Diesel truck discussion
  1. Brian Foster
    Brian Foster
    Streetsboro, OH
    LMFAO...I'm on page...evergreen is my route to sammys
  2. ironpony
    ironpony
    Mid Ohio
    going and look at one today with a 3500 with a utility body on it.................cheap nobody wants a V10
  3. CoachSchaller
    CoachSchaller
    Southeast Michigan
    I have been looking at ECODiesel Ram 1500. I want the bigger cab and a short bed is fine... I will be using it as a family wagon!!! I will use my 98 Ram Cummins or my 03 Silverado 3500 4 door dually (it is a boat)
  4. bang
    bang
    South central Indiana
    I'm pushing half a million on my 03 7.3. I pulled campers, mostly heavy 5th wheels, for about half of those miles and it has been very reliable. I installed new injectors last August and I need to rebuild the turbo but it still pulls strong and doesn't burn oil.
    94BULLITT, Horkn, huskihl and 6 others like this.
  5. boettg33
    boettg33
    Wakefield, RI
    Please join the conversation and dispel the wrongs. I've already been corrected. Which I appreciate. Knowledge is power.
  6. JustWood
    JustWood Guest
    I can't get by with Less!! (Trucks are $ makers for me)
    Just took delivery of this today ,,,, going on the Kodiak behind it in the next few weeks.
    I've owned 2 early 90's 7.3s and a 5.9.
    This is my first Duramax.
    Very impressed with power and mileage in a truck this size.
    94BULLITT, bang, TurboDiesel and 6 others like this.
  7. Rope
    Rope
    Alaska
    How long is that box truck? What is the mileage your getting?
  8. lukem
  9. JustWood
    JustWood Guest
    16'
    12ish MPG running around rural roads.
    I haven't had it in town or interstate yet.
    Got a deal on it this last summer so I bought it to put together this winter during our slow time. I've only run a few tanks through it . I get that 4000lb wind sail off it and mileage should increase .
    OhioStihl, TurboDiesel, Horkn and 4 others like this.
  10. Rope
    Rope
    Alaska
    12mpg is respectable considering what it is. That 4500 will get some work done.
  11. MasterMech
    It was always about MPG. Just like the diesels of yesteryear. The old IDI’s and Detroit 6.2/6.5 engines were never meant to be the highway combat superiority option. They were durable, and reasonably capable engines meant to go in trucks that got a ton of miles put on them. If you had big campers/trailers to tow, that’s what the big block gassers were for. But we all know the MPG story there.
    Hence the confusion, diesels have shifted roles from being the bean-counter’s engine, to being the premium option for capability. That shift began with the introduction of he PowerStroke 7.3L in 1995 and was in full swing by the time the DMax was introduced in 2001. Folks expecting a diesel half-ton to dominate on performance, durability AND mpg (which is exactly what was being offered on HD pickups form 2001-2007) have been disappointed with every offering.
  12. 94BULLITT
    94BULLITT
    Frederick County, VA
    This is slightly off topic but this would be a good thread to share it in since all the diesel truck owners are here. I wanted to share this deal with you.
    I did a video on my YT about the Meross MSS620 outdoor wifi smart plug. I use this to control the block heater on my truck.
    Meross gave me a 30% off coupon code for it, making it under $20, which is a great deal for an outdoor wifi smart plug.
    Link to Amazon (not an affiliate link so I don't make $$$ from it)
    https://amzn.to/2D7v7V4
    30% off Coupon Code
    FMA7E6VH
    Here is my video that explains it.
  13. JustWood
    JustWood Guest
    10 Amp may not be enough for some block heaters.
    Mines on a 20 amp and it'll kick the breaker sometimes when there's other stuff on that circuit.I think that's aimed more at outdoor lights.
  14. amateur cutter
    My block heater wouldn't run on a 10amp circuit either. Those things draw quite a bit. I had it on a 14ga cord & went to 12ga. It smoked the contacts over time. Cool product though.
  15. lukem
    Could always wire that device into a relay to run a heavier load.
  16. brenndatomu
    Yup, block heaters are notorious for burning up cords, etc.
    I bought a set of injectors from a guy that was parting out his 7.3 PS after it burnt up...had it all serviced and loaded up to tow their 5th wheel camper to Florida for family vacation the next morning...woke up in the middle of the night to find the truck was on fire...they determined the block heater burnt up! :hair:
  17. JustWood
    JustWood Guest
    They use the lightest cord on those. Extension cords have heavier insulation/wire .I've seen many wore through and shorted out on motor or frame.
  18. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Stuck with my 01 F250 V10, 230K and 9' bed.:picard::headbang:
  19. 94BULLITT
    94BULLITT
    We just did a block heater in a New Holland tractor. It was a 400 or 500 watt heater. The factory block heater in a powerstroke is 1000 watts or less depending on the engine. Watts/volts=amps. 1000/120=9amps. There are some aftermarket block heaters I have seen for powerstrokes as high as 1500 watts which would be a no go. If your block heater is burning up cords or tripping breakers, you have a bad block heater, block heater cord, or bad breaker(only if it is tripping the breaker). A GFCI breaker can be overly sensitive sometimes. I read something the other day about some brand of GFCI breakers that are not but I don't recall the name. It was not something you can get in a box store.
  20. ironpony
    ironpony
    Mid Ohio
