Cylinder Clean-up for FHC
Discussion in 'Chainsaws and Power Equipment' started by BuckthornBonnie, Jan 18, 2014.
  1. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    I have used all the above methods. For me it depends on what thecustomer wants within his:her budget. With acid a little heat helps. With Wiggs method, a little too much pressure and you will blow it.
  2. MasterMech
    Most cylinders I've tried to restore have some kind of defect under the plating that causes acid to ruin the jug. The acid begins to eat the aluminum behind the plating creating a weak spot where the plating could chip and do more damage.
    I like the Wiggs method. :)
  3. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    If only mild aluminum transfer I dilute the acid with water then Wiggs, if carbon tracking I use Wiggs method. If there are visable defects like flaking around ports and such cylinder gets replaced.
  4. cnice_37
    cnice_37
    This is for my cleanup on the 038 with the (presumed) sheared flywheel key.
    HD did not have anything from what I saw in this area. I'm going to try and auto store if my dad's body shop doesn't have anything besides the green stuff.
  5. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Courtesy of Al Smith Here are the order numbers from McMaster Carr for the holders for scotch brite!
    Aha and so it is ."Disc holder " Mac master -Carr number
    46325A92 2" ---46325A91 1.5"
