Chimney and Stove selection, Englander Madison?
Discussion in 'Modern EPA Stoves and Fireplaces' started by CoreyB, Aug 25, 2017.
  1. Ronaldo
    Ronaldo
    About loading in the minivan.....toyally possible. My wife and I hauled a soapstone (very heavy) in our GrandCaravan. Hauled from eastern SD to IA. We put the seats down, cardboard in and slid it in with boards under the feet. I did put it through the side doors to keep some weight up front.
    Sent from my SM-S320VL using Tapatalk
    papadave, HDRock, Horkn and 4 others like this.
  2. brenndatomu
    A little trailer would work well too...cheap enough to rent if you can't borrow one...
    Horkn, Eric VW, wildwest and 2 others like this.
  3. CoreyB
    CoreyB
    South east iowa
    I will need to build a harth as there is not one anymore that is one big reason of leaning to the madison. Would others be tacky?
    HDRock, Horkn, Eric VW and 1 other person like this.
  4. wildwest
    Imho, staying warm will never be tacky regardless of which stove or ember protection or hearth :)
    You could get a Madison (at your store, that is a plus in my mind), screw up some protection on the walls, put down an ember mat, done in time before the cold hits :thumbs:
    HDRock, Horkn, papadave and 2 others like this.
  5. Eric VW
    Great thread FHC :thumbs:
    Lots of solid questions and advice...no hemming and hawing....:yes:
    HDRock, Thor, Horkn and 2 others like this.
  6. brenndatomu
    Speaking of hemming and hawing...;) I have a question about the thread title? 6-8" :woodsign: What gives? :confused: Inquiring minds want to know...
    (thanks Eric :p)
    Thor, Horkn, Eric VW and 1 other person like this.
  7. wildwest
    See his original post, #1
    Thor, Horkn, CoreyB and 2 others like this.
  8. brenndatomu
    Oh, DUH! Gotta spoon feed me sometimes :picard:
    Without the ... at the end of the title, I didn't "get it" :emb:
    :picard:
    :picard:
    :picard:
    OK, derail averted :handshake:
  9. wildwest
    I opened it up because alot of the beetle kill pine we throw in in the stove here is 6-8, but after I read the first post I :emb:
    Thor and Eric VW like this.
  10. Horkn
    It would easily go in the minivan, and wreck nothing if you plan it though.
  11. Kimberly
    Kimberly
    The Kangaroo State
    That is the same stove I have. When sold at Lowe's, it is under the Summers Heat brand. It is more stove than I really need to heat this house but I really like the stove.
    papadave, HDRock and Ronaldo like this.
  12. Kimberly
    Kimberly
    The Kangaroo State
    With my Madison, I have found the heat shields does the job for the stove; I do have it spaced from the wall according to the instructions. The wall has always been cool behind the stove even when it is up and cruising. What I found is that the most heat on the wall will be from the single walled stove pipe that I used. I don't have a infrared therm but just place my hand on the wall to see how hot. I went with single wall pipe because the double walled was just too costly. However, when I replace the pipe, I am planning on going double walled.
    HDRock likes this.
  13. Kimberly
    Kimberly
    The Kangaroo State
    I think I spent about $120.00 on my hearth pad. Let me find that post.
    wildwest and HDRock like this.
  14. Kimberly
    Kimberly
    The Kangaroo State
    By the way, check ebay for the through the roof chimney kit, I got my through the wall kit for way less than Lowe's wanted. People sometimes get into projects and then abandon them thus selling the kits.
    HDRock and CoreyB like this.
  15. Kimberly
    Kimberly
    The Kangaroo State
    Here you go for the hearth pad I made. I had never done tile work before so it wasn't maybe the best job in the world but I did get the surface fairly level. It was cheaper than the tile hearth pad I searched around to buy and I think the appearance is better than the mats you can buy and they are not exactly cheap either.
    My Hearth Pad
    HDRock likes this.
  16. Kimberly
    Kimberly
    The Kangaroo State
    One thing that I wish I had known before starting, I went with porcelain tile and it said I had to use a special tile set for the porcelain; that tile set was more expensive than the regular thin set mortar. Something to keep in mind.
    wildwest likes this.
  17. CoreyB
    CoreyB
    South east iowa
    Well I can get last year pavers 16" x 16" for a good price from work. Though about putting them down then on the back wall some.
  18. Kimberly
    Kimberly
    The Kangaroo State
    You would want to put them in some sort of border and then grout them. You don't want embers falling into the cracks.
  19. CoreyB
    CoreyB
    South east iowa
    Well stove is ordered. Getting the madison from my work. As long as the stove Is good and I can get 6hrs of burn time I will be grateful. I also have 26 , 16"X16" pathers I plan to use to build a hearth. 64"X64" and up the back wall as much as possible.
    I was wondering if the admins could change the name of this thread. It has grown to a lot more then just 6 inch or 8 inch chimney. Bad thing is I don't even know who is an admin to tag. Lol
    I will continue updates and tons of questions through the whole build process
  20. brenndatomu
    I think you can change it yourself...although I can't tell you exactly how right now...anybody else?
    As for an admin...just tag 'em like this... Moderating
    concretegrazer, HDRock and wildwest like this.
