coldest ever
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by BHags, Feb 14, 2016.
  1. 343amc
    343amc
    Northeast Lower Michigan
    It was warm here this morning based off the numbers I saw here. Coldest I saw was -3F.
    Good thing Lake Michigan isn't frozen over or it would have been a lot colder.
    ivanhoe, BHags, ttdberg and 4 others like this.
  2. will711
    will711
    Pocono Mts.
    Been there done that too :handshake::cheers: that's why I do pellets now , but even with them I some times F up and forget to load before I pass out :drunk::doh:
    savemoney, ivanhoe, BHags and 4 others like this.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Lets hope so, we moved about 1/3 cord in today. We have far more on hand but dont want it taking up room in the house or haul it back out when the weather breaks.... Only two real cold days here this year. I'll take it after last year.
    ivanhoe, BHags, ttdberg and 2 others like this.
  4. will711
    will711
    Pocono Mts.
    Me Too this winter has been a treat :dex::dex::dex::dex::dex:compared to the last 2 ,when you work outside like I do .
    savemoney, ivanhoe, BHags and 3 others like this.
  5. imacman
    imacman
    Denver, NC
    Uh oh
    :heidi:
    ivanhoe, ttdberg, bogieb and 2 others like this.
  6. imacman
    imacman
    Denver, NC
    In my previous home w/ the heat pipe going through an unheated attic, I had that zone set for 6 times a day for 10 minutes. Never had a problem in the coldest temps.
    ivanhoe, ttdberg and bogieb like this.
  7. will711
    will711
    Pocono Mts.
    So far I've been able to recover before she knows I F 'ed up :thumbs: I get up before she does :whistle:
  8. imacman
    imacman
    Denver, NC
    I did. If you mention you're on a pellet forum, you might get an additional 10% off. Great unit, perfect for your situation.
    artc, ivanhoe, ttdberg and 3 others like this.
  9. Russell
    Russell
    South Coast , Massachusetts
    My first year with the Quad cb1200 so I was up and down all night checking and trying to find that sweet spot . Looking for the most heat I can get but don't want any issues at - 9 :hair:
    savemoney, ivanhoe, ttdberg and 3 others like this.
  10. will711
    will711
    Pocono Mts.
    Russell [ Grasshopper ] you have done well my friend :handshake: a newbie that has become a seasoned veteran real fast well done :salute:
    savemoney, ivanhoe, imacman and 4 others like this.
  11. Russell
    Russell
    With the help of you guys . Thank you Will appreciate it .:handshake:
    savemoney, ivanhoe, imacman and 3 others like this.
  12. will711
    will711
    Pocono Mts.
    Thank you too Russell new folks help drive this site and we learn from you too always a win win :cheers:
  13. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    X2
  14. bogieb
    Sounds pretty much like my house (actually two rooms of pipes go thru garage).
    Yes, I bought mine direct from Bear Mountain. IDK if you can get it anywhere else. Easy to set up and program. Seems expensive for what it is, but I don't have the know-how to make one myself and was well worth it to me.
  15. Keep-in Warm
    Keep-in Warm
    I have set them set to run 2 minutes every 2 hours when it gets down to single digits, but at -35 wind chill its just easier to turn on the trouble zone. My problem is that the trouble area is tied into a thermostat in the room shared by the pellet stove. The trouble pipes surround a block foundation addition with a dirt crawl space. The coldest part of the house.
  16. bogieb
    My boiler thermostat is also in the same room as the pellet stove, but the ThermGuard overrides the thermostat and tells it to turn on (I'm sure you know that, just clarifying for anyone who is unfamiliar with the unit). I, myself, would have it run more than 2 minutes because I would be unsure the pipes in the cold area would truly warm up in that time, but that is me. You know what works best (and easiest) for you and your situation.
    savemoney, ivanhoe, imacman and 2 others like this.
  17. thewoodlands
    thewoodlands
    We had -29 this morning (-45 realfeel) we had the wood & pellet stove going in the basement and the oil furnace still kicked on a few times.
  18. Keep-in Warm
    Keep-in Warm
    re. Thermguard....Bogieb, "You know what works best (and easiest) for you and your situation."
    I appreciate the insight. I'm aware of the thermostat override but appreciate any feedback on what others have for settings.
  19. Keep-in Warm
    Keep-in Warm
    For piece of mind, I should look into those wireless thermometer monitors and place a couple of stats directly in the pipe / foundation areas of concern. Then I would know what temps I'm dealing with in the dirt crawl space / block foundation when it gets this cold.
    Anybody do this?
    ivanhoe and bogieb like this.
  20. ttdberg
    ttdberg Pellet Pig
    CT
    I sure will, thanks for the tip!
    artc, ivanhoe, Russell and 1 other person like this.
