentioned. Mine, running that same config, has been rock solid for 6 yrs now.
    Horkn, BuckthornBonnie and J. Dirt like this.
  4. J. Dirt
    J. Dirt
    Thanks for the oil line tip I will check on that! :handshake:
    Horkn likes this.
  5. Barcroftb
    Barcroftb
    The Mitten
    The HD filter can drop rpm and power. It's not the filter that restricts airflow but the sharp turn in the new intake that is required along with the HD filter.
    J. Dirt and huskihl like this.
  6. Horkn
    Is there a way to mod that bend a little to ease this restriction, or would you say the standard filter is better for power?
    J. Dirt, huskihl and Barcroftb like this.
  7. Barcroftb
    Barcroftb
    The Mitten
    I don't think anyone has come up with a work around for it. Of the two stock choices the standard filter makes moar powah.:dex:
    J. Dirt, huskihl and Horkn like this.
  8. Horkn
    Hmm. I think I'll need to get the HD filter for my 6421 and take a gander. I've been known to wield a Dremel and do plastic/rubber modifying. :dremel:
  9. J. Dirt
    J. Dirt
    What’s the big benefit to the HD filter set up? Just a better filter than the little plastic loose fitting screen one?
    Horkn likes this.
  10. Horkn
    From Bailey's.
    "Heavy duty air filter kit from Dolmar. This kit greatly increases the filter surface area, which gives the saw better air flow and longer runs between filter cleaning. Fits the following chainsaws:"
    But if there's a restriction, how's that helping?
    J. Dirt likes this.
  11. Barcroftb
    Barcroftb
    The Mitten
    The HD filter is gooder for the fines you'd typically run into with seasoned hard wood cutting and cutting with a dull chain. I've had my 7910 for a couple years now and never really saw the justification for the loss of power with the HD set up. I'd cut with it awhile and see if you are noticing a lot of fines getting past the stock filter and go from there.
    Nixon, J. Dirt and Horkn like this.
