Clean up begins.
Discussion in 'Everything Else (off topic)' started by Gasifier, Apr 2, 2014.
  1. Gasifier
    I here that. These won't be over three feet. :whistle:
    thewoodlands likes this.
  2. Stinny
    Does NY require a permit for open fires when there's snow on the ground?
  3. Gasifier
    Noooooo. What a crazzzzzzy? :zip:
  4. thewoodlands
    thewoodlands
    I think each town is different unless your in the Adirondack Park, then you better have one.
    Some towns don't really care until something happens.
  5. Stinny
    In Maine, most towns require a permit after snow leaves. I keep a "really big" rock fire pit that I burn in. Always have a hose beside the pit. I don't ask about a burn permit, tho I know it must be quite a sight when I've had "3 foot" flames a few times… prolly looks like the back of the garage is on fire…. :D
  6. Gasifier
    Wow. Did I make a lot of work for myself. Moved a lot more branches today. I think I have about 90% of them piled. Probably 75% of them will be burned. I made two piles in the trees that I will leave as cover for the animals. Rabbits love them. Trimmed up some branches and made two areas so the pulling distance would be shorter that way. Going to rain tomorrow night and would be good for burning. Unfortunately I have to work. :( Ugh. Don't know if I will get home in time to light them off before they are too wet. Would be perfect for burning if I did. Snow still on the ground and raining. :yes:
  7. Stinny
    Tarp em. Get it ready to burn with lots of dry stuff under it… pull the tarp & touch her off. It might get hot enough with all those pine boughs to keep going…
    I do the same thing Gas. I burn any open piles when there's a drizzle or at least damp conditions. Good job today. Good luck burning… pics?
    Gasifier and savemoney like this.
  8. thewoodlands
    thewoodlands
    Will the flames be high enough that we can see it from Colton!
    Gasifier likes this.
  9. Gasifier
    I don't have a tarp big enough for one of the piles. LOL There is Pine (long standing dead and recently cut), Ash saplings, vines and brush. It will get hot enough and keep going. Just depends if I can be there at the right time when it rains some night. Going to rain tonight, but I don't know if I will be there at the right time.
    Stinny likes this.
  10. Gasifier
    You may see a mild "glow" from there. If you don't need your marshmallows burned, you may try holding them out off of your porch with a real long stick. I'll let you know when.
    Stinny and thewoodlands like this.
  11. thewoodlands
    thewoodlands
    I thought about burning on Sunday but everything (most) wood that's down around the house is still frozen in.
    When you decide to burn PM me, I'll turn the scanner on!
    Stinny and Gasifier like this.
  12. thewoodlands
    thewoodlands
  13. thewoodlands
    thewoodlands
  14. Gasifier
    Stinny likes this.
  15. Gasifier
    Small portion burned but the rain was too much. Oh well. Next time.
    Stinny likes this.
  16. Gasifier
    A little more work.
  17. HDRock
    Your rollin now man :axe: :tree:
    I wish I had your tractor :p
    savemoney and Gasifier like this.
  18. Gasifier
    Still snow in that area. I started cutting the sapling stumps down to the ground the other day. I would not hesitate to say that there must be several hundred saplings that I cut in these two areas I trimmed up and took several trees out of. I would say it is about the size of, oh, a 1/4 of a football field maybe. It is going to be some serious work with the chainsaw and my back! I have a strange feeling I will go through a few chains. :whistle: The chain, she no like-a the ground and a rocks. Eh. :zip: I need to get them all cut down as flat as I can with the ground as I can so they won't hurt the tractor tires. UGH!
    Stinny likes this.
  19. savemoney
    Me too! Only fun thing I have is a new riding mower. At least it is red!
    Stinny and HDRock like this.
  20. HDRock
    A big weed whacker brush cutter with a carbide blade, might be better on the back ,and save your chains, probably rent one if you don't have one
