Chopping block pics. Lets see 'em
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Feb 10, 2020.
  1. KaptJaq
    KaptJaq
    Long Island, NY
    Been using the same one for a loooong time, stump of small oak.
    My processing area is slightly sloped and I can never buck perfectly square so it comes in handy that it is a little slanted. Just spin it around until the round stands up. I've had it soooo long I think it is now petrified.
    KaptJaq
    MikeInMa, Thor, FatBoy85 and 6 others like this.
  2. Road-side Oak
    Road-side Oak
    Southern NJ
    I have been using a stump from a pretty big pine that I had taken down about three years ago. It is very low to the ground so it’s pretty safe as far as miss-hits. Unfortunately it is finally starting to soften up so I will need a new block soon. A93E063A-C942-44C0-8497-B9D8BF2BB966.jpeg
    Thor, FatBoy85, metalcuttr and 2 others like this.
  3. billb3
    Wow, yeah, that sure looks like it has had some use.
    FatBoy85, metalcuttr and T.Jeff Veal like this.
  4. Holland Dell
    Holland Dell
    SW Wisconsin
    Amish satellite dish?
  5. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    When I split by hand this was my block. It worked well for me.
    Thor, FatBoy85, James Miller and 2 others like this.
  6. James Miller
    James Miller
    Hanover PA
    Don't know if these count. 20200217_165703.jpg Locust round in the driveway for splitting kindling. That whole tree measured under 15% on my mm when I cut it don't know why that round got saved from the fiskars. 20200217_171540.jpg This apple round had been sitting inside the front door for 25 years or better. I've often thought about taking a swing at it with the fiskars but its probably hard as concrete by now.
    I'm 5'9 so if I'm making firewood the rounds are on the ground.
  7. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    Been just spliting on the ground this year, but in years past when I split by the wood stove I have a pine log that I use.
    Been there for 3-4 years now, it's old, mud and water logged but does not crack.
    Thor, FatBoy85, James Miller and 3 others like this.
  8. mrfancyplants
    mrfancyplants
    South Carolina
    49965EBB-E108-4A3C-98E5-17D69D64A8E8.jpeg Not sure what mine is made of. I went through(broke) a few chopping blocks this year. I like them low so that if I miss or get deflected, it’s less likely to test the steel toed shoes out.
    Thor, FatBoy85, T.Jeff Veal and 3 others like this.
  9. FatBoy85
    FatBoy85
    Washington State
    I thought I had one or two pictures of the thing but guess not. I had picked up a couple of very large Weyland cypress cuts and these were some of the more harder rounds ever to split. They don’t pop or anything easily so its a matter of using the splitter to simply shear the wood apart, that’s about as good as it gets. Anyways I had help and we lifted some rounds about 18 inches across give or take, about 2 feet or so high. They would be great if they were just cut flatter as the cuts were likely near the base as a felling cut. With cedar being pretty rot resistant, it should hold up a lot longer than my previous doug fir block. I took that one to be made into a Swedish Candle. I’ll take pictures likely when ready to begin splitting again!
  10. FatBoy85
    FatBoy85
    Washington State
    Oh I like how you have that wood stacked up in that pull cart!
