Chimney safety
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Midwestjdgreen, Jan 17, 2018.
  1. Scotty Overkill
    The more insulated pipe, the better. Keeping those internal flue temps up is very helpful to a good draw and a cleaner flue!
    VOLKEVIN, WeldrDave and wildwest like this.
  2. wildwest
    Have your heard of a Daka Furnace?
  3. Scotty Overkill
    I've heard of it, but I can't say I've checked into what they are all about.....
    wildwest likes this.
  4. Midwestjdgreen
    Midwestjdgreen
    Sw mn
    wildwest and brenndatomu like this.
  5. brenndatomu
  6. Midwestjdgreen
    Midwestjdgreen
    Sw mn
    Any clue what it is?
  7. yooperdave
    Whenever I've seen a unit like that one, the blower motor has always been mounted on the back of the unit, never on the top.
    Guess the previous owner thought it would be a good idea to set up a downflow configuration...?
  8. blacktail
    blacktail
    PNW
    What are the walls made of? On my phone it looks like one is brick.
  9. Midwestjdgreen
    Midwestjdgreen
    Sw mn
    Walls are made of cast iron. I'll probably end up making a new hole, don't feel like burning the garage down. Just need to figure out how to patch the old hole. Had it fired up the other day and she gets plenty hot.
  10. WeldrDave
    An Edsel! :whistle:
    brenndatomu likes this.
  11. WeldrDave
    OK, I'll be the bad guy here.:whistle: Do you "REALLY" feel "Safe" installing that? Please don't take me wrong and I'm only looking out for you're safety. In the pic, Rear right corner it looks like pieces of rust falling out the bottom. Maybe you should have someone give it the once over or at least get a chipping hammer and tap around it to make sure she's solid and not going to burn through. Sorry for being a stick in the mud but you're safety is not worth saving a buck or two or possibly burning you place down at worst case scenerio.
    walt likes this.
  12. wildwest
    yooperdave likes this.
  13. Midwestjdgreen
    Midwestjdgreen
    Sw mn
  14. Midwestjdgreen
    Midwestjdgreen
    Sw mn
    No worries. No it's nice and solid yet, no holes, I have a chipper and will probably paint it up someday here. I'm just using it to heat my old garage so I can screw around in there during the winter. Kind of just doing it for fun.
  15. wildwest
    Hee Hee no worries, seems others did too. Interesting they say its an add on for forced air. I was hoping someone knows more about these.
  16. blacktail
    blacktail
    PNW
    The shop walls?
  17. oldspark
    oldspark
    NW Iowa
    Where does the air come out from the blower, looks confusing in the picture.
    As long as it's a nice solid stove I would not be concerned with the surface rust, stoves like that look like crap in a picture.
  18. yooperdave
    Looks to me as the blower is mounted to the top of the stove...typically where you would tie it in to duct work.
    If this is correct, and the blower is not just placed there for handling, then the blower would blow down and out the back end cut out (where the blower used to be mounted)...or maybe the whole bottom of the stove shroud has been removed also.
    WeldrDave, brenndatomu and wildwest like this.
  19. oldspark
    oldspark
    NW Iowa
    That makes sense they just wanted the air to come out the back versus the top.
    WeldrDave likes this.
  20. bushpilot
    bushpilot
    Eastern Washington
    I was thinking the same.
