Corn Fuel Issues?
Discussion in 'Chainsaws and Power Equipment' started by Kimberly, Sep 5, 2016.
  1. blacksmith
    blacksmith
    central Pa
    Me personally I use aviation fuel. We have a Stihl dealer here in town that sells it or you can go out to the small airport and get it youself. I use it in all my small engines and never had any storage (never use stabil) problems with it. When I get it I put some Marvel Mystery oil in it (not sure if it work the same as stabil or not). And then mix with Amsoil 2 stroke as needed for my saws. I am not exactly sure what the octane is but it's higher than what you can get at the pump. The saws seem to run a better than with pump gas but you need to re-tune your carb.
    I have a Stihl ms661 (with the auto tune carb) and was having some problems with it not wanting to start after it ran out of gas. I took it to the dealer they dumped my gas out and put in regular pump gas in to do their tests. Long story short. It needed a new mixing fuel solenoid. When I got it back it had the pump gas still in it. It ran very sluggish! I ran the tank out and put the aviation gas in and the saw seemed to wake up a good bit! Coincidence I don't know? If anyone has any info on what I am saying is wrong please enlighten me!
  2. mdavlee
    mdavlee
    The mtronic takes a little while to get used to the fuel. It took almost a whole tank in the 550 auto tune to get it to run right when switching fuels with that big of an octane difference
    concretegrazer and blacksmith like this.
  3. blacksmith
    blacksmith
    central Pa
    Cool thanks for the info. But does it actually make it run better? It seems to for me even in my older saws! Or am I just imaging things?:faint::picard:;)
    concretegrazer and mdavlee like this.
  4. mdavlee
    mdavlee
    I've never got better performance from real high octane. Could be in your head or the fuel isn't that good where you're at.
  5. bushpilot
    bushpilot
    Eastern Washington
    There are lots of fables about high octane fuels.
    High octane does not mean higher energy, in fact in many cases the opposite is true. For example, 87 octane autogas contains 125,000 BTUs per gallon, avgas contains 120,200 BTUs per gallon, about 3% less. Or an extreme example, ethanol contains 84,600 BTUs per gallon, and an octane rating of 129! It's the highest octane of the bunch, but lowest fuel energy. Gasahol (10% ethanol) is about the same as avgas regarding BTUs.
    So why do some high performance engines use ethanol? They are built to run on the edge of detonation, with high compressions, blowers, etc. They are not designed to be useful daily engines. Without the high octane that the alcohol provides, they will destroy themselves in very fun ways to watch!
    Aircraft engines use avgas for safety, not for performance. Most of them run fine on e-free autogas.
    Back to the chainsaw - sssuming the saw is properly tuned ... you will get more power from ethanol-free mogas than avgas or gasahol, because of the higher BTUs. If the engine is not on the edge of detonation (which it shouldn't be), the lower octane fuel is often better and nearly always cheaper.
    Hinerman, Horkn, mike bayerl and 5 others like this.
  6. blacksmith
    blacksmith
    central Pa
    Thank you for the info I really appreciate it! I never knew that about the octane and the btu differences!
    Horkn likes this.
  7. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Wow, lots of incorrect information here.
    Spark plugs were all designed to run on leaded fuel. Spark plug technology hasn't changed in many years. Airplanes consume hundreds of gallons of fuel to get minor lead deposits on the plugs.
    Lead actually was added to gas to slow down the flame front in large bore, low reving (2,000 rpm max, due to prop tips going super sonic above that speed), aero engines, giving a longer power pulse. It also works to reduce detonation in the higher compression aircraft engines (not the ones that can use auto gas)
    Since I burn 10 or so gallons a season I'm really not worried.
    Besides, my saw plug is cheap, compared to $25+$ times 8 or 12 on an airplane.
    I like to put a new plug in each season.
    The old plug is never fouled by lead.
    Lead will not kill you, it really only is bad for growing kids.
    It is the best source of non ethanol fuel, and at free, can't be beat.
    I also run 100LL in my snow blowers, lawn mowers, splitter, generator, etc and never have issues with starting after sitting for a year or more.
    Besides, I think avgas with two cycle oil smells heavenly.
    blacksmith, Eric VW and Naturalgas like this.
  8. blacksmith
    blacksmith
    central Pa
    ??????????? I am not too sure what to think now?
    :emb::faint::picard::whistle:
  9. Scotty Overkill
    I like the stability of avgas.....but as blacksmith can attest to (because he cuts with me), I use 87 octane pump gas (with 10% ethanol) in my saws because I literally go through 25 to 35 gallons of mixed gas every year, between my sleds, snowmobiles, weed eaters and leaf blowers. The most economical place to buy Avgas here is an hour and half round trip. I do put it in my classic car every winter, because ethanol laden gas will draw moisture and "stale".....
    All of my vintage saws (that don't see action all the time) will be getting Avgas for the storage factor.....
    Horkn and blacksmith like this.
  10. MasterMech
    You will get opinions from a everywhere. I highly doubt your saw makes more power on avgas (what grade are you buying BTW?) than regular auto fuel. But such things are difficult at best to measure without sophisticated equipment most do not have access too.
    AVGas will store a LOT better than automotive fuel however. But there are some drawbacks. Limited availability, price, and of course the most commonly available grade (100LL) has far more tetraeythyl lead (TEL) that automotive fuel EVER had. Think about that with the machine's that exhaust 3ft in front of your face. Lead inside your body is poison, no matter how old you are or how it got there.
    Horkn, mike bayerl and blacksmith like this.
  11. bushpilot
    bushpilot
    Eastern Washington
    Well, we can go back and forth on the finer points, but in the end you will remain convinced of the value of avgas in saws, and I will remain unconvinced.
    I agree that avgas tends to be more stable over time, that is a plus for using avgas. Free is good too, if you got it.
    But the saw likely will not run better on it, as it does not need the detonation protection. It will probably run inperceptably worse due to the 5% lower BTU rating.
  12. bushpilot
    bushpilot
    Eastern Washington
    Avgas contains lead, lot of it. Lead is poisonous especially to children, but also to adults. Symptoms and causes - Lead poisoning - Mayo Clinic
    Avgas is highly unlikely to make your saw produce more power, it will probably produce less power. It might (likely will) store better. There are other ways to make the saw store better, if that is a problem.
    These are indisputable truths. Your call.
    Horkn, blacksmith and Naturalgas like this.
  13. MikeInMa
    Well then......
    Thanks all for all the comments, and differing opinions.
    Maybe, I'll try a 50/50 mix of E10 and no E, with the appropriate amount of fuel stabilizer. That will give me, effectively, E5. I have to think that's better then E10, and the 110 octane will be tamed a bit as well.
    I don't go through a lot of gas, between my chainsaw, lawnmower, and snowblower. So, I'd be looking for a bit of extended shelf life. Not months and months, but weeks and weeks should suffice.
    Thanks again and Merry Christmas. Everyone have a safe Holiday season.
  14. mdavlee
    mdavlee
    Really if you use less than 10 gallons a year it may be cheaper and easier to buy trufuel or VP SEF in 5 gallons pails.
  15. Boomstick
    Boomstick Banned
    Saratoga county ny
    You make it sound like lead was created for use in gas for airplanes it wasn't.
    Lead can kill you and cause several types of organ failures.
    Lead is an octane booster it slows the rate of burn.....
    It resists pre ignition and detonation...Caused by heat and compression..
    Lead being added to gas had if I remember correctly little to do with modern airplane engines.
    I've redneck tested e85@105 octane. Its hard to ignite on the ground....87 pump is volitol! You get that whhhooomp! E85 it's a cool low slow flame.
    Pre 2003 alot of candles were lead core(some still do) and dispursed lead vapor into enclosed spaces like a living room or bathroom.....It was more common in earlier years as well.........
    But now they use other poisonous heavy metals like zinc in candle wicks lol.
  16. MasterMech
    Lead, specifically TEL, was added to fuel for many reasons, most of them capitalist in nature. ;) Obviously, modern engines have eliminated the need for it with superior materials and machining. Both of which were available decades before they were actually implemented. But it was the advent of the Clean Air Act (1970) and the Catalytic Converter that brought about the elimination of TEL in automotive fuel. Using a catalytic converter to scrub emissions down to regulatory limits would have been impossible with the continued use of leaded fuel.
    The whole function of lead in the fuel was not only an octane booster but it also coated the valve sealing surfaces preventing them from forming micro-welds when closed under high-heat/load. The lead would lubricate the valve and provide a good seal when it closed as well. Eliminating the micro-weld pitting also greatly extended the life of the valve seats. Not beyond what today's engines achieve (when was the last time you had the valves ground on your car or modern small engine?) but much better than what would have resulted using unleaded fuel with what was standard materials for valves and valve seats back in the day. The valve seat wear issue is really only a significant factor in engines that see a lot of use under high load conditions. Airplane engines, stationary (industrial) engines, and vintage small engines were all included in that category. Plenty of guys out there with a vintage car/truck that drive it a few times a year in the local parade that do just fine with regular unleaded, even E10. If they were still working/racing those engines however, the wear issues would crop up.
    Boomstick and blacksmith like this.
  17. mdavlee
    mdavlee
    E85 you need about double the fuel volume over pump gas to make the same power.
  18. MasterMech
    My 5.3L drops from a 15-16mpg average down to 9-10 on E85. But picks up 15hp.
    Horkn, blacksmith and mdavlee like this.
  19. brenndatomu
    Truth ^^^
    High octane fuels is one of the biggest scams perpetuated by big oil companys. Think about it, fuel that burns cooler and slower (read less MPG) sold at a higher profit...
    Horkn, bushpilot and mdavlee like this.
  20. Boomstick
    Boomstick Banned
    Saratoga county ny
    When running e85 I never came close to double. On forced induction making more HP with e85 than premium, I was using about 28℅ more fuel at WOT. For rough tuning a good starting point is 30% richer either carb or fuel injection.
    Theoretical max power rich is waaay to rich.
    I used to have cruise AFR set to 16.8 with e85.....
    mdavlee likes this.
