  1. JCMC
    JCMC
    Just outside of Shushan, NY
    10* this morning Red Oak and Hard Maple in the OWB last night in anticipation of the cold 70* in the house.
    You need to put some more wood on the fire!:whistle:
  2. BigPapi
    BigPapi
    The hills of Western MA
    18 here, red maple and pine for right now, red oak for overnight. Little light snow falling.. Pretty out here!
  3. lukem
    Boiler throwing some good sparks out the stack during a reload. It be like that with hedge.
  4. Well Seasoned
    Current temp 3°F, and its not even 9pm yet- supposed to go down to 6°F, they are already wrong! Anyway, about to put the night load of birch in.
  5. amateur cutter
    Thank you, & it's very good for my needs. Have worked long & hard & had much time to think it out, so it works very well for my needs.
    :handshake: Thanks Dennis, & right back atcha!
  6. amateur cutter
    15F & dropping here, no wind & clear. Another beautiful night. Boiler full of 5-6 yr Oak tonight that got moved up out of the archives today. Heat load is very moderate with no wind, I'm interested to see how long this load runs.
  7. lukem
    Wind kills my heat load too. Last winter I could go down to -15 with no wind and the wood stove could keep up. 10 degrees with a 10 Mph wind and the dino burner kicks on.
  8. HDRock
    28 today , Cooling right down now 16 at 11 PM , They say low 14 tonight .
  9. JohnNH
    JohnNH
    Oregon
    11 outside/61 inside this morning - currently burning some small splits of maple - house is quiet & coffee is on
  10. LodgedTree
    LodgedTree
    Maine
    We are currently at 0 degrees which is bad.
    My other home is unoccupied, but heated, and has been sucking down the propane. So much so that yesterday it had 0 in the tank. We called for a fill-up, but they only come once per week, so we put the thermostats on geothermal setting and hope that we can coast through until Monday. I did shut the breaker off to the water oump though so that if a water line separates, it will not flood the house.
  11. LodgedTree
    LodgedTree
    Maine
    My own house is freezing...maybe 65 in here with the @#$%^& pellet stove almost running full-throttle. We will limp through winter with it, but it is stupid. I got 30 years of dry firewood and I am buying pellets only to freeze to death. Every day I hate pellets more and more and more.
    On a better note, I did get my basement fixed so it is operating at Neutral Thermal Inertia. That means it has no temperature swing. Using insulation in the right spots I was able to use the ground to heat the basement enough so that I do not have to light a fire in the basement stove to keep the pipes from freezing.
  12. Locust Post
    16 outside this fine Lord's day. Burning down coals from a load of locust and sugar maple. 34 forecast for today.
  13. Maina
    Maina
    Maine
    8 OAT, 74 inside at 6 am. Some pine on the coals. Cold week ahead
  14. Well Seasoned
    4°F here this morning, heading all the way up to 29°F! Burning birch at the moment, gonna head to Conway for some Christmas shopping and a lunch. Later on, Gonna bring in 4 wheel barrel loads of wood & put up the tree. Enjoy your day everyone!
    Maina, BigPapi, Thor and 8 others like this.
  15. OldJack
    OldJack
    Saskatchewan, Canada
    6°F / -14°C this morning. DED Elm in the ancient Enterprize cook stove. Some electric and oil heat to help it out.
    200 miles south of saskwoodburner.
    Maina, BigPapi, Slocum and 6 others like this.
  16. Gasifier
    19 F here. Pine and Maple in the boiler this morning.
  17. yooperdave
    18f but the feel is at 8.
    Another sunny day on tap for this area. I'll send it east shortly!
  18. clemsonfor
    35 here been raining for over a day straight. Several inches of rain so far. Yard flooded. The upper part of the state around Anderson, Clemson, Greenville have a few inches of snow.
  19. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Low of 8 last night, sitting at 11 right now. Had a later reload than normal last night around 10:15, normally do it around 7:30, so it was still at 73 when we woke up this morning. 72 now but the sun is out fully today with a high of close to 30 predicted. The house should hold temp with the solar advantage today. First time we will be seeing the sun all day in at least 2 weeks.
    Reason #54 of 110 I love my IS, is in a case like this I can close the air tight and it will hold the coals until I decide to reload tonight. Open the air rake everything forward and in 10 mins all the coals are glowing red hot load it up and poof off goes the old 3.5 yr dry oak (thanks to the great info from people here when I joined or I'd be burning what I cut this spring). Happy Sunday Funday everyone!
  20. lukem
    Boiler ate quite a bit of wood last night. Sun is supposed to come out and stay out today...weird.
