Chimney Questions
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Aug 8, 2015.
  1. Canadian border VT
    papadave, is right but if I remember right you are going through the wall. most of those kits you can do from the ground. another reason to go higher. my rods screw together push brush up when close to top rotate pull back down less than 10 minutes only go up on roof once a year to check flashing clean cap..
    Chvymn99 likes this.
  2. Kimberly
    Kimberly
    The Kangaroo State
    So I get the metal round brushes? I don't want to damage the chimney by using the wrong type of brush. The chimney will be of the ground in the back so I think I can push the brush up from the bottom clean-out port without climbing up on the roof.
    wildwest, papadave and Eric VW like this.
  3. Chvymn99
  4. Kimberly
    Kimberly
    The Kangaroo State
    wildwest and Chvymn99 like this.
  5. HDRock
    Product Description
    The Sooteater RCH205 Rotary Chimney Cleaning System cleans wood stove and fireplace flues. Spinning chimney whip removes dangerous soot and creosote buildup better than a brush. Helps prevent flue fires. Unique trim to fit design fits multiple flue sizes. Will work on round from 5 to 18-Inch in diameter; 12=Inch x 12-Inch square, rectangle or oval flues up to 8-Inch x 12-Inch. Won't scratch metal flues like a steel brush. Fits through tight areas. Fits on any drill and spins forward and reverse. Cleans from the bottom up without getting on a ladder so you can DIY and save money. Includes (6) 3-Feet long flexible rods with reversible bottom link quick connect system.
  6. Eric VW
    If you come thru the wall and run to a Tee to go vertical, you can uncap the bottom side and run your brush up that. My dad uses this technique.
    Edit: Guess I should have started reading posts from the top of the page... You've got it figured out, Kimberly :D
    Chvymn99 and wildwest like this.
  7. HDRock
    Don't forget you still need to clean whatever horizontal run you have.
    Chvymn99 and Eric VW like this.
  8. Eric VW
    So true, HDRock, I forgot to include that!
  9. Kimberly
    Kimberly
    The Kangaroo State
    Do I have to dismantle the pipe? If so, how often?
    Eric VW and wildwest like this.
  10. Chvymn99
    Elbows will probably require you to dismantle. From the stove to the wall should not be that big of a deal to dismantle. Being a first year wood burner... At least once a month for a while. Till your wood and operating skills are up to par. Then I'd say bare minimal of twice a year for peace of mind.
    HDRock and Eric VW like this.
  11. Eric VW
    If your Tee isn't horribly tall, you can use a mirror and flashlight to look back towards the stove along the horizontal, from outside...
    I check my chimney this way from the clean out door in our basement- saves a lot of time!
  12. mike holton
    mike holton
    Old Dominion
    click here http://www.heatredefined.com/englander/stove/Englander-1200-1800-Sq.-Ft.-Wood-Stove then scroll to the bottom look for "Manuals" click it and a PDF of the manual should open on screen
    wildwest and HDRock like this.
  13. mike holton
    mike holton
    Old Dominion
    sorry I was late to the party, there is no "required" minimum rise before horizontal on our units though I usually encourage at least a couple ft if there's room to help get the exhaust column moving earlier on cold starts, helps reduce smoke spillage on cold starts.
  14. Kimberly
    Kimberly
    The Kangaroo State
    Thanks for taking the time to come in with this information, I was not even thinking about the smoke part.
    wildwest and mike holton like this.
