Do you dry wood in IBC totes?
Discussion in 'The Wood Pile' started by williaty, Dec 29, 2015.
  1. williaty
    williaty
    Knox County, Ohio
    I’m going to start using IBC tote frames to hold my firewood while it dries. I know some of you dry your wood this way because I’ve seen pictures, so I want to benefit from your experience.
    1) Do you stack the wood properly or just jumble it in as you throw it off the splitter?
    2) With however you do it, how long does it take to get most wood under 20% MC (in other words, is it as fast as stacking it in rows)?
    3) If you stack, how tightly do you fill the tote? I’m cutting at 15” long, which technically gives me 3 rows fitting in an IBC frame. However, they’d be pretty much end-to-end in there. 2 rows would leave a >10” airspace between the rows, which might aid drying.
    Is there anything else I should think about?
  2. Eric VW
  3. jtaves85mcss
    jtaves85mcss
    SW Ohio
    Chvymn99 likes this.
  4. williaty
    williaty
    Knox County, Ohio
  5. yooperdave
    Sure limits the amount of air flow once the wood goes in them, no?
    But then if you load and cover it and place it in full sun, there is always that solar kiln thing working for you.
    Chvymn99, Eric VW and NH mountain man like this.
  6. Eric VW
    My thoughts, too. Go Dave!
  7. Nitrodave
    Nitrodave
    Grayling Mi.
    Mine are stacked in.. The same as double row. I fill right from the splitter. I can then move them to prime seasoning area in the summer with the tractor. So far I have had no problems. We handle the wood way less this way.
  8. wfournier
    wfournier
    Western MA
    I was looking into doing that but I can't find em for reasonable prices in this area so so far it's a no go.
