Chimney problem?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Paul Dokken, Jan 21, 2021.
Tags:
  1. Canadian border VT
    For 2500 I’d rent one
    mat60, Rush Battle and brenndatomu like this.
  2. chris
    chris
    SE WI
    the lift rental would be much better and a long shot safer than ladder. Those twist loc connections can be somewhat cantankerous at times and on a ladder:whistle:
    mat60 and Rush Battle like this.
  3. brenndatomu
    I'd just unbolt the wall mounts and then take an angle grinder to the bottom, fell the whole thing like a tree! :whistle: :rofl: :lol:
    Eckie, mat60 and Rush Battle like this.
  4. Rich L
    Rich L
    Eastern Mass.
    Has it been determined yet that the other sections are faulty.From the pictures there seems to be some good sections of pipe.
    mat60 likes this.
  5. brenndatomu
    I'm not sure, but after looking at those pics, and if it has really endured several chimney fires, I'd want to replace it all...really looks to have some age to it too...
    fox9988 and mat60 like this.
  6. Warner
    Warner
    For me it would be all or nothing. The system would be all the same age no changing out pieces here and there.
    It’s like splicing a brake line when it pops. Replace the line from start to finish or find someone else to do it because you will be back shortly with another leak.
    NVhunter, brenndatomu and mat60 like this.
  7. Rich L
    Rich L
    Eastern Mass.
    If the pipe does need to be replaced I wouldn't go with that brand.I wonder are those rust spots starting from the outside of the pipe or the inside.My metalbestos is twenty years old with no rusting.My Hart & Cooley which I gave to a friend was in great shape and older than the Metalbestos.I'd like to know the cause of those rust spots and the brand of pipe.
    mat60 likes this.
  8. jo191145
    jo191145
    Ct
    I’m not a pro at metal chimneys but many of them can leak when I properly installed. The water gets in between the tow separate layers, soaks the insulation causing it to sag/compress inside and prematurely rust.
    Rich L and mat60 like this.
  9. jo191145
    jo191145
    Ct
    Are you saying a propane and oil appliance both vent thru the same flu? Didn’t think that was legal.
    mat60 and MikeInMa like this.
  10. MikeInMa
    Yes. Both were already tied into the old tile lined flue. So, they still are.
    mat60 and jo191145 like this.
  11. jo191145
    jo191145
    Ct
    Don’t tell anybody ;) :)
    MikeInMa and mat60 like this.
  12. MikeInMa
    Multiple plumbers, oil burner service people, and chimney service folks, all licensed, have worked on connections over the years. Everything is legal.
  13. brenndatomu
    Multiple connections, as I understand it, is not actually illegal, just not recommended, and not done that way anymore...as in if anything major needs to be redone, a HVAC professional would tell you it can't be put back the same way...probably recommend that the gas appliance be switched to HE, so it can be "side vented" using PVC pipe.
    MikeInMa likes this.
  14. MikeInMa
    The entire oil burner/furnace was replaced a few years ago. Licensed professionals involved. No mention of any preferred alternatives.
    Thanks for info.
  15. Canadian border VT
    Here you can have two in same flue as long as are similar fuels. Oil and propane ok. Oil and wood. NO
    Something about fuel deposits reacting with each other.
  16. brenndatomu
    When I installed my old Yukon Husky wood/oil/coal combo furnace in 2012 it was recommended to use a 316ti SS liner...it's rated to handle the nastiness from the combo of the soot from those 3 fuels...the Yukon is gone, the liner remains. :)
  17. chris
    chris
    SE WI
    Solid fuel units require a separate flue per appliance, Oil , NG/ LPG - can use same flue- but codes change with time and it is possible that oil now may require a separate flue.
    Canadian border VT and MikeInMa like this.
