Diesel truck discussion
  1. MasterMech
    Stuff is miles (literally) better than anything the OEM's are putting in a late-model trans. I've been running the low-visc formula in the Honda van and it made a surprisingly noticeable difference.
    brenndatomu, Eggshooterist and Horkn like this.
  2. Eggshooterist
    Eggshooterist
    Erff
    I've been kicking around putting their CVT fluid in or HRV in hopes it will help it last. Zero issues so far with Honda fluid and just north of 60,000 miles. It was changed at 36,000 and we plan on continuing with a 30,000 change interval going forward. Even if we make it 200,000 without issues I'll never by another just because I trust a manual or traditional automatic more.
    Horkn, James Miller and brenndatomu like this.
  3. chris
    chris
    SE WI
    CVT been around a long time, but newer applications being used now are a bit wet behind the ears. fail rate , i do not think is any better or worse than more conventional items being used.
  4. Eggshooterist
    Eggshooterist
    Erff
    That's my hope.
    Horkn likes this.
  5. Horkn
    Just don't tow anything with it, you might be ok.
    Eggshooterist likes this.
  6. Eggshooterist
    Eggshooterist
    Erff
    Definitely will not. No hitch on it but if we do put one on it will be for a bike rack only.
    Haftacut and Horkn like this.
  7. Prospector
    Prospector
    Mississippi
    Old thread- I know. Been there/ done that. In 2018 I sold my last diesel. Good truck- had not spent a significant amt on it in 135k. But. In light of my perceived (and IMHO…) lack of reliability in more modern diesel engines I took a hard look at my needs… and bought a 2016 F250 gas-6.2/6R140/3.73:1. Started at 22k/ now at 134k. Flawless. Do I occasionally miss diesel torque? Sure. Is it that big a deal? Nope. I’m a numbers guy. Same truck with a diesel and an estimated $7500 price increase? Saves me $16 a month in gas/fuel. According to my uses, if I encounter NO diesel expensive repairs (…right…) it will take approximately 46 years to break even. Also the real mpg of diesel is when you are cruising . I got no better mpg with my diesels low speeding it around neighborhoods, hunting leases etc. In fact, you probably won’t notice a significant difference in the lower gears “starting “ a load moving. If I miss my diesel it is when I’m at 65mph with a significant load maintaining speed on elevation- the gasser requires more driver input. Otherwise I’m personally happy. I would not look over a 6.2 to buy an older, higher mileage 7.3… it’s iconic/ it’s a great engine. BUT. Stock against stock? The more advanced frame, drivetrain, and tranny of my truck is rated to haul and tow just as much (more) as the older F250 and will more than keep up.
  8. isaaccarlson
    isaaccarlson
    Colfax, WI
    I like the older stuff because you can fix it when you need to. Everything breaks down some time, and the easier and cheaper it is to fix, the better. Inlines are super easy to work on. We put a new head gasket in my truck for less than $100 last year. It failed because the previous owner broke a head bolt 14 years prior. Can't touch that with anything new.
    I'm not in a hurry, and I don't need fancy gizmo's to get there. Diesel is for highway towing with heavy or high drag trailers. I am happy with gas, especially when it's -30 outside.
  9. chris
    chris
    SE WI
    I do not need 30K of gadetry making a truck somewhere past 60K, even with what I have put into my diesel over 276 + miles I am still way ahead of anything new or lightly used in todays market. No matter what I still need a 3/4 ton or better truck. Sooner or later my 04 is going to bite the dust, being in the rust belt likely sooner. All of the newer stuff have nasty pricy problems that are not common to normal everyday use. 80% center around emissions and electronic failures no fault of owner. another 15% are mfg engineering faults point blank.
  10. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    21 on the right. 24 350 Lariat Tremor with High output 6.7 on the left IMG_3100.jpeg
    eatonpcat and brenndatomu like this.
  11. FarmerJ
    FarmerJ
    Minnesota
    Do you REALLY need a 3/4 ton?
    or would a properly spec’d 1/2 ton work?
    at 2551 lb payload, I’d be hard pressed to go back to a 3/4 ton unless it was truly a business need. And then I’d go straight to the ford F450 because of a better turning radius and brakes.
  12. chris
    chris
    SE WI
    I/2Ton with a 5 ton trailer full load gets a bit dicy . Then there are the brakes themselves on a 1/2t vs the 3/4 or 1 ton. same for axels. F450 are dualls unless you super single it, No experience with that conversion though. Registration here gets pricey as you move up the line. I found the 1/2t to be lacking when hauling full load, 3/4 for my needs works ok. and I have had 1 tons in the past.
  13. FarmerJ
    FarmerJ
    Minnesota
    only time I find it gets dicey is when the trailer brakes start needing to be adjusted. And by then, it's long past where it should have been done.
    Bigadbob and brenndatomu like this.
  14. MasterMech
    All of my trailers with electric brakes got converted to self-adjusters whenever and as soon as possible. Makes a huge difference and one less variable when the chit hits the fan.
    Bigadbob, FarmerJ and brenndatomu like this.
  15. Eggshooterist
    Eggshooterist
    Erff
    Are they as reliable as standard? I was going to put those on our camper and the place talked me out of them. He said they wear out way faster. Not sure how but I opted for manual adjust being my first trailer with brakes.
  16. lukem
    After two of my buddies had their CP4s detonate, take the rest of the fuel sytem with it, and leave each of them with a $12K repair bill, I don't think I could buy a diesel if it didn't have a 15K+ lb trailer behind it 75% of the time.
    I still think a gas 7.3 with a 3L Whipple or big Procharger would make plenty of torque and sound awesome doing it.
    eatonpcat, rdust, Bigadbob and 3 others like this.
  17. brenndatomu
    This, X 1000!
    That's exactly what I used to tell our customers when they come in looking for "a turbo diesel so I can tow"...turns out most of the time it was just a camper, or horse trailer, 1-2x/year, and often not very far either.
    eatonpcat, Bigadbob and Eggshooterist like this.
  18. FarmerJ
    FarmerJ
    Minnesota
    That’s my plan too after the bearing issue last spring.
    eatonpcat and Bigadbob like this.
  19. rdust
    rdust
    SE, Michigan
    Convert it to a CP3 and never worry about it, but I certainly get it.
    I spent 3 months this summer rebuilding my 2004 2500hd. “New” rust free cab/frame, suspension/steering, fuel lines, brake lines, power steering lines, hoses, water pump, glow plugs etc….Lots of work but worth it with price of new diesels.
  20. FarmerJ
    FarmerJ
    Minnesota
    I was looking at doing that to my 2500 ram and decided to just buy my F150 for close to the same amount of money.
