Diesel truck discussion
  1. brenndatomu
    [​IMG] [​IMG]
  2. TurboDiesel
    I always loved that show! lol
  3. brenndatomu
    Yup, even without cable, it is still on one of the rerun channels a lot...and way better than watching some/most of the "current" stuff that is on!
  4. fuelrod
    fuelrod
    Western Maine
    It wouldn't be long before you'd need a new drive train:rofl: :lol:
  5. brenndatomu
    Dodge (Ram) doesn't need any help with that...:whistle:
  6. fuelrod
    fuelrod
    Western Maine
    I know the a/t's in the last few 7.3 years would turn into a pile of shavings.
    amateur cutter and Brandon Scott like this.
  7. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    Well they would at least pull a greased string out of a cat’s azz...
    amateur cutter and brenndatomu like this.
  8. brenndatomu
    That's about it though! ;) :p
    And BTW...ewww! :rofl: :lol:
  9. Redfin
    Redfin
    central Pa
    $2.99 diesel as of late. Havent seen that in years.
  10. AJtree88
    AJtree88
    damm, you’re close to me. I live on Frost north of 82.
  11. 94BULLITT
    94BULLITT
    Frederick County, VA
    It is $2.63 here. I saw gas for $1.85 today.
  12. Ou812
    Ou812
    Eastern ct
    :bug:
  13. TurboDiesel
    76.6 cents gas tax here.
    Thanks to Fat Eddy....:mad:
  14. Mwalsh9152
    Mwalsh9152
    Pelham NH
    2.89-2.99 for diesel here
  15. Ou812
    Ou812
    Eastern ct
    Last time I bought diesel I paid 3.15
  16. MasterMech
    This was taken just before Christmas and was the case until about a week ago. We’re back up to about $1.89 on gas now.
  17. 94BULLITT
    94BULLITT
    I filled up today. It was down to $2.63.
  18. Redfin
    Redfin
    central Pa
    No gelled fuel filters to write about last week? Ya’ll on point.
  19. chris
    chris
    SE WI
    $2.07 fuel, no problems with the cold - warms up add 1/2 tank of fuel to what was there - drive 40 miles - dead eng. water in fuel light on and check eng light. Right at the end of the off ramp getting off the freeway. I do not know if the water in fuel circuit will disable the eng. Figures I was going to do oil, filters, water separator Sat. I have not found anything definitive in that respect either, or weather it would toss a code as well. It's at the diesel shop so get the Bad? news later today. Last time it pulled this no run stunt is was the hpop unit $$$$. My friend from up north called yesterday as his had died in the cold-- Hpop went out on his 6.4. I was 6 miles from home he was 5. His hpop basically imploded so besides the hpop he will need a full set of injectors- new ones are apx $255 ea. remanf. are less but kinda questionable. passages in these injectors are so small it is almost impossible to get all the sparkles out ( metal fines) not like the ones in the over the road trucks.
  20. lukem
    Ford is bringing back the 7.3 at the end of the year....except it is a gas motor. Big pushrod NA V8. Could be a good, much less expensive option, for those that need the extra juice every once in a while.
