Cinder Block Stacking Method
Discussion in 'The Wood Pile' started by Well Seasoned, Aug 3, 2014.
  1. Locust Post
    I've been using those retaining wall blocks like you see in my avatar. Solid all the way through and I have stacks 7' high.
    Well Seasoned, HoneyFuzz and HDRock like this.
  2. HDRock
    That's what I'm using 3 blocks per 8'
    Do you have vertical boards on the ends?
    Mine have been there less than a year , no sinking yet
    HoneyFuzz likes this.
  3. HDRock
    If your going to put uprights on the ends you gotta a least put end blocks holes up, or cross stack on the ends .
    Myself ,I don't like cribbing PITA
  4. HDRock
    What I like about stacking this way is very good air circulation 8" off the ground and single rows, so I stack the oak on these
    Woody Stover, papadave and HoneyFuzz like this.
  5. Well Seasoned
    Thx Hd! I read this after your post, but thanks to your earlier pictures I saw the blocks. I bought enough block/timber/2x4's for one rack (I needed deck paint anyway at lowes) quick threw it together and stacked a bit. Later in the week I will buy more to continue the existing 8' length, and get enough to make another 4 after that. Soon after, the oak scheduled for this year will be moved into the shed, opening up a rack to hold another 3 cords. Thanks for everyone's input!
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I like that alot !!! Maybe Ill use a few of Dad's spare block up for him :)
    Chvymn99, Well Seasoned and HDRock like this.
  7. HDRock
    Cool , you ain't messin around are ya ?
    Another thing I like , when they are empty you can easily move em if ya want
    Well Seasoned and HoneyFuzz like this.
  8. Well Seasoned
    Damm! I re-looked at your pic and I realized I put the 2x4's in wrong! :headbang:
    My "not messing around" will need to get reworked! Damm......
    12 hour shift today = sit your azz down after work. oooohhhho_O
  9. HDRock
    Yeah it's good to have the beam strength, or you could end up with some nice curves on the 2 X's
    HoneyFuzz and Well Seasoned like this.
  10. Well Seasoned
    Man, I thought my 6' was pushing it. :)
    HDRock, HoneyFuzz and Locust Post like this.
  11. Locust Post
    Don't want to take up anymore yard space than I already do, but if I haul in as much as I have for the last 2 winters we'll have to rethink that. :axe:
    HDRock, HoneyFuzz and Well Seasoned like this.
  12. HDRock
    Well mine isn't exactly straight now, I pushed some of top ones over
  13. Well Seasoned
    Yes...... well, from here on out I will. Ill be adding to that rack, sharing the far right cinderblock with another, giving me 16ft, so I
    Unlimited air space......
  14. Oliver1655
    Oliver1655
    Central Missouri
    While setting the blocks so the hollow spaces are pointed up will allow you better compression strength & the ability to insert uprights for racking the splits, I like to either have a 2" flat block underneath or will use a piece or 2 of treated wood to keep the block from sinking into the ground.
  15. Woody Stover
    Woody Stover
    Southern IN
    I like the idea but I think the blocks would settle too much in the soft forest soil....
  16. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Thats where the boards under the block would help keep them from sinking.
    Well Seasoned likes this.
  17. rdust
    rdust
    SE, Michigan
    In my softer areas I plan on doing this to help span the load when I have to re-stack/reload those racks.
  18. Woody Stover
    Woody Stover
    Southern IN
    This is my latest experiment. I went across the slope so the south wind will hit the stack broadside. Support is under the side rails; I'll stack two rows per pallet, each row over each side rail. If I went three rows per pallet, I'd want blocks under the center rail as well, which would require a lot more leveling on the uneven ground, but I might do that if I run stacks down the slope in another spot. I see I need to tilt that end block in so that the load bears on the side rail, not the cross-boards. :confused:
    billb3, WeldrDave, HDRock and 2 others like this.
  19. Well Seasoned
    Looking good!
  20. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Great idea !
