Coming soon...Echo Saw Builds
Discussion in 'Chainsaws and Power Equipment' started by Eggshooterist, Nov 9, 2024.
  1. Sawdust Man
    Sawdust Man
    He's kinda on o p e.
    Maybe not one of the most fashionable porters but I think he does good work, and his price was good......only issue was, he had the saw for a bit over a year.
  2. Eggshooterist
    Eggshooterist
    Erff
    Thats a spell for sure. Wow.
  3. Sawdust Man
    Sawdust Man
    Yeah, I'd'a been miffed if I had been in a hurry.
    He did say he was kinda slow, but......
    I have no complaints, and.....it makes a good story.
    Lol
  4. Eggshooterist
    Eggshooterist
    Erff
    Update on the 4010. Removing the limiters to adjust the carb didn't help with being rich when limbing. So I did some investigation to figure out what feeds what, and where it flows, using carb cleaner. Then I picked the brain of someone who really knows saw carbs inside and out on how they remedy it.
    20241201_105353.jpg The circled hole to the right feeds fuel to the high needle, which you can adjust but, the hole in the slotted jet you have no control over and feeds the high speed circuit from around 1/2 throttle to wot. You can close the H needle completely off on this saw and it still runs. I tried to remove it to solder it shut but it wouldn't budge so I JB welded a welch plug over it. I hope to test it tomorrow now that I will have full control of the air / fuel ratio on the H screw. Some people call these "governors" as they basically prevent you from leaning the saw out.
  5. Sawdust Man
    Sawdust Man
    Well no wonder I couldn't get it to lean up!
    Between that and the limiters, there's no way it'll run anywhere near it's real potential.
  6. Eggshooterist
    Eggshooterist
    Erff
    Correct. Here's a vid demonstrating for thise that aren't familiar. If you pull up it cleans up or if push down hard enough. Otherwise, it blubbers unless you are cutting much larger wood.
    https://photos.app.goo.gl/VoBV7AjguCrZjeJv5
  7. Ohio
    Not Ohio
    The 590 Timberwolf has the same thing in the carb. The saw is so common the replacement plug without a hole in it is readily available online. The cheap and easy fix is to jb weld it like you did.
  8. Eggshooterist
    Eggshooterist
    Erff
    Knowing that about the 590 /620 is why I tore into this carb. Sure enough, there's the warranty protector. Lol
    I just wasn't 100% on what to plug because it had thee visible jets plus other holes. Now I know what to look for.
  9. Eggshooterist
    Eggshooterist
    Erff
    FAIL! Would not run below 1/2 throttle with that plugged no matter how far out the needles were opened. it would rev out like it should beyond that. They might look like the jet in a 590 / 620 but it appears to not feed the same thing. I got lucky and got the JB welded welch plug out and tada! idles and operating normal again. I put a new full chiz chain on it and took the rakers down to .035. So far it running much better than before. Maybe the hungry chain is all it needed. I'm not accepting that answer just yet.
  10. Mrxlh
    Mrxlh
    Dat Boot
    Is the H circuit back fed by that orifice? I believe the 3120XP H jet (when you mod it), is fed the same way. Hence I’m having the same issue, I cannot get it to lean out even turning the H in until closed, which I believe is what you tried. It’s fixable, but from what Kevin said, it’s a tad more involved.
  11. Eggshooterist
    Eggshooterist
    Erff
    Not sure but im not giving up yet..a new carb is $35 if I ruin this one.
  12. Eggshooterist
    Eggshooterist
    Erff
    I have abandoned the 4010 project. One of my nephews is buying it. If I could change the name of this thread to Echo saw projects, I'd continue here with the 501P progress.
  13. Sawdust Man
    Sawdust Man
    Rats.
    So you think it's a lost cause?
  14. Eggshooterist
    Eggshooterist
    Erff
    I could use a toothpick, per Mrxlh to test which jet I can plug to defeat the "governor" but, the nephew likes it as is with the rakers at .035.
    The toothpick could easily be removed.
  15. Sawdust Man
    Sawdust Man
    Roger.
    Glad it found a good home anyways.
  16. Eggshooterist
    Eggshooterist
    Erff
    Ok, thanks to Backwoods Savage the title has been modified to reflect the change in this thread. Here is the start. As some may have seen in the what's on your bench thread, I was given a hard use Echo 501P with 18" Tsumura lite bar and three woodland pro full chisel chains. Two still in their boxes. I'm in process of doing a deep clean in preparation for dying all the plastic black and future performance modifications. It already has a muffler mod and carb limiters removed. The saw has 100-150 tanks of fuel through it doing some commercial arborist work and a lot of fire wood cutting. Mostly original formula Red Armor or Dolmar Synthetic @ 40:1. A bit of Amsoil Dominator mix as well. If you zoom in on the piston pic you can see the machine marks are still there. Until next update... 20241215_075721.jpg 20241215_075752.jpg 20241215_075736.jpg 20241216_123951.jpg 20241216_123946.jpg 20241216_123954.jpg signal-2024-12-16-12-52-47-001.jpg signal-2024-12-16-12-52-51-819.jpg 20241216_123934.jpg
  17. RCBS
    RCBS
    Over here
    Excellent condition considering commercial use. Just needs a wash.
  18. Eric Wanderweg
    Great progress :thumbs:
    I really need to splurge on an ultrasonic cleaner; they're not even that expensive. Well worth it if you do enough saw builds or simply don't like running them hard and putting them away dirty.
    KSPlainsman, Screwloose, RCBS and 3 others like this.
  19. Eggshooterist
    Eggshooterist
    Erff
    It is yes. The ultrasonic cleaner is doing a great job with that super clean.
  20. Eggshooterist
    Eggshooterist
    Erff
    So far this one is great. Its analog. I was advised to skip digital versions as they have issues.
