  1. Sirchopsalot
    Sirchopsalot
    medium city in CT
    I was just thinking the same thing....all our warm weather hoarding, tool using, stacking.....racks, all the months of work....the discussions and note comparing. So worth not turning the thermostat up, the heat of a hot fire on a cold day...
  2. Sirchopsalot
    Sirchopsalot
    medium city in CT
    First frost here too. Hard frost in Gardner MA, less so in Worcester, more in NE CT.
    Moon was awesome last night.around 20:30 20231101_203008.jpg
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    If I could I'd give this more than one like! There's nothing that compares to the heat a wood burner puts out. It just feels different, better. I'll keep CSS wood until I give out.
    Loading up the Lopi
    Mike in Okla
    Sirchopsalot, Chvymn99, Sean and 12 others like this.
  4. JDU
    JDU
    Perry County, PA
    Have been starting a fire in the evenings for a while now other than last week when it was 80. Last night was first "overnighter" fire in the insert.
    25 this morning, house was 67 when I got up to go hunting. Felt good. Burning oak and cherry.
  5. Chud
    Chud
    NC
    I got home from work and the house is 61 so I’m burning oak like it grows on trees. :thumbs:
  6. Horkn
    What model quadrafire? We really like our 4100i bowfront insert.
    I don't know you really, so I'll bring this up as gently as I can, but a tv above the fireplace is literally the worst place to put a TV, especially when there are fires in the FP,/ stove. The angle you need to look up is bad for your neck, the heat from the fire is really bad for the TV, and the fumes from the extra hot plastics are bad for any living creature to breathe.
    Is there any other place that the TV can go? There's some really nice arm mounts that allow a lot of options. We put our TV on a wall mount a couple of feet to the side of our insert/ FP.
    -Tom, your neighbor in Ozaukee county
  7. Dunmyer mowing llc
    Dunmyer mowing llc
    Indiana
    Had 2 cracked firebricks towards front. Replaced front 4 with Rutland brand fireclay rated for 2700f. The replacement brick was way way heavier than factory. Probably will eventually replace all of them with the Rutland brand. Loaded up a mix of a bunch of stuff for overnight. Got 66f inside right now
  8. Locust Post
    39/72 burning a mixed bag tonight.
  9. thescratchylens
    thescratchylens
    Rock County, Wisconsin
    Same weather report as here in Rock County. We just couldn’t resist, even though we didn’t NEED a fire tonight. Burning buckthorn and mulberry chunks.
  10. thescratchylens
    thescratchylens
    Hi, Tom -
    No need to be too gentle - we’re not wilting violets here! The fireplace was non-functional when we put the TV up. We moved in a few years back and had no functional fireplace until last night. Anyways, right now, the mantle is warm to the touch underneath, cool on top. The wall under the TV is cool. The bricks right above the firebox are pretty hot close to it, warm just under the mantle. We’ll likely install a non-wood, more modern mantle, um-ah-erm eventually (translate: when we can afford it).
    Despite the photo, we actually don’t watch much TV in this room. Music mostly. The room where we DO watch the tube has a much older TV. I’ll discuss your suggestions with The Wife. We could just as easily hang a picture over the fireplace and upgrade our TV in the other room.
    Thanks for the good advice.
    Oh - and it’s an Expedition I. One of only two models that would fit into our 70’s prefab fireplace.
  11. Horkn
    Fully understand the situation. My vote, though it won't count in your house ;) , is to put a picture above the mantle and relocate the TV. :)
    What surround did you go with, whenever it shows up?
    Here's my quadrafire 4100 with Hayden soaking up the heat.
    Ron T, Chvymn99, Cash Larue and 9 others like this.
  12. thescratchylens
    thescratchylens
    It’ll look like this: IMG_0758.jpeg
  13. BuckeyeFootball
    BuckeyeFootball
    Did they wire the blower switch on the wall correctly? That would be my guess and not the snap disc. I know my installer had to write specific instructions for the electrician for my Quad.
  14. Chud
    Chud
    NC
    28 red and white oak. Back to milder temps for a week. TGIF
  15. The Wood Wolverine
    25 here, 70 inside. Reloaded with more red oak. :shiver:
  16. thescratchylens
    thescratchylens
    I really like the 3-pane design on that rig. Hopefully they're not a “pane” to clean.
    Thank you. I’m here all week. Tip your waitress, try the veal.
    ps beautiful lab.
  17. thescratchylens
    thescratchylens
    Oh, the problem was ME and my impatience, coupled with being a newb. Once the box got up to temp, the blower functioned perfectly. Thanks for the reply!
  18. yooperdave
    That's right......above freezing! All night it was above freezing!
  19. KSPlainsman
    KSPlainsman
    Kansas
    44/75. Stove is still warm from 12 hours ago, so I'm not reloading it for the day.
  20. Sean
    Sean
    Same here yooperdave. It was 1c/34f here at 6 am. I loaded a modest load of doug fir to chase away the dampness. I swear the house feels colder when its right around freezing then it does when its 10 below. I had a chill all day yesterday so hanging out by the wood stove was heavenly.
