Creosote Sweeping Log: Chimney Fire Waiting to Happen
Discussion in 'Modern EPA Stoves and Fireplaces' started by Grizzly Adam, Dec 18, 2013.
  1. Grizzly Adam
    Grizzly Adam Guest
    Less than perfect wood last year too, put the stove in last November.
    wildwest likes this.
  2. milleo
    milleo
    Maine
    Check it once a month till you are happy with what you see....Then still check often just in case...:)
    wildwest and Grizzly Adam like this.
  3. fox9988
    fox9988
    NW Arkansas 72717
    Did you run the "little" Lopi harder than the King? Maybe thats why you had better results from the Lopi, hotter chimney gases. How do the Lopi and the King emissions compare?
  4. clemsonfor
    When I first got my stove I would check the chimney. With the cat it was always just powder up top I was happy. Last year I did not really check. Looked and could tell it was building up. And was getting smoke. Anyway cat failed early last year. Chimney was 80% blocked
  5. milleo
    milleo
    Maine
    :eek:
  6. clemsonfor
    I meant to have that face at the end but forgot!!!
    Yea was bad I had not been up there the last month or two of burning. It got bad fast!
    wildwest and milleo like this.
  7. concretegrazer
    concretegrazer
    Southwest MO
    I wonder if its due to there being less junk in the gases to gunk up the the?
  8. Grizzly Adam
    Grizzly Adam Guest
    That's what I am thinking, more of it gets burnt so it doesn't make it to the chimney in the first place.
  9. clemsonfor
    Wouldn't that be works better on less efficient stoves for the reason cited? More smoke up chimney so it would work better?
  10. concretegrazer
    concretegrazer
    Southwest MO
    More crud in the gasses on a dragon= more crud left in the flue.
  11. clemsonfor
    Yea I got that so more of the CSL would make it to the chimney to work right?
  12. Grizzly Adam
    Grizzly Adam Guest
    One things for sure-- the reclaimer was hurting my draft.
