Chimney Damper?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Well Seasoned, Feb 7, 2015.
  1. ailanthus
    ailanthus
    Shenandoah Valley, VA
    Oh, and avg probe temp in my flue is ~500°.
    Well Seasoned likes this.
  2. Certified106
    Certified106
    In The Hills
    That seems a bit high to me. Mine are usually below 600 on probe thermometer. Mine can get to 800 but I usually have to be pushing the stove to get them there with the air above a 1/4 of the way open on a full load.
  3. oldspark
    oldspark
    NW Iowa
    No I dont think so, they are tested with dry material.
  4. oldspark
    oldspark
    NW Iowa
    My guess is the only way you will find out is to try it your self, I had a Summit that ran high flue temps and low stove top temps and I tried a damper but it basicly did nothing, the Drolet I have now works so well I dont feel the need for it,
    At 600 stove top my flue temp is right about 300 (surface) which is way lower then my Summit ever ran on the same chimney.
    I have a pre EPA stove in my shop and I use the damper all the time.
    HDRock and Well Seasoned like this.
  5. Well Seasoned
    I think I will record the data for the rest of the season, wood species, indoor/outdoor temps, load size, weather, winds etc install over the summer and record new data next season.
  6. sherwood
    sherwood
    Look forward to seeing your results.
    If they are anything like mine, you won't need to keep those records after a few days next burning season.,
  7. oldspark
    oldspark
    NW Iowa
    So what do you run for flue temps, both before and after? That's amazing you can keep it closed most of the time, you must have one heck of a draft.
  8. sherwood
    sherwood
    400 degree stovetop at the moment, flue 560. Previously, that flue temp would have been about 720.....
    500 - 525 stovetop previously, I was running flue temps around 800. Now, 620 to 650.
    Big difference.
    splitoak and Well Seasoned like this.
  9. prell 73
    prell 73
    ia
    Sweet. What do u guys think about a barometric damper??
  10. oldspark
    oldspark
    NW Iowa
    You must have a strong draft, taking into account the difference between my surface temps and your internal without a damper my flue temps are as low as yours (or lower) for the same stove top temps. I only have about 18 feet of chimney so draft is about right for my stove.
  11. HDRock
    My pipe only occasionally gets up to 400 surface temperature (SW pipe) during a reload but I dont allow it to stay there very long. Running 400 surface temperature all the time would not be acceptable to me that would be like 800 internal
    I generally run around 325 surface temperature with a 625— 650 stove top.
    pipe and chimney only adds up to about 15 feet , straight up , the stove pipe is 6 inch and about four and half feet the chimney is 8 inch, draft has never been a problem.
    The only problem I've had with this stove is when the door gasket was screwed up and it wanted to get too hot
  12. Machria
    Machria
    Long Island, NY
    Is there a link to the one talked about that replaces the "appliance adapter?
  13. concretegrazer
    concretegrazer
    Southwest MO
    What brand?
