Chimney Sweep Tools
Discussion in 'Modern EPA Stoves and Fireplaces' started by jacktj, Jan 23, 2025.
  1. jacktj
    jacktj
    Delaware
    Thanks Everyone, I'll have to take a look at these options
    metalcuttr, wildwest and brenndatomu like this.
  2. WI_Hedgehog
    WI_Hedgehog
    Milwaukee
    Thanks for everyone's advice. I bought the name brand instead of the cheap knockoff thanks to members naming the original brand. As stoveliker said it's easy to unknowingly hit the Reverse button and strand the brush in the flu.
  3. wildwest
    Also try a couple different pairs of your shoes on you roof, some sole are slippery and some grip wet or frosted much better
    metalcuttr and brenndatomu like this.
  4. WI_Hedgehog
    WI_Hedgehog
    Milwaukee
    With the drill spider it cleans out from inside in 10 minutes according to one of the installers who was a chimney sweep previously.
    - Let the stove cool.
    - Push segments up the flue until tapping the cap.
    - Pull the spider back into the flue pipe.
    - Attach a [cordless] drill.
    - Turn on a shop vac to suck up the dust.
    - Spin up the drill and use a leather glove to keep the rods from hitting the stove where the bend up the flue would cause the rods to run against the metal.
    - Pull down slowly.
    That's supposedly all there is to it.
  5. wildwest
    cool, bottom up
  6. Highbeam
    Highbeam
    I use the sooteater and purposely flip the direction to drill forward on the way up and in reverse on the way down and I pump the head up and down as I go. In my mind I imagine that there are parts of the flue that will only get cleaned with going one way or the other.
    Like brushing your teeth in just one direction isn't as good as back and forth brushing.
  7. brenndatomu
    Yup, I clean on the way in, and on the way out...and some slow back n forth motion on each section of rod both ways too.
  8. beardley
    beardley
    Cato NY
    Do you guys run your drills in high or low?
  9. wildwest
    We used pellet stove 95% of the time and did not use a drill at all. Just some twist on the way up and again on the way down.
    MikeInMa, metalcuttr and brenndatomu like this.
  10. brenndatomu
    High gear for my Sooteater...but a wire brush I just push/pull by hand.
    But since putting in flex liners I always use the SE to clean
    MikeInMa and metalcuttr like this.
  11. beardley
    beardley
    Cato NY
    Yea sorry, I was referring to the sooteater folks. I run mine on high, but always thought it made a hell of a racket and wondered if I should actually be running it on low. I do it from the basement, so I have 12 rods clanking around in there at the top.
    brenndatomu and MikeInMa like this.
  12. cezar
    cezar
    KY
    I do pretty slow. Just enough to keep it spinning.
    brenndatomu likes this.
  13. brenndatomu
    A Sooteater?
    Spinning those slow will not clean much of anything
  14. cezar
    cezar
    KY
    Fast enough that the rods aren't banging into the liner.
    I keep going up and down with each rod section until nothing more comes out, so I know I'm getting it clean.
