Cleaning up the yard
Discussion in 'The Wood Pile' started by Chud, Nov 14, 2021.
  1. Chud
    Chud
    NC
    It’s been standing dead for 3yrs and splits are going to be single row in the sunniest hot location of my yard. Do you think it won’t be ready? I can push it out 2 or 5 years if I have to. I’ll check a piece with the mm today and post up current level.
  2. The Wood Wolverine
    If you say it will be, I have no doubt. :coldone:
    Eric VW, amateur cutter, Chud and 2 others like this.
  3. SimonHS
    SimonHS
    Yorkshire, England
    Your truck looks real close from that angle!
    Would the tree have reached it, had it fallen that way?
  4. Chud
    Chud
    NC
    Yes it would have cut it in 2 if it went that way
  5. Chud
    Chud
    NC
    Fresh split readings
    An hour after split
    on its way to 17% in October
  6. TurboDiesel
    Chvymn99, Eric VW, eatonpcat and 4 others like this.
  7. Chud
    Chud
    NC
    Staying away from firewood making today, so I tore into the 272 for a look. I could hear a muffler bolt had come loose and I wanted to look at the piston to rule that out as the culprit of bog under load. To my relief the piston and cylinder looked good. When I went to disconnect the plug wire discovered the plug was loose. Hopefully that was the cause of hard start and no power in cut.
    One bolt on top right would not come out of muffler bracket. It seems the nut inside muffler broke away. This is the $15 china muffler and bracket.
    Also have the carb kit ordered if it’s still not running right.
  8. Chud
    Chud
    NC
    Pilot Mountain on fire.
  9. Chud
    Chud
    NC
    My youngest is going to her first prom tonight and no prom is complete without pics at a woodpile. Her look cracked me up.
  10. Erik B
    Erik B
    Western Wisconsin
    That is a great pic Chud She exudes the sense of being daddy's little girl and very proud of it.:handshake:
  11. Chud
    Chud
    NC
    Have I ever told you how much I hate working in the rain. Me and the emergency response 261 and backhoe had it cleared in no time.
    Shortleaf pine
  12. Chud
    Chud
    NC
    Some pics of a big chunk stash that is not in my yard. Maybe haul some home tomorrow while the ground is still firm.
  13. Chud
    Chud
    NC
    Is there a resolution or zoom limit on pictures?
    I get a security warning on some. It seems to be anything that I zoom in.
  14. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    same here.....like if i take a pic of a saw sitting in the gravel parking lot ill have to zoom out or resize it....almost like too much going on with the pebbles
  15. The Wood Wolverine
    Yes, there is a size limit. Not zoom but over all size. I'm not exactly sure what it is but if I use my works phone for pics, they exceed that limit.
  16. Chud
    Chud
    NC
    Got a little bit done today. This white oak has been laying in the yard so long it’s growing fungus. A lot of it is knotty, so the extra seasoning helps when splitting.
  17. Chud
    Chud
    NC
    Living the dream albeit rather slowly. Made another pile of mostly straight white oak sticks.
    742DCAEA-93FB-4154-8974-161748C5A8CA.jpeg 3DF69EF3-2D89-4172-8D6B-6B3595F3017F.jpeg
  18. The Wood Wolverine
    Oak is such a pleasure to split. Usually only a few inches with the wedge and pop. :dex:
  19. Chud
    Chud
    NC
    Yes and the bark is falling off so it’s even better.:coffee:
    It’s going to be a struggle to fit in some personal hoarding time over the next couple days. :stacker:
  20. The Wood Wolverine
    I agree. I needed a little break though. We'll see how long I can stay away, lol.
