  1. spotted owl
    spotted owl
    PNW
    It’s warmed up considerably. 27 / 71. Full load of oak for the night.
    Owl
  2. WoodPirate
    WoodPirate
    Tennessee
    11/74 Snow tapered off. Weather people said 3-6 we only got maybe an inch. Glad weather people missed predictions. Still too cold for the South. Oak and elm keeping it warm.
    Camber, Horkn, metalcuttr and 10 others like this.
  3. Dano in Mexico Missouri
    Missouri
    Set a record here in central Missouri. Never got higher than -2. Lowest was -12 at sunrise. Burning white and chinquapin oak. The ole Clayton wood burning furnace has kept house nice and toasty at 74-75 degrees for days.
    Camber, Horkn, metalcuttr and 16 others like this.
  4. theburtman
    theburtman
    22/73 burning down coals with pine
    Camber, metalcuttr, wildwest and 12 others like this.
  5. Chvymn99
    Currently -9 w/ WC of -21 ... House is currently 73F ... the other half put 3 sticks on a full bed of coals before 2... But will be removing coals here in a bit for a full load of Oak for the day burn, since its time to go back to work... NC30 did A Okay... heater only turn on twice yesterday while trying to burn down coals (its set at 69F)... Ended up only have to take out 2 buckets of coals over the weekend, will be three this morning... I'm happy...
    Stephiedoll, Camber, Horkn and 14 others like this.
  6. Chvymn99
    Not surprised ... It definitely was a rare event... Glad your staying warm neighbor... :handshake:
    Camber, Horkn, metalcuttr and 6 others like this.
  7. Haftacut
    Haftacut
    Rives Junction, MI
    -8 out there and 71 in here. Beech to keep things going this morning. If I was gonna be around today, I’d consider supplementing with the morso. Not many days a year where I need to do that!
    Stephiedoll, Camber, Horkn and 11 others like this.
  8. Haftacut
    Haftacut
    Rives Junction, MI
    Beautiful stove and flames
  9. BuckeyeFootball
    BuckeyeFootball
    -4f, -19wc, house is at 71 and rising with a full load of BL
  10. Gasifier
    16F. Cherry, Beech, and Yellow Birch.
    Camber, Chvymn99, Horkn and 9 others like this.
  11. Butcher
    Butcher
    Boss offered me the day off. Ain't gotta ask me twice!
  12. jmb6420
    jmb6420
    Grand lake, Oklahoma
    -7/63 when I got up this morning. Guess I should have loaded up last night before bed. Red oak & hickory.
    Loading up the Lopi
    Mike in Okla
    Camber, Chvymn99, Horkn and 13 others like this.
  13. yooperdave
    -9/68 WC -33
    Camber, Chvymn99, Horkn and 11 others like this.
  14. Biddleman
    Biddleman
    River Hills of Pennsylvania
    Had a bed of nice coals 5:30 AM for reload. Bringing house back up to temps with oak, cherry and BL.
  15. ginger1313
    ginger1313
    12/66. Load of maple doing its thing now.
    Hopefully winter will stick around finally.
  16. Chud
    Chud
    NC
    Radar says yes my eyes say no
  17. Eric Wanderweg
    18/69 red oak and mulberry
  18. WeldrDave
    We hit 20º last night for the first time. warming to 32º today. 78º in the house, just threw a MEGA split of Oak in Grandma! She's a simmering away...
  19. Backwoods Savage
    It is actually very simple. First, many folks think you can just put wood in a stove, set the draft and forget about it. Until the brains figure out all the gadgets that are need for this, one needs to pay attention to the stove. While I do let the stove go for many hours, including overnight. I do try to pay attention to the stove then adjust if necessary. One of those necessary times is during extreme cold spells. This is when folks have a tendency to add wood as the stove cools but it has lots of coals.
    Normally during these times when our flue temp gets down close to 300 and the wood has burned to almost all coals, it is a simple matter to open the draft to full open. Some say adding a small bit of soft wood like pine will help burn those coals down but I've not had very good results with this. After giving the fire more air the stovetop temp will stay steady. Sometimes it may help to use a poker and rake through the coals to loosen them a bit. As for the cat during this, there is nothing to worry about as there is very little to no smoke to burn off.
    That is all there is to it.
    For night burning, many time when you get up you will need heat right away. Then I do not concern myself with the coaling. I also do not fill the stove but usually add only 2 or 3 splits and let it burn fairly hot. Near the end there will still be coals but just do as above.
    By doing the above, you gain space in the stove to add more wood. For sure the burning of the coals should be done in late afternoon or evening so you have firebox room to fill for the night fire.
    There are other things one can do including how you load the stove. For example, don't just throw the wood in but try to get it as tight as you can. Those big air spaces do not add to your warmth. Another I do is to rake any coals (as much as possible) to the front of the firebox. Then for that bottom rear piece I like to place a fairly large piece (a square piece works best) then fill as normal. That seems to be a key to longer fires.
    I hope this helps. Good luck.
    Stephiedoll, Chvymn99, Horkn and 9 others like this.
  20. Locust Post
    Was 11 at 7 a.m. Now down to 8/70 in with the NG boiler circulating. Have the stove loaded with ash and something that was rock hard, heavy and barkless. Work started giving us the option about 3 years ago to take MLK day off, no argument here.
