  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Who needs a midlife crisis when you can have a midlife crisis in denial! Thats how that works right?:p
    We better go up a few degrees so I can start my van it wouldn't turn over this morning AGAIN! I reallllllly need to get work to let me stick a block heater in it....:doh: Theres some people counting on me today:picard:My wifes heat blanket is on the starter vacinity right now:whistle: No Joke...
    Rope, Horkn, HDRock and 5 others like this.
  2. Pallet Pete
    Ovid
    I saw somewhere where people where stacking bricks up to the top and adding a baffle that made it much more efficient but for the life of me I cant remember who did that.
    WeldrDave might remember maybe it was coaly?
    It was a pretty neat little trick that gave out more heat and better burns.
    Gasifier, Horkn, HDRock and 4 others like this.
  3. NH mountain man
    NH mountain man
    WMNF N.H.
    You better go in then and warm up your wife.:shiver:
  4. Stinny
    x2
  5. Pallet Pete
    Ovid
    She went to work at 7am and even in the garage the car banged into cold life. She had to warm it up for 15 minutes... Thats usually a sign winter is in full force around here. Unfortunately the van has to sit outside because my truck is locked away most of the winter in the garage so it can stay out of the salt and cold winds.
    Its how I can use the heat blanket and not get yelled at till later. :rofl: :lol:
    Rope, greendohn, Gasifier and 7 others like this.
  6. papadave
    Nice hat. :yes::D
    Rope, greendohn, Horkn and 5 others like this.
  7. papadave
    So yeah.......it's a bit chilly. -9 on the way to brother's house again. No idea on wind chill.
    Rope, Stinny, greendohn and 8 others like this.
  8. bang
    bang
    South central Indiana
    It has 2 air intake ports in the rear near the top , guessing an attempt at a secondary burn, that I closed off and I can control it better and with "overnighters" get 8 or 9 hour burns. Daytime I throw junk wood in it to keep it above freezing unless I'm going to be out there working.
  9. Backwoods Savage
    I do not think that is an actual temperature. Maybe a wind chill but that just tries to make the temperature sound bad...
    milleo, NH mountain man, Rope and 3 others like this.
  10. yooperdave
    At first, I thought the same....but then when I checked my thermometer a few minutes ago....:bug:
    Yes, it is coldest before the dawn!
    milleo, NH mountain man, Rope and 6 others like this.
  11. Backwoods Savage
    Methinks it is a safe bet to say that most of us are into winter now.
  12. Backwoods Savage
    Still has to go some to reach -40 or lower! But you and I both know it very well can do that, but usually in January.
  13. Pallet Pete
    Ovid
    I’m not sure the article didn’t specify but I’m betting it was wind chill.
  14. Pallet Pete
    Ovid
    o_O
  15. Pallet Pete
    Ovid
    Wow the van started! Very hard but it started! Thank god for Walmart heat blankets:whistle:
  16. WeldrDave
    If you have a Fisher, "which" he doesn't sadly, you could stack fire brick up on the lower brick. It was a "easy" thing to do instead of welding in angle iron on the sides and setting in a piece of steel. Pete, you were right, it was Coaly! I believe he did it first. I welded the pieces in on the sides and set the baffle on it. I'm not to sure if he can do it with the earth stove? :confused: I've never seen the inside of one and only seen one in a antique here locally "which" they burn all winter long! :), Sorry can't be of much help. I do know that when bricks were stacked it worked fairly well unless you had a thin 1/4" or less plate and it warped, then the bricks would fall. You need a minumum of 3/8" for a good baffle.
  17. WeldrDave
    The Theory from what little I've read on them is it was to create a better pull into the chimney. There were many "copycats" of the original Fisher design and the only one that was the closest was the Kodiak stove, By Alaska stove works. The all nighters, big moes, Timberline, and several more. All served the purpose, some better than others and they were all trying to get into the wood stove market back in the late 70's and early 80's. EPA came into play and slaughtered most of them financially, even Fisher took a major hit!
  18. clemsonfor
    Our walmart does not sell heat blankets unless its for your bed...must be a regional thing:whistle:
  19. bang
    bang
    I had an all-nighter mid moe in the house that I liked but when I built a hearth it didn't fit due to the flue going out the back. It definitely did better than the earth stove but I sold it and later decided to put a stove in the shop. Sometime I'll get something better but I have plenty of wood to feed it.
  20. papadave
    Gotta' think outside the blanket. :)
