Compact Tractor
Discussion in 'Chainsaws and Power Equipment' started by Beet Stix, Jun 14, 2014.
  1. lukem
    My neighbor growing up had a JD with a belly mower. I helped him remove the deck a few times. Its pretty easy to do on level ground. It didn't have the reversible wheels like you described either.
  2. clemsonfor
    I thought JD you rolled over the mid deck now a days?
    Stinny likes this.
  3. Stinny
    What were you riding? A lot of miles.
  4. Stinny
    Yup, the larger ones do that. Perty cool.
  5. lukem
    We started out with a couple front deck Zippers and wore them out. Then we went through several Dixie Choppers in gas and diesel flavors. Hard to beat a gas powered 72" ZTR for busting out acres of turf.
    We bought a new ZTR one year and I was the only who drove it. I put almost 600 hours on it in one year.
    Chvymn99, MasterMech and Stinny like this.
  6. Stinny
    "I put almost 600 hours on it in one year." ... that's a lot of azz thrashin... gawd my back hurts just readin' that... o_O
    Chvymn99 and clemsonfor like this.
  7. lukem
    Air down the tires a little, lean forward, and roll out. Riding it wasn't bad....but that's a lot of blade changes.
  8. MasterMech
    I started out mowing over 80 acres of finished lawn (total property was roughly 900 acres which is decent sized for the area) for an estate belonging to a VERY wealthy woman. (She flew in via helicopter....) I was pretty much a one man grounds crew. I had to get all of the lawn cut, the main areas trimmed and be done inside of two-days. The rest of the week there was bush-hogging, weed-eating fencelines and helping out on the farm that needed to be done. Not to mention cars to wash and other odd-job type errands to fit in.
    We had All kinds of equipment from a push-mower up through a Deere 4440/4450 with a 15 ft bush-hog to get 'er dun. But the main house lawns were always done with the ZTRs, bought one 72" Exmark Lazer Z with a 25HP Kohler on it, loved it so much that we bought another one, this time with the 27HP Liquid Cooled Kawasaki on it. The diesel front mount mowers sat unless we were mowing a tight area where the 72" ZTRs wouldn't fit. We had a 5000 ft grass runway (private airstrip) to mow too but that was done with a farm tractor towing a set of Toro gang mowers. (Spartan reels -- old school) I could knock that strip out in under 30 minutes with those. :cool:
    After that job I got into fixing these things for a living and the rest is history.
  9. lukem
    I love 4450s. Especially when they've been fiddled with.
    concretegrazer and clemsonfor like this.
  10. Stinny
    Those Toro reel mowers do an awesome job of knocking down the tufts too don't they? Those trailing rollers are great. Bet it was a mighty smooth runway.
  11. MasterMech
    Neither one of those pumps were running stock settings. :cool: 3 bottom over/under and we could move some ground! :D
    Actually.... They would leave any weed stems over 6" tall and hadn't seen a grinder in decades so cut quality left a bit to be desired. But the 3020 would drag 'em pretty quick, start in 4th, clutch it to 7th and run it at about half-throttle. (If you've driven a Deere with the SyncroRange trans, that made perfect sense! ;)) They'd sing pretty good and throw rooster tails of clippings doing 10 MPH down the strip!
    concretegrazer, Chvymn99 and Stinny like this.
  12. Stinny
    Yeah, running a reel mower with dull blades wouldn't work as good as dull blades on a rotary, that's for sure.
    clemsonfor likes this.
  13. chris
    chris
    SE WI
    Recently got a 98 Massey Ferguson 1230 4x4, loader, 60" deck, pto&3point cat1, 28hp Iseki diesel, Combination soft/hard cab with heat. Haven't much time to play with it yet. Still trying to remember which lever does what. Did move some logs around a few days ago. Replaced skid steer I sold last fall. No issues with skid just could not use it much and I was never comfortable in it. The MF has much better ground clearance with the deck off course. The trade off is in the lift capacity and maneuverability, but much better in the versatility department and 3 point attachments are considerably less expensive than equivalent items for the SS. Sold the SS for same price I paid for it 6 years ago, and these CUT units are the same or worse in the price department. Didn't really care about the deck, it does add to the resale ability though. Got top half of a grapple fabbed up, got to do the bottom 1/2 yet and then maybe convert the loader to quick tach, although pulling the bucket off isn't all that bad as it stands, adding quick tack reduces lift capacity though.
    cnice_37, clemsonfor and Stinny like this.
  14. cnice_37
    cnice_37
    Chris, we are going to need some pics of that grapple.
    I agree, a couple pins to pull the bucket is no big deal if not doing it often. Also smarter as you mentioned to save that precious lift capacity.
    We are gonna need a tractor pic thread.
    concretegrazer likes this.
  15. MasterMech
    What if you converted to a Deere style quick-tach? It's simpler and lighter than a skid-steer style and the parts are readily available via any Deere dealer. Buckets and attachments are available ready to attach as well. Skid steer buckets generally do not work well on small CUT loaders due to their increased weight (reduces lift capacity) and the visibility angles are generally wrong. The deep/shallow profile makes breakout force an issue as well.
    jetjr and Stinny like this.
  16. chris
    chris
    SE WI
    I will get some pics up in the next couple days. Not familar with the Deere quick-tach, Although I have seen listing for conversion units that are not as massive as the full ss units. For the grapple I will need to find a way to rig another hydro circuit or change out the current loader valve to a power beyond type ( pricy) With deck on nothing left to tap. Don't need a ton of flow rate for the grapple. As with most tractors this is a closed circuit system, I believe. Might be simpler to due a conversion from an old snow plow electric over hydro or something along that line -more than enough flow rate/pressure there. I know there are some small electric hydro power pacs around that are not astronomically priced.
    Stinny likes this.
  17. WVhunter
    WVhunter
    Mountains of WV
    I own about 120 acres and used to have a JD 5425 which was a 81 hp, 65hp to the pto. My farm is all wooded except for about 30 acres, I used that thing alot. When I quit cutting hay, I sold it along with most of my equipment that went with it, including my 3pt splitter. This was a mistake, I did not relise how much I used it, so now I have been looking for something in the 30-35hp range, loader and brush hawg. I have looked at all brands and around here they are all close in price, EXPENSIVE!!!! I even priced a Branson $19,300 for the tractor and bucket. Point is you will get alot of use out of it, more than you think. Just be patient and look for a deal, that is what I am doing. Some people buy these, think it is cool, and then never use them, so they sale them. There are a few good deals that come up, look for them.
  18. clemsonfor
    Isnt branson the same as montana and didnt LS leave those guys high n dry and pull out of the US market a few years ago?
    I know farm track had that done and the guys that bought them were left without warranty support.
  19. jetjr
    jetjr
    Pa/Md line
    In that hp range check on tractorhouse.com. I bought my New Holland from Forrester farm equipment in chambersburg pa. Found them and the deal on their.
  20. MasterMech
    The Deere QT is stupid simple. Bucket hooks over two plates much like a skid steer setup but instead of a mechanical latching system, the bucket has two stub pins welded to the back that poke through the loader mount plates and are secured with lynch pins. Last time I checked, all the parts were available to weld onto whatever bucket or attachment you have.
    I like the idea of the grapple having a self-contained electric-over-hydraulic system. Parts are cheap and available and setup is easy/cheap. Rob a snowplow setup off an old plow truck and your in business.
    concretegrazer, clemsonfor and Stinny like this.
