Chinese Stihl 070 knockoff
Discussion in 'Chainsaws and Power Equipment' started by Uncle Augie, Nov 18, 2014.
  1. Hedgerow
    Hedgerow
    SW Missouri
    That is correct... It should run fat...
    Still not sure as to the "why" anyone would want to have to go through the hastle of chasing the alcohol out of a work saw...
    A race saw, sure... But a worker??
    clemsonfor likes this.
  2. SquareFile
    SquareFile
    somewhere
    Your supplying 20-25% more fuel with a unmodified carb on a craftsman saw...yes I still smell the 1066
  3. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    I only do that if I don't plan on using the saw for more than 2 weeks, but I only messed with it once so I don't know if I'll be running the saw again until the summer, or just switching back to pump gas
  4. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    Do own the saw in question? We already know you have no experience with E85 so are talking from where exactly? Oh yeah the place that fills that 1066.:smoke:
  5. Freakingstang
    Freakingstang
    I read that... what I said HMMM about was not having to mod the carb for 25% minimum more fuel on E85? most carbs sized for whatever engine won't flow enough to support the volume E85 needs without installing a larger carb, or drilling it out. with more fuel you need more air. so hmmm was about that, not about flushing the lines out. although at partial throttle or idle, not sure, unless you are running it WOT with your splash.
    I agree, for a work saw it sounds like a serious pita, but a play saw, it could see huge gains, if done properly. but having it set up ideally for corn isn't going to be very optimal on pump gas, not unless retuning and retarding timing is a quick fun thing for you to do.
    clemsonfor and bigbarf48 like this.
  6. Hedgerow
    Hedgerow
    SW Missouri
    And if a person wants to feed more fuel and see real gains, an oxygenator additive is used in race saw blends...
  7. SquareFile
    SquareFile
    somewhere
    I do not nor would I have the saw in question. I do not have any experience with E85. I would rather eat food not burn it.
    I have experienced you starting threads on this section IMHO looking for a argument but then not proving anything.
    clemsonfor and Pyroholic like this.
  8. SquareFile
    SquareFile
    somewhere
    The only reason I responded to this thread was because the OP quoted a knowledgeable member out of a different thread into this one. It was uncalled for and out of line. Do your own test and give us feedback. That 1066 is still overwhelming. I call BS
    Hedgerow likes this.
  9. Hedgerow
    Hedgerow
    SW Missouri
    I look at it like a novelty, rather than a legitimate option..
  10. basod
    basod
    Mount Cheaha AL
    instead of turning this into an A-site thread (understandable with the animosity already exhibited)
    Is it possible we search for positive alternatives for a milling saw? There are a bunch of old saws out there that will serve you well Augie - no need to go for a knockoff saw with technology 40-50+yo
    This saw regardless of chain sharpness will be slow and shake you to pieces - just cause it's "new" don't mean the tech in the saw is any better than what was built in the original.
    Seriously ask for input on the old mag saws that have grunt for a mill - might have a few more bills in one but if needed they will come back to you...real stihls hold their value;)
    thistle, Certified106 and bigbarf48 like this.
  11. bigbarf48
    bigbarf48
    Stone Mountain, GA
    This is good advice
    If you just want the 070 for the sake of science and the heck of it, I'd say go for it. I'm interested in seeing one. But if you really just need a saw that you can hook into your mill and go to work, you may be better served spending a bit more upfront for a used saw that'll be more comfortable to use, more reliable, and likely better built. I would imagine that increased initial investment would payoff over the years if you plan on milling a lot :thumbs:
  12. DexterDay
    DexterDay Administrator
    Northeast Oh
    A good 70 cc-90 cc saw can be had for under $500. If you look and search really good? Then you can find one for much, much, much less than that.
    I would much rather have an old 056/076, or a 2100/385.
    Not knocking your idea Augie. But modern saws are a lot better than the 070.
    Yes, I have bought and owned a fee Chinese saws. I have since sold them. Long ago. With the saws I have? There is no room for them.
    thistle and bigbarf48 like this.
  13. clemsonfor
    I passed on a decent 056 a while back. Not minty but not beat. I do think it was $375 with an original old stihl like 28/32" bar. Just didnt need it since I own a 650.
  14. NewToStihl
    NewToStihl
    Central Indiana
    I've been keeping up on this thread and I'm glad it (apparently) has taken a better path. So, I figured I would throw some of my cents out for the heck of it...
    I have no experience running or even inspecting a Chinese knock-off Stihl. I'm a huge fan of the 1106 series Stihl saws for novelty/collector purposes, so I have read a lot about the counterfeits. I think your approach is sound; pull it apart and check things out before going balls to the wall. I also think your statements about potentially good quality soiled by poor quality control are also sound. Bottom line is that they will never equal the quality of the original for many reasons (e.g. poorly trained employees, inferior materials, insufficient/nonexistent R&D, low-cost manufacturing by design, etc.), but that doesn't mean they're a waste of time & money as long as one understands and accepts what they're getting into. Frankly, in my opinion it's no different than buying a big box store chainsaw of virtually any brand.
    Because I love running my 070/090 saws for recreation and have always been curious about how the knock-offs compare I've been tempted more than once to buy one. I have never pulled the trigger though because I strive to minimize purchases of any new imported items and have never come across a good used one.
    Now, regarding what the folks are saying about seeking out other options; with a heavy heart I would have to agree that it's worth looking into. The 070's are physically large, heavy, slow, and loud. However, I don't know the first thing about milling, so I would pose one question; does the quality of the product vary at all with chain speed? I'm only asking because there could possibly be some validity to wanting to use a 'slower' saw?
    I don't want to turn this in to a classifieds ad, but if you're truly interested in that format of saw for milling and want to do it on a budget PM me and perhaps I can help you out.
    Cheers y'all!
  15. DexterDay
    Northeast Oh
    Good on you bud! You better take him up on that offer Augie. He will be slammed with PM's momentarily.
    NewToStihl, clemsonfor and bigbarf48 like this.
  16. thistle
    thistle
    Polk/Guthrie Counties,IA
    When I got the 288XPW several years ago I thought it was the ultimate milling saw.Its incredible of course,but when I got the 2100CD & Mac 125C last year that theory went out the window.....:saw:
    I've never seen anything like the 125,equal in HP/torque to the legendary Stihl 090,but 7 pounds lighter with 3000 more RPM's 11,000 vs 8000 approximately. Its definitely not a ''slow old saw" by any means.
    basod, Oliver1655 and clemsonfor like this.
  17. Hedgerow
    Hedgerow
    SW Missouri
    The old mac's, in the right hands, can really haul the mail...
    No question!!!
    thistle, basod, Oliver1655 and 2 others like this.
  18. 94BULLITT
    94BULLITT
    Frederick County, VA
    So are you going to go with a knockoff?
    NewToStihl, bigbarf48 and clemsonfor like this.
  19. prell 73
    prell 73
    ia
    That thing is JUNK get rid of it
  20. clemsonfor
    Well did you get one?
