Comparing the Ideal Steel to Progress Hybrid
Discussion in 'Modern EPA Stoves and Fireplaces' started by Flamestead, Dec 12, 2013.
  1. fox9988
    fox9988
    NW Arkansas 72717
    8" is a LOT of travel, easy to adjust in small increments. Are you saying the Steel is more controllable than the PH, or just easier to control?
  2. Flamestead
    Flamestead
    Windsor County, VT
    The PH has a similar amount of travel (longer lever), but my first adjustment from wide open at start-up was always straight to 50%, so half that travel was wasted.
    One last photo for the night...
  3. Machria
    Machria
    Long Island, NY
    Flame, can you post a pic of the PH on your hearth? I'd like to see how big or small it looks compared to the steel on there....
  4. Flamestead
    Flamestead
    Windsor County, VT
    Here she is. I won't post a picture of her current condition because she looks sad and neglected (dirty glass, ash pan and heat shield off...)
    papadave and milleo like this.
  5. Huntindog1
    Huntindog1
    South Central Indiana
    Todd I remember hearing something about a secondary cat air inlet that at certain times during the burn the cat can be starved for air and this control lets more air in automatically to get a clean burn plus this also balances out the air flows thru the stove and stabilizes the burn as when hte stove is burning at a higher level it needs to be calmed down a little or balanced out. Allowing more air in the top of the stove at the cat means less air being sucked in at the wood coal level and so the wood coals burn slower while the cat burns hotter at the top of the stove.
  6. Flamestead
    Flamestead
    Windsor County, VT
    Visual Dimensions:
    I think if you made a custom-fit box to set each stove in the dimensions would be very similar. The PH has many design elements that downplay its size (angled corners, stepped-in top), which makes it look smaller. Since I don't have the stoves side-by-side, I've taken pictures with a stick in each photo as a reference. I modified the length of the stick for each dimension (height, depth, width), and for each dimension kept it the same length for both stoves (I used the Ideal Steel to set the length).
    (Flush with the PH front top casting)
    concretegrazer likes this.
  7. Flamestead
    Flamestead
    Windsor County, VT
    Optical illusion. This stick is flush with the outside of the legs.
    Really close to the same...
  8. Flamestead
    Flamestead
    Windsor County, VT
    Height: Note that the Ideal Steel has adjustable height, and we are set near the low end of that. Also note the PH has two leg heights, and we have the tall legs.
    (CD case on top, so you can see the top of the soapstone despite the white background)
  9. Machria
    Machria
    Long Island, NY
    Nice, thanks. Man, I just love the look of the PH and all it's soap!
    Oldhippie likes this.
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    The Ideal Steel looks great with that color scheme and duck hunting scene on the sides.. I wouldn't mind one on my hearth!
  11. raybonz
    raybonz Moderator
    Carver, Mass.
    Now about the blower...
    concretegrazer and BrowningBAR like this.
  12. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    A blower would rock. Especially when run at the lower temps. Please let there be a blower.
  13. Machria
    Machria
    Long Island, NY
    Why would anyone want a "blower"? I dispise hearing a blower! Get soapstone and you don't need a blower. ;)
  14. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I've had soapstone. Blower helps move the air better. Hearthstone offers blowers.
    concretegrazer and raybonz like this.
  15. Machria
    Machria
    Long Island, NY
    Say NO to blowers!!!!!!!!!!!!
  16. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    A blower allows you to move heat around a lot more efficiently. It helps with poor layouts and stoves wedged in a fireplace. Of which I suffer from both.
    concretegrazer and alforit like this.
  17. raybonz
    raybonz Moderator
    Carver, Mass.
    You don't have to have one but they make a big difference moving the air as BB mentioned.. A good blower is pretty quiet.. You'd be surprised how quiet the T-5 blower is.. My humidifier makes much more noise and I need the humidity..
    Ray
  18. concretegrazer
    concretegrazer
    Southwest MO
    What type of blower is on the T-5?
  19. concretegrazer
    concretegrazer
    Southwest MO
    Don't you have a forced hot air duct?
  20. raybonz
    raybonz Moderator
    Carver, Mass.
