  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    An easy +13°F ambient outdoors . 68° in the far end of the house . 4 rooms away from the woodstove. Pretty much dark outside now .
    White Spruce in the woodstove . I'm playing around with saw split (noodled) squares. Just small enough to fit through the woodstove door. See how well they last .
    Pretty warm this week . All last week it was -17 to -22 F ambient. So this is almost T shirt weather .
    Absolutely Loving the 10" thick dense packed , insulated walls.
    MNWood, TnMan, Stephiedoll and 9 others like this.
  2. yooperdave
    12 right now but that's expected to drop a bit more before the day begins in earnest.
    No snow.
  3. theburtman
    theburtman
  4. Burnin Since 1991
    Burnin Since 1991
    Good Morning! 25 here this morning. 65 inside. Got a good one going this morning. Maple chunks, oak cutoffs and a couple pieces of oak.
  5. The Wood Wolverine
    39 this morning is much warmer than yesterdays 24. 71 inside, burning oak.
  6. Backwoods Savage
    22. It spit snow all day yesterday but temp around 35 so none stuck around to make things slippery except in a very few areas. I'm told it got slick between Saginaw and Mt Pleasant late in the day.
  7. theburtman
    theburtman
    We have had 17% more heating degree days so far season to date over last season. I have used significantly less wood. As best I can tell from my records maybe 30% less. Mostly elm from the same 2022 score, and lumber cutoffs like last year. The only thing I can think of is I eliminated a bad draft that caused one whole corner of the house to be cold. I knew it would help with consumption, but didn't expect this much.
  8. saskwoodburner
    saskwoodburner
    Sitting at -2C/29F this morning, with a few inches of snow fall for insulation. Should make it above freezing today. Pine chonkies for breakfast.
  9. lukem
    Cool and damp here. 45 and a heavy mist coming down.
    I forgot to load the boiler yesterday but it still had a good coal bed in there this morning. Loaded it back up with a mix of ash, walnut, and cherry. I need to move another pallet of wood up but we got too much rain yesterday and the tractor would destroy the yard in the process. I guess I'll just have to burn the stuff by the boiler until the ground firms up.
  10. Locust Post
    41/72 didn't reload this morning as the wife was sweeping and putting the tree up in the stove room. Just started back up around 5:30, maple and ash.
  11. Horkn
    Newer phones have really great cameras. The main issue in FHC is the megapixel limit. Anything over 8 mp and it will more than likely need to be reduced quality. I usually have to take screenshots of my pictures on my pixel 8 pro.
  12. theburtman
    theburtman
    24/74 Shagbark shorts
  13. Dunmyer mowing llc
    Dunmyer mowing llc
    Indiana
    Bout 45f outside.
    Feels good to be home after 3 days of out of state work.
  14. Burnin Since 1991
    Burnin Since 1991
    24 F here this morning. 64 in the house at 6am. Not much for coals left this morning so burning some pallets and a few small splits of oak and maple. We're sitting right at 71 in the house and letting the coals do their thing for a bit then loading up a full load for the slow burn. High of 44 today and cloudy. Lot's of chores to do today!
  15. The Wood Wolverine
  16. yooperdave
    Warm morning. Still no snow but rain today.
  17. Backwoods Savage
    Do you mean they would reduce if sent online?
    NH mountain man and jmb6420 like this.
  18. Backwoods Savage
    27 during night then temps started rising. 34 with drizzle now.
  19. MNWood
    MNWood
    Coon Rapids Minnesota
  20. NH mountain man
    NH mountain man
    WMNF N.H.
    It has to be your sealing up the draft, I am not far from you and I have used significantly more wood so far then recent years.
