Diesel truck discussion
  1. ironpony
    ironpony
    Mid Ohio
    Longer stroke = more torque
    Hence Cummins wins hands down.
    amateur cutter, mat60 and Ohio like this.
  2. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Ok all you Ford diesel guys, I gotta question-
    My 2002 F-250, 7.3 does a "thing" when warming up. Some people say it's probably "this" or "that", but most say it's a new one for them.
    Note it has straight through exhaust that splits to become dual, so it's got a unique exhaust note.
    When warming up, it will kick up a few hundred RPM (1100) and something opens/closes so the exhaust sounds like a jet. A quick blip on the throttle will return it to normal idle, but it will do it again. What is causing that?
  3. brenndatomu
    The 7.3 PS has a valve (EBPV) on the exhaust that closes to cause back pressure, which helps things warm up faster...and yes, it will idle up and make "turbo noises" during...and when its real cold out you will not even have control of the engine speed with the throttle pedal until the engine warms for a minute....
  4. Beetle-Kill
    Beetle-Kill
    Thank you. As long as it's supposed to do that I'm good. Gotta ask, my first diesel and all.
  5. 94BULLITT
    94BULLITT
    Frederick County, VA
    This truck was a rental truck. I am wondering if the PCM had a special calibration since it was a rental truck that makes it a dog.
    mat60, amateur cutter and brenndatomu like this.
  6. brenndatomu
    I bet it did...
    mat60 and amateur cutter like this.
  7. 94BULLITT
    94BULLITT
    They also have a low compression diesel.
  8. Redfin
    Redfin
    central Pa
    We have numerous 6.4 hemi dodges in our fleet at work. Detunned is an understatement.
    We also have several 6.2L, 13.5k laiden and they perform as expected. Great engines.
  9. 94BULLITT
    94BULLITT
    Maybe the manufactures have a special calibration for a fleet trucks. I know a guy that works for the phone company and his truck Ram 4500 with a cummins. He said it is dead taking off, almost to the point of dangerous but once it is up and moving it is fine. I think the torque management is too sensitive.
  10. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Cab & chassis usually comes with a different computer program with lower power too I believe
  11. Mwalsh9152
    Mwalsh9152
    Pelham NH
    You can wire a switch in to close that ebpv as an exhaust brake too.
  12. Beetle-Kill
    Beetle-Kill
    Sounds intriguing. I wouldn't mind having that if I could operate it manually.
  13. Mwalsh9152
    Mwalsh9152
    Pelham NH
    You can, just an on off rocker switch. I used to have one on a wrecker, and my roommate had one on his service truck.
  14. amateur cutter
    '96 7.3 PS setup the same way?
    Beetle-Kill, brenndatomu and mat60 like this.
  15. Mwalsh9152
    Mwalsh9152
    Pelham NH
    No, the first year that had it was 1999
  16. brenndatomu
    amateur cutter and Beetle-Kill like this.
  17. Mwalsh9152
    Mwalsh9152
    Pelham NH
  18. wildwest
    Hi guys, I'm toying with the idea of getting a gas vehicle that warms up faster. Idk, budget and goals say otherwise but I am quite tired of my iceberg Duramax and I have a bit of damage starting to show on my fingers and toes. I'd jump back into the Blazer but it's really falling apart. The BEST heater if have ever driven was the 99' F250, it rocked!! ,except that defeats the gas engine warming up faster. My Dodge Colt vista wagon was nice and warm too, extra vent below steering column that helped alot. Thinking outloud, thanks.
  19. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I hear you on the warm up! That is one of my number one reasons I'll never buy another diesel at this point.
    What about putting a remote start in the truck?
    wildwest and amateur cutter like this.
  20. brenndatomu
    Ever try one of those auxiliary heaters that plug into the cig lighter?
    amateur cutter and wildwest like this.
