Condor probes for AS woodstock
Discussion in 'Modern EPA Stoves and Fireplaces' started by Camber, Dec 22, 2017.
  1. Camber
    Camber
    Montana
    Evening folks. My Absolute steel just showed up today and since I didn't get all my pipe...I've decided to put a flue thermometer in. Does anyone that has an AS know which models I need? Flue and cat? I've looked on their website but couldn't find anything for woodstock.
  2. Matt Fine
    Matt Fine
    New York
    I can’t help with the cat, but for the flue I would suggest a probe style even with single wall pipe. Condar makes two models, one is fairly colorful and in Fahrenheit and the other is black and white with Celcius on the outside and Fahrenheit on the inside. There are a couple other brands as well. Any of them will work, although the accuracy and reliability may vary and none will be as good as digital thermocouples.
    Installing is as simple as drilling a small hole and sticking it in, so don’t let that stop you.
    Camber likes this.
  3. Camber
    Camber
    Montana
    Thanks Matt. I wish I had darn thing installed. -10 F now. But I've got three other stoves cooking now, the garage,sauna, and shop.
  4. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Give woodstock a call, they should have them both in stock. I need to pick up a cat probe, going by color when you need to lift the lid with a pot of water on it is a pita
    Camber likes this.
