Craftsman 4.2 tuning
Discussion in 'Chainsaws and Power Equipment' started by jjpeters4, Apr 15, 2021.
  1. jjpeters4
    jjpeters4
    When I bought this saw I noticed the low circuit was running so lean there was a real bad hesitation, it took 3ish turns out for proper response off the bottom end...I'm thinking theres an air leak somewhere...thoughts?
    Sent from my SM-G965U using Tapatalk
    M2theB likes this.
  2. amateur cutter
    Welcome to FHC! I think you're likely correct on the air leak. Check the intake boot from carb to cylinder for cracking etc. Also check the fuel lines for the same. Beyond that crank seal would be next & likely not worth doing on that saw.
    M2theB and buzz-saw like this.
  3. huskihl
    huskihl
    Air leak or most likely the diaphragms in the carb are stiff and not pumping enough fuel
    amateur cutter, Nixon and buzz-saw like this.
  4. buzz-saw
    buzz-saw
    Ct.
    Air leak or maybe a partially clogged passage in the carb. low side circuit ?
    amateur cutter likes this.
  5. jjpeters4
    jjpeters4
    Yep it's the low side, high side is good to go, low side is about around 3 turns out
