Chimney clogged
Discussion in 'Modern EPA Stoves and Fireplaces' started by firecracker_77, Feb 16, 2025.
  1. MNWood
    MNWood
    Coon Rapids Minnesota
    Here is a link to the video iCloud Photo Sharing Before doing this I removed the door, the faceplate, the baffle plate and fire bricks that set above it and the damper/bypass plate. Fall 23 I poked a hole through the plastic for the sooteater rod, fall 24 I just ran it under the bottom edge as you see in the video. I think either way works when using the HEPA filter vac. Without the Vac I would go through a small hole. I am a serious do it yourself person. I nearly never pay anyone do to anything for the house or vehicles. Sometimes even get in over my head but this is fairly easy.
    metalcuttr, Chaz and brenndatomu like this.
  2. stuckinthemuck
    stuckinthemuck
    Looks like you are burning a couch, a chair, and most of your kitchen in there. Interesting perspective in the photo.
    metalcuttr, Ron T, Chaz and 4 others like this.
  3. The Wood Wolverine
    He did get into some of his oak. I split a piece and brought it home, let it in the basement for 2 hours.
    I’d say 70/20 mix of ash and cherry has been the norm though, little walnut in there too.
  4. stoveliker
    stoveliker
    Eastern Long Island
    Was that after resplitting so you measured on a freshly exposed surface to get the internal moisture content?
    metalcuttr, Chaz, brenndatomu and 2 others like this.
  5. The Wood Wolverine
    That’s the only way to get a true reading. :yes:My mm says to let the piece reach room temp, hence the 2 hour time frame.
  6. brenndatomu
    I've never seen a mm with the sample temp on it like that before :yes:
  7. Canadian border VT
    Assuming MM measures change in resistance so Temperature wood matter; good pun there.
    Also fresh split face due to drying process.
    In short the man’s doing it right
  8. In the Pines
    In the Pines
    and where did you get that information from? Because the product I recommended specifically states it is safe for cat stoves or are we just spouting off myths?
    ACS Anti-Creo-Soot Creosote Remover | ChimneySaver
    Catalytic Combustors: Put in bypass mode before treatment and for 1 hr. afterwards
    brenndatomu and metalcuttr like this.
  9. stoveliker
    stoveliker
    Eastern Long Island
    The mfg of my cat stove. Blaze King.
  10. stoveliker
    stoveliker
    Eastern Long Island
    Also, I would rather trust the stove mfg or the cat mfg rather than the mfg of that stuff whose sole interest is to sell you that stuff.
    They may be right, but I'd run it by the cat mfg of your cat before I would put it in my stove.
    (Also, if you have a working cat and dry enough wood, how would you need anti creosote stuff...?)
  11. Pyromaniac
    Pyromaniac
    Central Michigan
    This year, I have transitioned to burning very hot fires (as in nearly full stat) in my Blaze King. This is for two reasons, first, we've had some darn cold weather, and second, on "warmer" days, I burn smaller, hot fires. My stove interior and pipe are ridiculously clean, best I have ever seen them. I don't feel I'm burning any more wood than I would be by packing it full and turning it down.
  12. Highbeam
    Highbeam
    Them telling you to "bypass" the cat during treatment tells us that their product harms catalytic combustors. Further, the stove designs I've seen with a bypass do not fully bypass the smoke around the cat but just provide an extra path in addition to the cat still being exposed to smoke.
  13. stoveliker
    stoveliker
    Eastern Long Island
    During and one hour after spraying it in ...
    brenndatomu likes this.
  14. BKVP
    BKVP
    Walla Walla WA
    Correct! Never use the logs in our stoves. They will result in over plating (yes even with bypass open). We have the lab, we have the engineers and the stoves have been tested to show this is the case.
    BKVP
    JimBear, brenndatomu and wildwest like this.
  15. cezar
    cezar
    KY
    I quit using the plastic. I have a George (fancy british wet/dry vac, but any will do if they have HEPA bags, and I just stick the hose at the entrance and run the thing while using the kit. Works fine and saves a step since I'm already vacuuming out the stove anyway.
  16. In the Pines
    In the Pines
    Is not the cat bypassed when the fire is first started until it gets rolling and the same when you rekindle?
    they recommend doing it with a fresh fire, so your cat is bypassed on initial startup anyway.
    ppl like to knock chit instead of reading and researching first.
    Maybe research the product instead of "tells us"
    wildwest, brenndatomu and MikeInMa like this.
  17. cezar
    cezar
    KY
    Or just pull the cats before use...
    wildwest and brenndatomu like this.
  18. brenndatomu
    Cat is "bypassed" as in it's not blocking the exit of the stove any longer, but also not isolated from the smoke either, so can still be poisoned
  19. Highbeam
    Highbeam
    No. The open bypass doesn't take the catalyst out of the smoke path, it just opens a second smoke path that some portion of the smoke follows.
    As far as your suggestions that people research the product. We have. It's poison to a catalyst. You made a mistake if you used this product in a cat stove.
  20. Highbeam
    Highbeam
    unfortunately, the BK design requires a new gasket each time you remove the cat. I've found no real need to use those log products if you're doing everything else right.
    wildwest, moresnow and brenndatomu like this.
