Diesel truck discussion
  1. brenndatomu
    You can rent those?! :eek:
    Oh the hours I've wasted! :hair:
    Stephiedoll, fuelrod and Horkn like this.
  2. Horkn
    They're almost always rented out and on a different job.
    Stuff is really easy to get at before the body is mounted on the chassis, or before the engine is bolted into the chassis.
    Stephiedoll, fuelrod and brenndatomu like this.
  3. brenndatomu
    Yup, when I heard Ford made it so that many things would require the body to be removed to access things, I thought someone fell and bumped their head, but then when I seen the first one actually removed I was like wow, everything is easy now! Yeah it takes a bit of time to get to that point, but not too bad really
  4. James Miller
    James Miller
    Hanover PA
    Mine will spin on the 1-2 also, found out when the transmission builder asked if I wanted to go along for a test ride.
    Still wish my truck was a zf6.
    Horkn likes this.
  5. fuelrod
    fuelrod
    Western Maine
    Myself and everyone that I knew that towed with that combination (7.3/slushbox o/d)
    Had multiple failures. Maybe it's nice and flat where corncobs running.
    Btw, the Amzoil a/t juice alone cut 40* off the transmission temps and that's a meaningful number.
  6. Warner
    Warner
    100% once you take a couple cabs off you will never want to work hunched over the radiator again!
    Horkn, brenndatomu and fuelrod like this.
  7. In the Pines
    In the Pines
    You lost me when you called amsoil snake oil. I disagree with the hydrualics as well.
    Issues with firewall flex on the 80-86's that cause issues with the slave but that isn't the clutchs problem.
    Fix it right the first time. Like they say fix or repair daily.
    To add on the cab lifting comment-
    How many backyard guys have the ability to lift a cab? No they made it so you have to take it to a dealer. Not that a backyard guy couldn't do it.
    Horkn, brenndatomu and Eggshooterist like this.
  8. Warner
    Warner
    Correct. These truck require expensive diagnostic tools as well as “special” tools to preform many repairs.
    Most modern vehicles are out of backyard guys league except for suspension, tires, brakes etc. I certainly don’t want Joe 6 pack working on my 80$k vehicle.
  9. fuelrod
    fuelrod
    Western Maine
    :thumbs: I don't want an $80k vehicle... unless it's got 3 axles and can pay for itself !
    It's just foolish "out there".
    Warner with the cab removal, I'm guessing that Ford has provisions like wiring and easy mechanical disconnections for steering and brakes and sheet metal and as bizarre as it sounds (for 20 years ago vehicles) I can see it's advantages.
    How long does it take to roll the chassis out from under the cab?
    Horkn, brenndatomu and Warner like this.
  10. Warner
    Warner
    Yeah I could go through it all but it’s pretty straight forward steeing shaft, disconnect master cyl without opening the system, drain coolant disconnect hoses body bolts and a few electrical connectors. after you do it a couple times a week it’s no prob. Hustling I could have a cab off of a super duty in a couple hours. The only thing a fella with a lift couldn’t do properly is evacuate and recharge the a/c system.
    It got to the point I’d take the cab of f150’s to do engine repairs. Some of the younger guys didn’t mind leaning on the radiator reaching. It was worth the time to me so that I didn’t have to spend hours in that uncomfortable position when the job books 15-20 hours.
  11. In the Pines
    In the Pines
    Why you think those parts swappers working in the stealerships actually know what they are doing?
    they plug their diagnostic computer in, read the code and replace the part.
    Finding a guy who can actually understands millivolts, grounds and how stuff cascades is a rare bird these days.
    I don't even trust my 86 truck (or any other vehicle) with mechanics, they can't even get simple stuff right that requires no electric knowledge.
  12. Warner
    Warner
    Some do but you are correct most don’t.
    This is a common misconception. Especially with multiplex networking. You need to look at the code and figure out if it’s a wiring, programming, hard part or results of some other system not working. Modern vehicles rely on module communication and a network of circuits for the information to pass on. One small corroded wire can take down a network and pretty much brick your vehicle.
    There are good people that work at dealerships but a lot of times the politics of said dealship steer the experience.
    there are also many uneducated and worse thieves in that realm.
  13. In the Pines
    In the Pines
    You didn't quote the part where I stated understanding millivolts and cascading failures. aka multiplex networking canbus etc.
    I try to keep it simple but maybe that was too simple of a response.... or not enough buzzwords
    Horkn, Warner and brenndatomu like this.
  14. Warner
    Warner
    Well in the 20 year stint I did at a stealership I never heard the term “cascading failures” so I apologize.
  15. fuelrod
    fuelrod
    Western Maine
    I kinda like it when it only took gas, air and a spark.:rofl: :lol:
  16. Warner
    Warner
    Yup, the new stuff is cool when it works….
  17. fuelrod
    fuelrod
    Western Maine
    It is, and more efficient and powerful. The days of junking Detroit iron @ 100k is way in the past. :thumbs:
    Just too much "fluff" that can go bad and leave you on the side of the road. Parts you don't have never need attention or repaced.
  18. Warner
    Warner
    100%
    brenndatomu likes this.
  19. Horkn
    I'm tall and even getting over the radiator on my f150 isn't easy. I'm about to take that air dam off mine because it's in my way. It will get easier to get to a lot of things with that air dam out of the way. I hear it's good for freeway mpg, but I'm not doing any long road trips any time soon and I suppose it will go on and off easily.
  20. James Miller
    James Miller
    Hanover PA
    I've been ask many times why I drive a 20 year old 1 ton every day. Honestly I can't afford a second vehicle. But it's also much cheaper the truck payments on a modern truck with the same capability and I can work on it myself. Hopefully in the near future I'll be able to pick up a ranger for a daily beater.
    Horkn, Stephiedoll, fox9988 and 2 others like this.
