Crazy Idea? Please weigh in.
Discussion in 'Chainsaws and Power Equipment' started by RCBS, May 1, 2023.
  1. Eggshooterist
    Eggshooterist
    Erff
    I know this is a cost savings idea you proposed but, you could pull a sample of the udt and have a lab tell you the real story on its further usability. Not only in the tractor but if you still wanted to drain at the recommended hours, the usefulness of the used oil in other applications.
  2. Eggshooterist
    Eggshooterist
    Erff
    Black stone labs and Oil Analysers are both reputable.
  3. FarmerJ
    FarmerJ
    Minnesota
    I use the caterpillar S.O.S. Program on all my equipment. Get the sample bottles from a local cat dealer parts counter
  4. MAF143
    MAF143
    North Central OH
    WOW, you guys are making me feel bad. I don't think I've ever changed the hydro oil in my splitter... I'm pretty sure that my brother who I got it from doesn't even know that there's oil involved... He had it at least 10 years and I've had it 12 or so...
    :whistle:
    :emb:
    I guess I better get out my tool and get to the lube store...
  5. huskihl
    huskihl
    Even drained from a tractor, UDT is likely way better oil than what’s in the splitter
  6. Mrxlh
    Mrxlh
    Dat Boot
    Sample it, if still good, polish it through a 25 sand 5 micron filter.
  7. RCBS
    RCBS
    Over here
    Excellent idea!
  8. RCBS
    RCBS
    Over here
    This is kinda what I'm getting at. The used stuff I'm tossing is likely higher quality than the stuff I got for $25/5gal, which is now $38/5gal.
  9. Chud
    Chud
    NC
    That sounds cheap. My splitter has a 20gal tank and the cheapest I could get at TSC was 5gal for $50. As usual the cheapest fluid was sold out.
  10. RCBS
    RCBS
    Over here
    It's CAM2 stuff. I think I bought it in 2017? Menards. Rural King showing at $38.
  11. Jeffrey Svoboda
    Jeffrey Svoboda
    The real question is if you should use it as bar and chain oil. :cool::rofl: :lol::rofl: :lol:
  12. RCBS
    RCBS
    Over here
    How's about used splitter oil in the saw?
  13. Jeffrey Svoboda
    Jeffrey Svoboda
    Well now you're just trying to make someone mad. :handshake::rofl: :lol:
  14. Eggshooterist
    Eggshooterist
    Erff
    Some STP or Lucas oil stabilizer might make it usable. :D
  15. Eggshooterist
    Eggshooterist
    Erff
  16. Forest dweller
    Forest dweller
    Mi.
    Well on the subject of hydraulic oil. I have a splitter and tractor and when the splitter won't push through a narly piece I have the splitter setup so I can hook the lines to tractor and use it it will then split what ever is needed, No hesitation. So yes the fluid will work just fine in the splitter. Just my 2 cents. No change needed. Best to all. Keep on hoarding.
    Forest Dweller
    amateur cutter, Chud and Screwloose like this.
  17. brenndatomu
    I thought about that too...but isn't oil testing getting pretty pricey these days...I heard it was...
    amateur cutter and Eggshooterist like this.
  18. Screwloose
    Screwloose
    In days gone by i remember farmers kept all the drain oil for use in spraying equipment after they were done using it to prevent rust.
    Add just enough diesel so the pump sprayer could spray.
  19. Eggshooterist
    Eggshooterist
    Erff
    $30 +/-
  20. Eggshooterist
    Eggshooterist
    Erff
    The more important thing about oil analysis is it shows trends in your equipment. If your oil change intervals are perfect for years then you see an uptick in a wear metal, or fuel dilution, there is something happening in your engine that could / will be an issue in the future.
