chimney cleaning quote
Discussion in 'Modern EPA Stoves and Fireplaces' started by Gweedo996, Dec 3, 2018.
  1. HDRock
    Seriously, if you have a straight up chimney a Brush and rods will do a great job :)
  2. Brad38
    Brad38
    S. Indiana
    I use a soot eater from the bottom up, and used this neat little hack I learned here a few years ago. Used milk jug and a shop vac, little to no mess!
    mat60, moresnow, Maina and 5 others like this.
  3. brenndatomu
    :tip:
    mat60, HDRock, Maina and 3 others like this.
  4. brenndatomu
    One thing I'll mention about that video, he didn't really use the plastic the way it is meant to be used...normally put the SE up the flue with a section or two of rod on it, then tape the plastic to the open firebox, threading the rod through a small hole in the plastic as you go. Then make a second hole to stuff your shop vac hose into.
    I clean going up, and then back down also...suppose if your flue is pretty clean, you could do one way.
    mat60, HDRock, Maina and 5 others like this.
  5. Gweedo996
    Gweedo996
    Oregon
    only pics i can find.. terrible pics but thats what i got atm moment.. No tubing to clean, should be straight up and out..
  6. Well Seasoned
    We charge 160 for wood stove, 185 for pellet. X2 soot eater.
  7. NYCountry
    NYCountry
    Mohegan Lake NY
    That's highway robbery, better start cleaning it out yourself , soot eater or brush , if its green wood your burning do it a few weeks apart, dry wood every 4 months to have a piece of mind
  8. Eric VW
    Good FHC help in this thread.... ya musta known you came to the right place Gweedo996 :yes:
    Chaz, mat60, HDRock and 5 others like this.
  9. Gweedo996
    Gweedo996
    Oregon
    I've been here a short amount of time, haven't been disappointed yet!! Great group of knowledgeable people here!!
    Chaz, mat60, HDRock and 6 others like this.
  10. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    I do my own now. I use a brush from the top down since I want to check everything up top at the same time Had three different sweeps that never did a good job. They never got all the crud off the smoke shelf in the fireplace, They never took out the ceramic blanket in the wood stove. (They are afraid of breaking the baffle boards) Most don't even get on the roof to check out the masonry crown. The one that did wanted to pour me a new crown for $1500. I got some crown coat five years ago and its still as good as the day I put in on. Good luck on finding one you can trust. (No disrespect Well Seasoned) I know you are one that can be trusted.
    mat60, Maina, Well Seasoned and 8 others like this.
  11. Gweedo996
    Gweedo996
    Oregon
    So there is more to clean then just the smoke stack.. Guess I'll be googling stuff today.. My insert is a bit old and not in current code, however it was within code when it was put in.. I don't recall the name of the system it uses to burn but the guy that inspected it said he doesn't see it very often..
    Amazon is on it, my new Sooteater will be here tomorrow.. However all cleaning will have to wait a day as I am going to Metallica!! :dex::dex::dex::D
    Chaz, Screwloose, mat60 and 5 others like this.
  12. HDRock
    Have a good time , big fan here, seen em a couple times :dex:
  13. papadave
    Aren't those guys like about 70 by now?
    Our son was a huge fan back in the day, which was almost 25 years ago.
    Oh never mind.......nothing really matters. :whistle::D
    Eric VW, Chaz, LongShot and 11 others like this.
  14. Marvin
    Marvin
    Huntingdon, Pa
    I see what you did there :thumbs:
  15. papadave
  16. HDRock
    Good one:thumbs:
    Chaz, Screwloose, mat60 and 3 others like this.
  17. Gweedo996
    Gweedo996
    Oregon
    LOL.. I saw them back in the mid 90's.. Never forget the guy running across the stage on fire!
  18. ReelFaster
    ReelFaster
    S.Jersey
    Mine just came in the mail the other night!!! Haven't used it just yet, but looks and sounds easy enough!!!
    Screwloose, mat60, HDRock and 4 others like this.
  19. billb3
    Glad you weren't referencing Madonna
    Screwloose, mat60, Gweedo996 and 2 others like this.
  20. papadave
    Oops.
    Screwloose, mat60, billb3 and 2 others like this.
