  1. Gasifier
    Wow. That is pretty cold for where you are this time of year. I use to live near Roanoke many years ago. And work in an area called Amherst. Nice area!
    ailanthus likes this.
  2. supersparks
    supersparks
    West Bend, WI
    Got the gasser going tonight 175° burning ash 42° and windy outside. Voted then went for tacos and beer 170° and still full of wood when we came home. 20141104_171943.jpg
    milleo, coal reaper and Gasifier like this.
  3. Gasifier
    Nice. And welcome supersparks! What kind of gasser to you have?
  4. Gasifier
    45º here this morning. Wow. I have some Ash and Spruce burning in the Gasification boiler for showers and a little heat from the bottom of the house up. :thumbs:
    HDRock and clemsonfor like this.
  5. lukem
    Burning some hedge and oak...did a half load last night and it was still going strong this AM.
    Wood consumption compared to last year is way down...so far.
    Gasifier likes this.
  6. Sam
    Sam
    Southern Minnesota
    I've had a few fires already this season as the temps dipped into the low 30's at night. I've only lit the upstairs stove so far which is an older Lopi Answer that sits right in the living room. To keep the temps in there reasonable I've only been burning hardwood slabs. They're easy to re-light if it goes out and they still don't burn outrageously quick.
    HDRock and Gasifier like this.
  7. HDRock
    No fire yesterday ,stayed 68 inside all day 59 outside , 63 in the house this morning ,lit up some shorty's and chunks of ash
    Drvn4wood, Shawn Curry and Gasifier like this.
  8. Sam
    Sam
    Southern Minnesota
    I love how it looks when it's burning juuust right!
    Drvn4wood, milleo, HDRock and 2 others like this.
  9. clemsonfor
    Welcome sam
    Sam likes this.
  10. HDRock
    Welcome aboard FHC Sam
    My daughter has a lopi answer, they only use it once in awhile it was in the house when they bought it.
    The air control is very hard to move in and out, just wondering if you have that problem at all.
    It may be due to the fact that they don't use it much, anyway I'm not sure how I can fix it.
    Anybody else got any ideas how to fix it?
    Drvn4wood and Sam like this.
  11. Sam
    Sam
    Southern Minnesota
    I'm not a fan of the air control as it is hard to move in and out even with plenty of use. Combine that with the fact that it's almost impossible to tell someone else where to set it at other than "pull it all the way out" or "push it all the way in" since the throw is so short and there's not a good way to mark the handle. I've been toying with changing it to a side lever type, attached to the push-pull, so I can mark different settings for the wife and children.
    Drvn4wood and HDRock like this.
  12. HDRock
    I put marks on my air control rod not long after I started burning with my Lopi Republic 1750.
    I took a 3 sided file and filed in fine lines in the rod on one side and then filled in the grooves with a fine line white paint stick It's been a year now and they don't ware off.
    The first mark by the stove is the half way point ,the last one toward the end of the rod is fully closed.
    What's up with the answer ? the control seems backwards ,push in for more air ,pull out for less ?
  13. Sam
    Sam
    Southern Minnesota
    That seems like a great solution to the question of where is the stove set. The only downside I can see is that it's right down under the ashtray on my stove but that's not horrible either.
    You're right, the Answer is backwards then, all the way out is no/low air and all the way in is full air.
  14. HDRock
    Mine isn't to hard to see , My hearth is a foot high ,so the rod is like 20" up from the floor
  15. Gasifier
    It was warm yesterday and then cooled down a bit last night. Right at 38º this morning. Some Ash and Spruce going in the boiler. Looks like some cooler temps to come in this weekend.
  16. Paul bunion
    Paul bunion
    My quad is the same way, I commented to the dealer when it was installed. His answer was to think of it as a gas pedal and all my conceptual misconceptions were solved.
    HDRock likes this.
  17. nate
    nate Banned
    Palmer, AK
    Was hot yesterday, got up to 31*! I almost started sweating with just a sweatshirt and jeans.
    clemsonfor and HDRock like this.
  18. HDRock
    It seems normal if you think of it that way :thumbs:
  19. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Little chilly tonight so I tossed in a decent load of ash.. Much better down in the basement now.. 1415320857003.jpg
  20. thewoodlands
    thewoodlands
    We're still burning Hemlock, White Pine with some Bigtooth Aspen.
    Shawn Curry, HDRock and Gasifier like this.
