Did a little cutting today
Discussion in 'The Wood Pile' started by rdust, Dec 14, 2013.
  1. rdust
    rdust
    SE, Michigan
    I've had this small double ash on the ground since the summer of 2011. It was standing dead near the power line so I had the line crew put it down when they were clearing near the lines. I tried to get it taken care of the last 2 winters which never happened so I made sure it got done this year. I cut one trunk last weekend and cut the other one today. Should be around a 1/3 of a cord all said and done.
    Last weekend.
    Finished up today.
  2. raybonz
    raybonz Moderator
    Carver, Mass.
    Very nice rdust you should be good for 10 years with a BK.. :cool:
    milleo and TurboDiesel like this.
  3. Locust Post
    Lookin good rdust....I almost went out late morning because I was doubting we were going to get the snow they predicted. Sure glad now I didn't because it was coming hard and fast a while ago.
    Backwoods Savage and raybonz like this.
  4. bogydave
    That's a great looking stack of rounds.
    The tree next to it looks bigger , :)
    you know it'll start seasoning when it's split & stacked , right ? ;) LOL
    Looks like splitting it may have to wait till Spring,
    your weather turned to winter early this year .
  5. Backwoods Savage
    Good that you got that rdust. It will burn really good too.
  6. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    The rounds look great for two years on the ground. I have some Ash that's going to be on the ground for over a year. I hope it's ok.:axe:
  7. raybonz
    raybonz Moderator
    Carver, Mass.
    Hmm not too many woods can tolerate ground moisture.. I got a couple cords of black locust that had been on the ground for decades and was totally bark free with no rot and bone dry but that is the exception rather than the rule..
    Good Luck!
    Ray
  8. bogydave
    Locust was/is the wood of choice for fence posts for that exact reason.
    Driving nails & staples into it was the difficult part :)
  9. raybonz
    raybonz Moderator
    Carver, Mass.
    I've heard they used locust for pier pilings too and for good reason..
    Ray
  10. rdust
    rdust
    SE, Michigan
    Both are show in the stack, neither were big I think the bigger one was maybe 14-15 inches at the base. I'll get it split before spring I like splitting in the winter. :)
    They're pretty much perfect, they were on rocks so very little direct ground contact.
    raybonz likes this.
  11. bogydave
    Sure is a nice clean looking fire wood.
    Good clean place to cut, just don't nick a rock
    Footing not good either.
    Some distance to hand carrying to the trailer?
    If it was easy, everyone would do it. :)
  12. rdust
    rdust
    SE, Michigan
    Pretty straight stuff, it should split nice. Footing stinks due to the rocks and a bunch of vines took over since I let them lay for so long. I did tag a rock that I didn't see due to the snow but it didn't screw anything up too bad, I'll run the file over it before I cut again. My properly isn't big,(3 acres) and I can pretty much drive up to where I cut. It might be a 30-40' carry but far from bad.
  13. Backwoods Savage
    But good news! Ash probably will last longer than most any other wood even when it is touching the ground. We've picked up lots of stuff that we've cut years before and some of it sat in water for a good length of time every year. Seems that happens around here; cut a tree and take some out but not enough for another load so thing about getting it later....then forget all about it. Senior moments?
    raybonz likes this.
  14. Well Seasoned
    Looking awesome bro!
